What's the difference between Prop Plug and USB2Ser Dev. Tool?
Both look about the same.
Are they interchangeable?
Can the USB2SER Dev. Tool be used as a Prop Plug to program the Propeller?
This difference is in the 5V / 3.3V connections to the FTDI chip.
However, this looks to be insignificant to its operation.
The important part is the 4 pin connector making connection to your board is the same.
I would say you should be good to go.
Duane
Prop Plug: VSS RES TX RX
USB2SER: RST TX RX VSS
The USB2Ser Dev. Tool is like many of the other "non parallax" adapters.
If my first adapter was the USB2Ser Dev. Tool I wouldn't have had to make
all these gender changers.
See another post regarding the RST pin:
http://forums.parallax.com/showthread.php?130412-SPIN-Problems-Using-Non-Parallax-USB-to-TTL-RS-232-Adapter.&p=986154#post986154
Duane
http://forums.parallax.com/showthread.php?129076-PropPlug-does-not-work-parallax-have-mercy
The difference is that the USB2SER is really designed for 5V applications, but should be ok "in a pinch" for the Propeller, since there are 1K current limiting resistors on the RX and TX lines.
PropPlug: (looking at the front side) VSS RES TX RX USB2SER: (looking at the back side) RES TX RX VSS
...By shifting the Plug over by one, the RES,TX, and RX align. The only signal you need to carry is VSS. A simple jumper wire will do the job.
nice tip. BUT ... the 1k resistors have been replaced by 150Ohm resistors with REV B and C. That's why I choosed to add 680Ohm.
Additionally I don't need it as a Basic Stamp programmer, thus I made it a full Prop-Plug ;o)
"the 1k resistors have been replaced by 150Ohm resistors with REV B and C" - I see that... I looked at the revA datasheet.
Still "in a pinch" it should be ok, but I wouldn't recommend it for a permanent setup. The FT232RQ datasheet indicates a maximum OUTPUT voltage from the datasheet (page 16 table #7) when VCCIO is powered from a 5V supply is at 4.9V(Max) ; 4.1V(Typical) ... The Diode drop of the Propeller (0.4V) and the difference of 3.3V amounts to 1.2V across the 150 Ohm resistor... or 8mA(Max) ;2.7mA(Typical) . The addition of a 680 Ohm resistor lessens the current to 1.4mA(Max) ;482uA(Typical).
Datasheet reference:
http://datasheet.octopart.com/FT232RQ-FTDI-datasheet-120501.pdf
http://www.intra2net.com/en/developer/libftdi/
After searching the forums, this seems the best place for this (short of starting a thread).
