A Prop enabled Gender Changer — Parallax Forums
TubularTubular Posts: 4,772
edited 2011-03-26 20:36 in Propeller 1
Greetings all,
I've been applying the squeezulator to shrink the prop down towards something approaching a gender changer. The VGA connection is made with the help of a tiny board at right angles to the main board.
As part of this endeavor I've worked out a footprint for the C3 style memory footprint that is just 1" long. I'll post this shortly.
Ultimately I'm trying to fit into the form factor of a D9 right angle female connector, to make it ultra easy to add a C3 enabled rendering Prop to other legacy or new projects.
  • TubularTubular Posts: 4,772
    edited 2011-03-26 15:51
    (reserved for Diptrace files)
  • roglohrogloh Posts: 6,322
    edited 2011-03-26 17:08
    Looks impressive. How many layers do you need to use on your boards to get them that small?
    edited 2011-03-26 19:45
    very nice :) Guess you should say that the connector on the prop pcb is for a microSD card !
    I suspect it's all 2 layer pcbs.
    edited 2011-03-26 20:08
    Yes, just 2 layers, plus a couple of wire links. In fact the memory subsection is really a single layer (except the uSD connector)
    Good point Cluso those don't look big enough to be a uSD holder. I'll annotate the pics to convey it better.
  • M. K. BorriM. K. Borri Posts: 280
    This is awesome. I'll buy one when you got one for sale!!!
