SMS Text from Basic Stamp to Phone
I'm trying to incorporate an SMS text from my BS2 (I have a BOE-Bot) module to be sent to my (or any) cell phone into a project I am working on.
This is a brand new concept to me and I essentially have no idea on how to do this. I have been searching around, however, and have found several modules that would allow me to implement a SIM card to send the text. My issue, however, is that I do not know if these modules are compatible with the BS2.
For instance:
http://www.sparkfun.com/products/10497
EDIT: I see now that I need the module and the breakout board?
Here is the appropriate module for that board:
http://www.sparkfun.com/products/10138
The ADH8066 Breakout is in my price range and seems reasonable: I essentially need a text sent when the program calls for it be sent. However, I am basically clueless about whether or not this is compatible with what I have. And I am not sure on how to implement it if it is.
Any help would be great!
For instance:
If you haven't already, you might look at SparkFun's IOIO. It's not readily available yet, but looks very promising for this sort of thing.
Do you suggest any other modules? Is this concept completely out of my league?
EDIT: For some reason, I did not see your link to SparkFun's IOIO earlier when I replied.
The problem is that I need this for a design project I am working on for school. It's a ridiculous little freshman engineering class that requires an innovative "smart" product using the Board of Education and BS2. The project is due in 3-4 weeks I believe and we just got our idea approved yesterday.
Part of our design is to *hopefully* send a text message to a phone when a PIR sensor is activated. I was hoping to find an easy "plug and play" solution, but it's not looking like it. My instructor told me that a student a few quarters ago was able to implement a way to send a text message, he had just forgotten how.
Anyway, if you know of anything that might work, I'd really appreciate it. I've spent the majority of the day searching and not coming up with anything life changing.
Thanks.
Our other option would be to have an email alert. Would this be any more plausible?
A cell phone module would be good for this, but they're usually designed for odd voltages and need some work to interface to a 5V processor. You'd have an easier time if you switched to something like a SpinStamp which has a Propeller on-board and runs at 3.3V signal levels ... compatible with a lot of 4V-based cell phone modules.
While it's designed more for the prop than stamp, it has a spot for a MAX3232 level shifter which should work with the stamp I believe. If not I have another variant which uses the ADG3304 level shifter.
Jay Kickliter also had some solutions for talking to Motorola cellphones with a Prop in the prop forum. Some of those phones were below $50, not sure if they are still available
It is essentially a way to take a relay signal to close a circuit and press the speed dial code for a pre-programmed number on a re-purposed cell phone.
I am looking to do the same as you,...I have a motion activated game camera I built with a PIR and canon camera in an enclosure. I would now like to receive a signal of some sort to indicate that a picture was taken, because it is in a remote area. I was trying the cellphone idea with Nokia's and got it to work via text message (resend button activated) but I don't have the phone on a cellular network and don't want to pay for it....so I am looking for other suggestions...
Any ideas on how to get a non-line of sight signal from about 1.5 miles (2km) away? I have a relay that currently closes the shutter that I can use..
I am a bit techie but not an electronic engineer..
HTH
However, the tutorial that darrenervine linked to is exactly what I need that is within the scope of my class/design project, so I am going to try and implement that (modified, of course) with the PIR sensors and the Board of Education.
I can't help with your problem, though. I am not an electrical engineer, either (don't ask me why I have to deal with all of this, hah!).
Anyway, thanks so much for all the help and suggestions. I'll try to post how it goes!
Let me know what you come up with. I started this thread in the Wireless Forum
http://forums.parallax.com/showthread.php?131030-How-to-send-wireless-signal-from-remote-wildlife-camera-2-miles-away but I have not received any ideas yet...
I am in a the centre of a metropolis (Toronto, Ontario) so I need to ensure that I am not sending signals illegally.
Thanks for any help and hope yours works out..
Cheers
Darren
Do most QWERTY-type GSM cell phones respond to AT commands from an input? Or is that rare?
Thanks for any insight!
Dave
The phones would make for a good TX of text message but it needs to be active on a cell network.
I am trying to find a way to do it for free...
Is yours similar to mine or to jknight291?
-dan
http://forums.parallax.com/showthread.php?107472-Wireless-BASIC-Stamp-Communication-using-2-meter-HT-Radios&highlight=basic+stamp+modem
http://forums.parallax.com/showthread.php?109739-basic-stamp-communicating-data-via-packet-radio&highlight=basic+stamp+modem
