Yes, that's right. Post your actual binary and I'll try that here.
Ross.
I just tried loading it again and now it seems to work. It's a bit faster than the -x3 version but not enough to make it actually usable. Oh well, it was worth a try. Thanks for your help!
Maybe there is still a bug or two lurking in there. As I mentioned in post #388, I'm a bit perplexed by some of the benchmark results I'm seeing with the cache, so I think there is still some room for improvement.
Ross.
David (& Jazzed)
It appears I have mixed up my OFFSETS with my INDEXES in the SPI cache code. I'm surprised it works at all!
Latest cogject code - this replicates the entire simpleserial spin object.
Some things have ended up a lot simpler in C than in spin eg
PUB dec(value) | i
'' Print a decimal number
if value < 0
-value
tx("-")
i := 1_000_000_000
repeat 10
if value => i
tx(value / i + "0")
value //= i
result~~
elseif result or i == 1
tx("0")
i /= 10
becomes
void serial_dec(unsigned long value,unsigned long par[]) // send out decimal value - unsigned
char lineoftext[11] = ""; // enough room for a 32 bit long 2^32
sprintf(lineoftext, "%u", value); // convert to a string
serial_str(lineoftext,par); // send out the string
The startup cog code is in an array, and you can either leave it as it is, or overwrite it with a .cog file.
I have been pushing this code and come across a little problem which may or may not also occur in Spin. If the baud rate is set very slow (1200) and lots of bytes are sent very quickly, the buffer full code does not seem to catch the error. I am not sure if maybe this is pasm updating the head before the tail or some other reason, or maybe the way C reads the variables? I presume that in a "while" loop C is reupdating the parameters? Maybe this is happening because C is faster than Spin?
I have put a 100ms sleep in this while routine (30ms was not long enough at 1200). I wonder if there is another better solution eg a gap of 2 or 3 between the head and tail, rather than 1?
void serial_tx(char tx,unsigned long par[])
PUB tx(txbyte)
'' Send byte (may wait for room in buffer)
repeat until (tx_tail <> (tx_head + 1) & $F)
tx_buffer[tx_head] := txbyte
tx_head := (tx_head + 1) & $F
if rxtx_mode & %1000
rx
unsigned long tx_head;
int address;
while ( par[3] == (par[2] + 1 ) & 0xF)
{ // par[2] is tx_head, par[3] is tx_tail
sleep(100); // small delay to send out some bytes, should only happen with slow baud rates
// printf("head is one less than the tail, buffer full");
poke(address,tx); // poke the tx byte value to hub ram
tx_head = par[2]; // get the head value
address = par[8] + 16 + tx_head; // location of rx buffer plus 16 to get tx buffer plus the head value
tx_head = tx_head + 1; // add one
tx_head = tx_head & 0xF; // logical and with 15
par[2] = tx_head; // store it back again
// need to add the echo mode?
I now need to think about the "merging" of multiple cogjects - eg things like multiple entries for "stdio", multiple copies of functions (like the cog loader) and other include files, and merging things into the "main" function. I might see if I can find another object to work on...
