Cognew Freezes code, help?
Hi Everyone,
I have decided to re-create the old 'snake' game using the parallax propeller chip. I have written the logic for the motion of the snake and the the output display for a TV screen. This all works nicely until I try and automatically update the position of the snake in a separate cog. As soon as I declare a new cog the code freezes.
So I have stripped down the code to the following basic lines and it still freezes. I cannot figure out why?
Main code:
Tester File:
If I comment out the "Snake.start" line in the main function then I can see the TV visibly updating the screen. But if I don't the code freeze's at that line!
Can anyone tell me why??
Thank you,
Main code:
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
'''''''' TV Dimensions '''''''''''
Frame_Width = 2
Frame_y_top = -Frame_Width
Frame_y_bottom = -207
Frame_x_right = 254
Frame_x_left = Frame_Width-1
Num_Values_In_Snake = 100
VAR
long Snake_x_vals[Num_Values_In_Snake] 'X-Coords
long Snake_y_vals[Num_Values_In_Snake] 'Y-Coords
long counter 'Generic Counter
OBJ
TV : "tv_terminal_graphics"
Snake : "TesterFile"
PUB main
TV.start(12)
DrawFrame
CreateInitialSnake
Plot_Snake
Snake.start
repeat
DrawFrame
TV.color(2)
Plot_Snake
PUB CreateInitialSnake
counter := 0
repeat 10
Snake_x_vals[counter] := 100 + counter
Snake_y_vals[counter] := -103
counter := counter + 1
PUB DrawFrame
'Drawing Frame
TV.Set_Clear
TV.color(1)
TV.Make_box(Frame_x_left, Frame_y_top, Frame_x_right, Frame_y_bottom, Frame_Width)
PUB Plot_Snake
counter :=0
repeat Num_Values_In_Snake
TV.plot(Snake_x_vals[counter], Snake_y_vals[counter])
Tester File:
VAR
long Cog 'Cog Number
long Stack[48] 'StackMemory
long Counter 'Random Counter
PUB start
Counter := 0
Cog := cognew((MoveSnake), @Stack) +1
PUB Stop
if Cog
cogstop(Cog~ - 1)
PRI MoveSnake
repeat
Counter := Counter + 1
Thank you,
How are you going to tell if it's running? You might put in another PUB method like this:
I'm not sure if I remember that right ... but you could give it a try. And it would make sense! The propeller tries to execute the function and pass the return value to cognew. But MoveSnake is an endless loop - never comeing back.
I removed the brackets, and it works now!
