Wanting to start with Propeller
Britannicus
Hi there,
Total newbie really to this kind of stuff, but I've been getting on very well so far with my Stamp2 BOE and feel I'd like to experiment with something more versitile and cost-effective.
I've been reading with interest about the propeller, and would like to experiment. I've had bad experiences in the past with PIC in the absence of support, gobbledegook explanations and projects with flawed circuits, which although built corectly just don' t work (what a difference from the parallax world !)
OK, so I've got that off my chest- what's the best way for a dummy to get his feet wet without breaking the bank. I need a sensible book, some fun projects and a stack of compatible bits - there seem to be a number of starter and education kits - what's the best way to go.???
Welcome to the world of the Propeller!
There are many flavors to pick from, a couple personal favorites are the Gadget Gangster Propeller Platform w/ El' Jugador Shield and the Propeller Professional Development Board.
There is also a world of Propeller information freely available,,,
Gadget Gangster Tutorials
Propeller Education Kit Labs: Fundamentals Text
Game Programming for the Propelller Powered Hydra
OBC
You can't program the SpinStamp through the BoE 9pin connector - you have to buy the PropClip.
[ ** I don't use the PropClip. I solder a right-angle header on the SpinStamp (where the PropClip would attach) which enables me to use a PropPlug.]
I may be slightly biased, as I still breadboard almost every circuit that I design, or use, before making a PCB, or putting it on perfboard (in the case of most one offs).
I agree. (Note: Propeller Education Kit = PE Kit). Get this and follow the free tutorials you can download from here:
http://forums.parallax.com/showthread.php?89958-Propeller-Education-Kit-Labs-Tools-and-Applications
The C3 is my current favorite pre-assembled board
I recommend PE+C3
There's also adding uController type sockets to the Parallax Protoboard if you want an inexpensive solution.
Here's the details: http://ucontroller.com/cookbookexcerpt.pdf
OBC
Either way, the PropClip and PropPlug or both $14.99. A PropPlug is good to have on hand if you buy the cheaper Propeller Proto boards without USB.
The pads are clear on all of my SpinStamps
If you want the absolute cheapest method (which is what I started on) buy just the Propeller, and a 5 Mhz Xtal if you want to do video or any time sensitive operation, and an EEPROM only if you want data storage after the power is off, than build the programmer with a few transistors you may have laying around and wire it directly to a D-sub 9 connector (serial port) on your PC. The schematic for that is here: http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/SerialtoPropeller.pdf
I was able to program a Propeller chip for only $15, and that was back when the Propeller was $12.95! at it's new $8 price this would only be about $10. Of course, I also just HAPPENED to have a 5.000Mhz Xtal laying around even though I had never owned a microcontroller besides the Basic Stamp! I still wonder to this day where that thing ever came from...... :-)
Thanks for all the advice.
Any of the pcbs or just the prop chip will get you started. The ProtoBoard USB is a cheap way in as it contains the inbuilt propplug circuitry. You could later cut tracks and add wires and a header to make it a Propplug. There is lots of manuals and info freely available and once you get running you can then decide where your interests lie. Help is only this forum away.