/* PASM demo for use with Catalina IDE Precompiler and Compiler */
#include <stdio.h>
// PASM blocks of code and associated arrays
/* PASM Code for compilation using SpinC and inclusion as a data file
PASM Start serial.spin
CON
' add your values here
_clkfreq = 80_000_000 ' 5Mhz Crystal
_clkmode = xtal1 + pll16x ' x 16
' Start of C hub constants
' End of C constants
PUB Main
coginit(1,@entry,0) ' cog 1, cogstart, dummy value
DAT
'* Assembly language serial driver *
org
' Entry
entry mov t1,par 'get structure address
add t1,#4 << 2 'skip past heads and tails
rdlong t2,t1 'get rx_pin
mov rxmask,#1
shl rxmask,t2
add t1,#4 'get tx_pin
rdlong t2,t1
mov txmask,#1
shl txmask,t2
add t1,#4 'get rxtx_mode
rdlong rxtxmode,t1
add t1,#4 'get bit_ticks
rdlong bitticks,t1
add t1,#4 'get buffer_ptr
rdlong rxbuff,t1
mov txbuff,rxbuff
add txbuff,#16
test rxtxmode,#%100 wz 'init tx pin according to mode
test rxtxmode,#%010 wc
if_z_ne_c or outa,txmask
if_z or dira,txmask
mov txcode,#transmit 'initialize ping-pong multitasking
' Receive
receive jmpret rxcode,txcode 'run a chunk of transmit code, then return
test rxtxmode,#%001 wz 'wait for start bit on rx pin
test rxmask,ina wc
if_z_eq_c jmp #receive
mov rxbits,#9 'ready to receive byte
mov rxcnt,bitticks
shr rxcnt,#1
add rxcnt,cnt
:bit add rxcnt,bitticks 'ready next bit period
:wait jmpret rxcode,txcode 'run a chuck of transmit code, then return
mov t1,rxcnt 'check if bit receive period done
sub t1,cnt
cmps t1,#0 wc
if_nc jmp #:wait
test rxmask,ina wc 'receive bit on rx pin
rcr rxdata,#1
djnz rxbits,#:bit
shr rxdata,#32-9 'justify and trim received byte
and rxdata,#$FF
test rxtxmode,#%001 wz 'if rx inverted, invert byte
if_nz xor rxdata,#$FF
rdlong t2,par 'save received byte and inc head
add t2,rxbuff
wrbyte rxdata,t2
sub t2,rxbuff
add t2,#1
and t2,#$0F
wrlong t2,par
jmp #receive 'byte done, receive next byte
' Transmit
transmit jmpret txcode,rxcode 'run a chunk of receive code, then return
mov t1,par 'check for head <> tail
add t1,#2 << 2
rdlong t2,t1
add t1,#1 << 2
rdlong t3,t1
cmp t2,t3 wz
if_z jmp #transmit
add t3,txbuff 'get byte and inc tail
rdbyte txdata,t3
sub t3,txbuff
add t3,#1
and t3,#$0F
wrlong t3,t1
or txdata,#$100 'ready byte to transmit
shl txdata,#2
or txdata,#1
mov txbits,#11
mov txcnt,cnt
:bit test rxtxmode,#%100 wz 'output bit on tx pin according to mode
if_z_and_c xor txdata,#1
shr txdata,#1 wc
if_z muxc outa,txmask
if_nz muxnc dira,txmask
add txcnt,bitticks 'ready next cnt
:wait jmpret txcode,rxcode 'run a chunk of receive code, then return
mov t1,txcnt 'check if bit transmit period done
sub t1,cnt
cmps t1,#0 wc
if_nc jmp #:wait
djnz txbits,#:bit 'another bit to transmit?
jmp #transmit 'byte done, transmit next byte
' Uninitialized data
t1 res 1
t2 res 1
t3 res 1
rxtxmode res 1
bitticks res 1
rxmask res 1
rxbuff res 1
rxdata res 1
rxbits res 1
rxcnt res 1
rxcode res 1
txmask res 1
txbuff res 1
txdata res 1
txbits res 1
txcnt res 1
txcode res 1
PASM End
unsigned long serial_cog[511] =
0xa0bca9f0, 0x80fca810, 0x08bcaa54, 0xa0fcb201,
0x2cbcb255, 0x80fca804, 0x08bcaa54, 0xa0fcbe01,
0x2cbcbe55, 0x80fca804, 0x08bcae54, 0x80fca804,
0x08bcb054, 0x80fca804, 0x08bcb454, 0xa0bcc05a,
0x80fcc010, 0x627cae04, 0x617cae02, 0x689be85f,
