USB Camera
Bill Chennault
All--
I bought a USB camera like the one the dentist sticks in your mouth. You can find them all over Amazon . . . and other places, I imagine. (Here's the one I bought on Amazon.) Of course, it is only LIKE the much more expensive camera your dentist shoves in your mouth. (I don't know the differences, other than the dental software is high dollar stuff.)
The software doesn't work well under Win 7. All I can get it to do is video. However, under XP it appears to function well. (The Amazon blurb doesn't mention Win 7.) I will use it on my XP laptop.
Here are my first two images . . .
Propeller on an AP-16+.......TP508 on an AP-16+
Here is an link to an exciting 139mb avi AP-16+ video.
I will use it in several different hobbies, but it is laying on my robotics desk and I can already tell it is going to be great in its preview mode to see those itty-bitty things on a PCB!
--Bill
--Bill
Mike.
The images look pretty good to me.
Have you hack-in to the plastic yet?
Thanks for sharing the cool find.
If the cam is a like a webcam and needs power to run It will need a 12V power injector .
as 4 Pin jacks are data only . If the cam is a normal DV cam you can buy 4 to 4 pin cables .
I would not recomend a adapter ads the 4 pin jack is SO small you really do risk breaking off the jack in side the computer or cam .
less stress is the best .
Peter KG6LSE
Sorry to not be responsive. I am away from my "stuff" for a bit.
--Bill
did you test under 7 the camera using an image software, like irfanview? It should work also as a capture tool.
Massimo
I only spent $280 0n na 2007 dual core whichich is fast, i only use web browsing and proptoop mand picaxe tool.
Im also interested minm building games thism them unreal editor sovillmdown load the 1.3 gig sdk and see if my macine can runnthe Epic edditor
--Bill
Also with mine the software supplied was terrible, and guess what, it is called AMcap...
Anyway I can use it under irfanview selecting file->acquire and then selecting the right source (if you have more than one). Then you can capture the images.
It works also under skype...
Massimo
