A question about multiple pushbuttons
Hello, I'm pretty new to all of this, but I've read some in the basic stamp syntax manual and the whats a microcontroller book, but I guess I'm not getting it. I have attached the code that I'm working with so far. It seems that there must be a better way of doing this. I just want to be able to press a pushbutton and have the BSII make a pin high and when I release the button and press it again it makes the same pin low and repeat continuously. And I want to be able to do this for multiple pushbuttons. Basically just turning a momentary pushbutton into a latching or constant switch (3 times or more). from there, I can control an led or use a transistor to operate a relay etc. Any help is appreciated. Thanks!
Also I forgot to make the pins outputs using the command,
DIRD = %1110
but edited that into the program in my previous post. That leaves the pin p12 as an input.
