Cognew Freezes code, help?
Hi Everyone,
I have decided to re-create the old 'snake' game using the parallax propeller chip. I have written the logic for the motion of the snake and the the output display for a TV screen. This all works nicely until I try and automatically update the position of the snake in a separate cog. As soon as I declare a new cog the code freezes.
So I have stripped down the code to the following basic lines and it still freezes. I cannot figure out why?
Main code:
Tester File:
If I comment out the "Snake.start" line in the main function then I can see the TV visibly updating the screen. But if I don't the code freeze's at that line!
Can anyone tell me why??
Thank you,
Main code:
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 '''''''' TV Dimensions ''''''''''' Frame_Width = 2 Frame_y_top = -Frame_Width Frame_y_bottom = -207 Frame_x_right = 254 Frame_x_left = Frame_Width-1 '''''''' TV Dimensions ''''''''''' Num_Values_In_Snake = 100 VAR long Snake_x_vals[Num_Values_In_Snake] 'X-Coords long Snake_y_vals[Num_Values_In_Snake] 'Y-Coords long counter 'Generic Counter OBJ TV : "tv_terminal_graphics" Snake : "TesterFile" PUB main TV.start(12) DrawFrame CreateInitialSnake Plot_Snake Snake.start repeat DrawFrame TV.color(2) Plot_Snake ''''''''''''''''''''''''''''''''''''''''''''''''''''''' PUB CreateInitialSnake counter := 0 repeat 10 Snake_x_vals[counter] := 100 + counter Snake_y_vals[counter] := -103 counter := counter + 1 PUB DrawFrame 'Drawing Frame TV.Set_Clear TV.color(1) TV.Make_box(Frame_x_left, Frame_y_top, Frame_x_right, Frame_y_bottom, Frame_Width) PUB Plot_Snake counter :=0 repeat Num_Values_In_Snake TV.plot(Snake_x_vals[counter], Snake_y_vals[counter]) counter := counter + 1
Tester File:
VAR long Cog 'Cog Number long Stack[48] 'StackMemory long Counter 'Random Counter PUB start Counter := 0 Cog := cognew((MoveSnake), @Stack) +1 PUB Stop if Cog cogstop(Cog~ - 1) PRI MoveSnake repeat Counter := Counter + 1
Thank you,
How are you going to tell if it's running? You might put in another PUB method like this:
I'm not sure if I remember that right ... but you could give it a try. And it would make sense! The propeller tries to execute the function and pass the return value to cognew. But MoveSnake is an endless loop - never comeing back.
I removed the brackets, and it works now!
