A Prop enabled Gender Changer
Tubular
Greetings all,
I've been applying the squeezulator to shrink the prop down towards something approaching a gender changer. The VGA connection is made with the help of a tiny board at right angles to the main board.
As part of this endeavor I've worked out a footprint for the C3 style memory footprint that is just 1" long. I'll post this shortly.
Ultimately I'm trying to fit into the form factor of a D9 right angle female connector, to make it ultra easy to add a C3 enabled rendering Prop to other legacy or new projects.
I suspect it's all 2 layer pcbs.
Good point Cluso those don't look big enough to be a uSD holder. I'll annotate the pics to convey it better.
