Any one know the current ATF16V8C?
As part of my 15BPP Propeller VGA I am using a bunch of gates, I would like to go over to these GALs, as I have 8 of them. The problem is they do not work with the old programmer that I have used to program the old 16V8 PAL. Does any one know what the difference is? Any help in making a programmer would be appreciated, or if the problem is just software (different fuse list?) then that would be even more helpful.
Thank you in advance for any advice.
It was pointed out that whilst the chip count plumented it required others to have all that programming software and even parallel ports available.
The ATF16V8xx pgm details are non trivial, needing a Vpp voltage, and different sized shifts.
We prefer the ATF16V8BQL, as that has lower standby, but it depends on the delay you can tolerate.
Other choices are ATF1502ASL, which is a larger package, but has easier ISP.
For those without parallel ports, there is an ATDH1150USB pgmr, but it does cost ~ $50
Xilinx newest parts in the XC2C series are 1.8V core, and not 5V compatible.
Do you know how many macrocells you need, and what delays ?
Do you have more info on the total Logic you need, and the clock and delays ?
I guess you also need this 5V operation ?
Does not need to be 5V, can be 3.3.
It comes down to some multiplexing, and simple line/bit twiddling.
The BQL parts use a pin-wakeup system, and above a certain MHz, their Icc and delay, are similar to a non-L.
The next alternative would be a ATF1502AS-10, which is JTAG isp, but PLCC44.tqfp44
3 seems a poor fit - you can socket a PLCC44 ?
If DIP is really important, you could look at the ATF2500C, that comes in DIP40, should just do 40MHz. Clk-out of 10ns.
{ Programmer support for this device could be a problem. 12.5V & 12.5V pulsed IIRC }
My suggestion would be to target the ATF1502AS, in PLCC44, over 3x16V8 (60 pins) or 1 x ATF2500C(dip40) ?
The ATF1502AS-10JU is 5V & ISP, I think with a choice of cables
If you need to get to a breadboard, for prototypes, there is always Digikey ATF15XXDK3-SAJ44-ND adaptor ?
And when I need breadboard compatibility, I get extra chips and solder leads directly to the pins (if they are not DIP, or not 0.1 inch).
Device f1502ispplcc44;
- this reserves 4 pins for ISP, and keeps (re) pgm simple - and then merge your 3 ATF16V8 design files into one.
(you can use pins as IO with jtag off, or Device f1502plcc44, but then you cannot re-pgm easily.)
