servo weight limit?
So any one know the exact weight limit for the standard servo that comes with the homework kit?
I need it to lift and turn a directional antenna and need to know the weight limit. :frown:
I don't know but their standard servo says it has "43.1 oz-in torque at 6 V" so if I didn't know anything else then I wouldn't go above 43.1 oz in torque for the one and 1.2 kg.cm for the other.
Parallax Standard Servo (#900-00005)
http://www.parallax.com/Portals/0/Downloads/docs/prod/motors/900-00005StdServo-v2.1.pdf
(GWS) NARO Servo
http://www.parallax.com/Store/Accessories/MotorServos/tabid/163/CategoryID/57/List/0/SortField/0/Level/a/ProductID/488/Default.aspx
Torque: 1.2 kg.cm at 4.8 VDC : 1.4 kg.cm at 6.0 VDC
The only real way to know is to test it and overload it or break one because even good products need to be tested.
http://www.parallax.com/Portals/0/Downloads/docs/prod/Servos/GWSServo.pdf
