LED Display With a 3 Volt @ 5 amp switching power supply
Unique LED graphical display with rectanglar LEDs in a 10X12 matrix. Colors as shown.
TYPE: X/YY Matrix
Color Vf mCd Dominant
RED 1.9 Typ @ 20mA 3-7 660nM
GREEN 2.1 Type @ 20mA 3-5 565nM
YELLOW 2.2 Type @ 20mA 3-5 585nM
Dot Size: Rect. 5.5mm X 3mm
Spacing: 2mmH/V between Dots
Gray Face/Diffused White Lens
Size: 66mm X 48mm X 15mm
WT: .057
Here is the Data sheet for the LED display........> [URL]http://www.mpja.com/download/18050op.pdf[/URL] [LEFT]PIN FUNCTION[/LEFT] 1 R6 ( C1-5) [LEFT]2 R5 ( C1-5)[/LEFT] 3 R4 ( C1-5) 4 R3 ( C1-5) 5 R2 ( C1-5) 6 R1 ( C1-5) 7 C1&6 8 C2&7 9 C3&8 10 R1 ( C6-10) 11 R2 ( C6-10) 12 R3 ( C6-10) 13 R4 ( C6-10) 14 R5 ( C6-10) 15 R6 ( C6-10 PIN FUNCTION [LEFT]30 R7 ( C1-5)[/LEFT] 29 R8 ( C1-5) 28 R9 ( C1-5) 27 R10 ( C1-5) 26 R11 ( C1-5) 25 R12 ( C1-5) 24 C5&10 23 NC 22 C4&9 21 R12 ( C6-10) 20 R11 ( C6-10) 19 R10 ( C6-10) 18 R9 ( C6-10) 17 R8 ( C6-10) 16 R7 ( C6-10)
TYPE: X/YY Matrix
_______________________________________________________________________________________________________
http://www.mpja.com/prodinfo.asp?number=18557+PS
"MFG: AULT
P/N: MW125RA0303B01
Input: 100-240VAC 50-60Hz
Output: 3VDC @ 5A <................The real reading is about 3.2.volts This is a well built power supply I open one to see what is in side
Specifications/Features:
Wall mount switching supply. Non-polarized 2 blade input, 6ft. ZIP cord with 10mm long X 5.5/2.5mm coaxial power plug Center +. ULus/canada/TUV/CE listed.
L: 3-7/8" W: 2-1/2" T: 1-5/8" WT: .78 "
P/N: MW125RA0303B01
Here is what i would like to do is to have a visonal Display outside Temp on this display
I know how this how ever
I have to post a litttle at time because I have all of what I want post just disapprears
http://forums.parallax.com/showthread.php?130951-LED-Display-With-a-3-Volt-5-amp-switching-power-supply
This will help alot
What part # should I use for the MOSFET ?
Is there a way that could light all of the LED on this Display
Which chips would the easyest to use for this project
I want do some thing like did with the LCD Display but do this on the LED Display
I think that would make an excellent supply for your Propeller board.
And with a few of these in parallel, you'll have plenty of load to keep it in regulation, if that's an issue, you'll know it's on, and there'll be plenty of current to spare one way or the other.
Then I could power the hole Project with one power supply
StarKist wants tuna that tastes good!
Either way, I smell a fish.
Yes I know I need to get off my *** and learn this but I just can not get some of the Spin language concepts to stay in my mind and stay there so I could start doing simple project
I hope there is still some hope for me to learn this ...............>
I just start a new job and do not have as much time as I use to BUT we will see .............>
