PASM code that runs with different clock frequencies
I am modifying some PASM code that I have so it will still run correctly even if the Prop's clock frequency is changed (also so this code can be used in different programs that might have different clock frequencies).
To figure out how to get the clock frequency and work with it, I was looking at the PASM code of the Parallax Mouse.spin object, which does exactly what I want:
My question is, what is the "shr t,#18/16/13 'shr scales time" line doing? It looks like it would shift t (the CLKFREQ) to the right by (18 divided by 16 divided by 13), which as far as I can tell would shift it right by 0. Am I missing something? What are these magic numbers 18,16, 13 anyhow?
Thanks.
nap rdlong t,#0 'get clkfreq
napshr shr t,#18/16/13 'shr scales time
min t,#3 'ensure waitcnt won't snag
add t,cnt 'add cnt to time
waitcnt t,#0 'wait until time elapses (nap)
nap_ret ret
Thanks.
You are correct, there are lines of code that makes that line do either a 18, 16 or 13 bit shift. The slashes were intended to show what might be inserted there, not divide-by symbols. My error in not posting all the code. By my calculations, these shifts would make a 122us, 15us and 3.8us delay.
So I think this method of timing adjustment by getting the clockfreq and then doing a shift allows you to adjust the timing according to the clockfreq, but only in a rough manner. (ie, if I need a 104us delay for 9600 baudrate, the closest I could come would be to do a >>13, which would give me 122us. A 12 bit shift is 244us and an 14 bit shift is 61us). I suppose if I needed more accurate timing, the next best (ie minimal code) would be to resort to a lookup table.
Does this sound right to you guys?
In PASM, I add the bit ticks to the current count, execute some code, then check to see if the cnt + bitticks is has occurred. Or you could just loop until...
Thanks for the help.
Some of my video drivers recalculate values every frame based on LONG[0]. It requires some extra code but it means the drivers are completely dynamic and not dependent on any SPIN code. One caution with using SPIN code to do the calculations (which is easier) is to watch your precision. It's real easy to overflow or underflow the result. (The same is true for PASM, but it's easier to tweak the routine.) Just remember that CLKFREQ could be up to 2^27.
it's used like this
movs napshr,#16 'pause ~16us call #napI'd say the 18/16/13 is a reminder to the programmer of the values that might be used.