0x68abec5f, 0xa0fcc833, 0x5cbcbc64, 0x627cae01,
0x613cb3f2, 0x5c640016, 0xa0fcb809, 0xa0bcba58,
0x28fcba01, 0x80bcbbf1, 0x80bcba58, 0x5cbcbc64,
0xa0bca85d, 0x84bca9f1, 0xc17ca800, 0x5c4c001f,
0x613cb3f2, 0x30fcb601, 0xe4fcb81e, 0x28fcb617,
0x60fcb6ff, 0x627cae01, 0x6cd4b6ff, 0x08bcabf0,
0x80bcaa5a, 0x003cb655, 0x84bcaa5a, 0x80fcaa01,
0x60fcaa0f, 0x083cabf0, 0x5c7c0016, 0x5cbcc85e,
0xa0bca9f0, 0x80fca808, 0x08bcaa54, 0x80fca804,
0x08bcac54, 0x863caa56, 0x5c680033, 0x80bcac60,
0x00bcc256, 0x84bcac60, 0x80fcac01, 0x60fcac0f,
0x083cac54, 0x68fcc300, 0x2cfcc202, 0x68fcc201,
0xa0fcc40b, 0xa0bcc7f1, 0x627cae04, 0x617cae02,
0x6ce0c201, 0x29fcc201, 0x70abe85f, 0x7497ec5f,
0x80bcc658, 0x5cbcc85e, 0xa0bca863, 0x84bca9f1,
0xc17ca800, 0x5c4c004d, 0xe4fcc446, 0x5c7c0033
// start of C functions
void external_cog_load(int cognumber, unsigned long cogdata[], unsigned long *parameters_array) // load a cog from external memory
unsigned long hubcog[511]; // create a local array, this is in hub ram, not external ram
int i;
for(i=0;i<512;i++)
hubcog[i]=cogdata[i]; // move from external memory to a local array in hub
_coginit((int)parameters_array>>2, (int)hubcog>>2, cognumber); // load the cog
void clearscreen() // white text on dark blue background
int i;
for (i=0;i<40;i++)
t_setpos(0,0,i); // move cursor to next line
t_color(0,0x08FC); // RRGGBBxx eg dark blue background 00001000 white text 11111100
void sleep(int milliseconds) // sleep function
_waitcnt(_cnt()+(milliseconds*(_clockfreq()/1000))-4296);
char peek(int address) // function implementation of peek
return *((char *)address);
void poke(int address, char value) // function implementation of poke
*((char *)address) = value;
unsigned long serial_start(unsigned long rxpin,unsigned long txpin,unsigned long mode, unsigned long baudrate, unsigned long par[], unsigned long cogdata[])
PUB start(rxpin, txpin, mode, baudrate) : okay
'' Start serial driver - starts a cog
'' returns false if no cog available
'' mode bit 0 = invert rx
'' mode bit 1 = invert tx
'' mode bit 2 = open-drain/source tx
'' mode bit 3 = ignore tx echo on rx
stop
longfill(@rx_head, 0, 4)
longmove(@rx_pin, @rxpin, 3)
bit_ticks := clkfreq / baudrate
buffer_ptr := @rx_buffer
okay := cog := cognew(@entry, @rx_head) + 1
unsigned long okay;
unsigned long bit_ticks;
unsigned long buffer_ptr;
par[0] = 0; // rx_head longfill(@rx_head, 0, 4)
par[1] = 0; // rx_tail
par[2] = 0; // tx_head
par[3] = 0; // tx_tail
par[4] = rxpin; // longmove(@rx_pin, @rxpin, 3)
par[5] = txpin; // note - if rewrite the pasm code could save a couple of hub longs here
par[6] = mode; // as rxpin and txpin are not used anywhere else
bit_ticks = _clockfreq() / baudrate; // bit_ticks := clkfreq / baudrate
par[7] = bit_ticks;
buffer_ptr = (unsigned long)&par[9]; // buffer_ptr := @rx_buffer points to start of circular buffer
par[8] = buffer_ptr; // pointer to the start of the circular buffers
// rx buffer is 9 to 12 and tx buffer is 13 to 16 (16 bytes =4 longs)
external_cog_load(7,cogdata,par); // load from external ram
// okay returns the cog number or -1 if a fail page 119 manual. Ignored here
printf("par array is at %u \n",(unsigned long)&par[0]);
printf("par array entry 1 is at %u \n",(unsigned long)&par[1]);
