S2 Work/Test Stand
As promised I have attached photos of my work/test stand for the S2. Couldn't be simpler, but very useful. I let my son do most of the work and let him help with designing it. He thought we didn't need anything to keep it from turning on the stand.
I am a little concerned that doing wheel run test on the stand may not work since the stall sensor is on the rear wheel and will not be running during run test. My have to make a work/test stand that is a rolling type that makes the rear wheel spin when the drive wheels do. OK I've already started working on it.
I'd be glad to share dimensions or answer any questions you might have.
Tony
Edit: 4-4-2011 Added building instructions in PDF
Tony
Congrats to you and your son! That's a very nice-lookng stand. It's obvious that pride in workmanship runs in the family.
BTW (if it's any help), as long as both wheels are running at the same speed, but in opposite directions, the idler wheel is effectively ignored in the stall sensor computation.
Thanks guys for the positive feedback. I read through the complete help file that comes with the GUI software. It noted "that you should hold the robot or put it up on something because you wouldn't want the robot to roll of the table when testing code" So true So true! That's why I build work/test stands.
Phil - If I am testing code that has both wheels moving in the same direction the tail wheel stall detector will be an issue, correct?
Tony
Paul
Phil - Thanks. I thought the checking of the stall sensor was a part of the all the movement code. If I'd been using the gray matter I could have looked at the code.
Tony
Decided I didn't need to draw up a simple project like this, but if you have any questions don't hesitate to ask.
Tony
Nice! I use a coffee cup for my Boe Bot!
Amanda
http://forums.parallax.com/showthread.php?127826-Super-Simple-BOE-BOT-Work-Test-Stand
Tony