printf("par array entry 7 is at %u \n",(unsigned long)&par[7]);
printf("rx_head is at %u \n",(unsigned long)&par[9]);
printf("buffer_ptr is %u \n",par[8]);
return okay;
PUB tx(txbyte)
rx
int address;
unsigned long serial_rxcheck(unsigned long par[])
PUB rxcheck : rxbyte
'' Check if byte received (never waits)
'' returns -1 if no byte received, $00..$FF if byte
rxbyte--
if rx_tail <> rx_head
rxbyte := rx_buffer[rx_tail]
rx_tail := (rx_tail + 1) & $F
unsigned long rxbyte; // actually is a long, so can return -1 FFFFFFFF if nothing and 0-FF if a byte
int address; // hub address
rxbyte = 0; // set explicitly to zero
rxbyte = rxbyte - 1; // return ffffffff if nothing
if (par[1] != par[0])
address = par[8] + par[1]; // par[8] is the rx buffer, par[1] is rx_tail
rxbyte = peek(address); // get the return byte from the buffer
par[1] = (par[1] +1) & 0xF; // add one to tail
return rxbyte;
unsigned long serial_rx(unsigned long par[])
PUB rx : rxbyte
'' Receive byte (may wait for byte)
'' returns $00..$FF
repeat while (rxbyte := rxcheck) < 0
unsigned long rxbyte; // actually is a long, not a byte
while ((rxbyte = serial_rxcheck(par)) == -1) {} // 0xffffffff and -1 works, but " < 0" gives a compiler error
return rxbyte; // return the value
void serial_rxflush(unsigned long par[]) // flush receive buffer
while (serial_rxcheck(par) != -1) {} // keep checking until buffer clear
unsigned long serial_rxtime(unsigned long ms,unsigned long par[]) // wait ms milliseconds for byte, -1 if nothing
unsigned long rxbyte = -1;
unsigned long counter = 0; // start a counter, 10ms ticks
ms = ms / 10; // internal delay for 1ms ticks is too high
while (((rxbyte = serial_rxcheck(par)) == -1) & (counter < ms)) // wait until a byte or counter times out
_waitcnt(_cnt()+(10*(_clockfreq()/1000))-4296); // wait 10 milliseconds
counter +=1; // add one to counter
return rxbyte;
void serial_str(char lineoftext[],unsigned long par[]) // send out the string
'' Send string
repeat strsize(stringptr)
tx(byte[stringptr++])
int i;
for(i=0; i<strlen(lineoftext);i++)
serial_tx(lineoftext[i],par); // send out the bytes one at a time
if value < 0
-value
tx("-")
i := 1_000_000_000
repeat 10
if value => i
tx(value / i + "0")
value //= i
result~~
tx("0")
i /= 10
// printf ("lineoftext is now: %s\n", lineoftext);
void serial_hex(unsigned long value, unsigned long par[]) // send out a hex value
'' Print a hexadecimal number
value <<= (8 - digits) << 2
repeat digits
tx(lookupz((value <-= 4) & $F : "0".."9", "A".."F"))
char lineoftext[8] = ""; // enough room for FFFFFFFF
sprintf(lineoftext,"%x",value); // convert to hex value
serial_str(lineoftext,par); // send it out
void serial_crlf(unsigned long par[]) // send a crlf
serial_tx(13,par); // cr
serial_tx(10,par); // lf
int EoF (FILE* stream)
register int c, status = ((c = fgetc(stream)) == EOF);
ungetc(c,stream);
return status;
void readcog(char *filename,unsigned long external_cog[]) // read in a .cog file into external memory array
int i;
FILE *FP1;
i = 0;
if((FP1=fopen(filename,"rb"))==0) // open the file
fprintf(stderr,"Can't open file %s\n",filename);
exit(1);
fseek(FP1,0,0);
while(!EoF(FP1) & (i<511)) // run until end of file
external_cog[i] = getc(FP1) | (getc(FP1)<<8) | (getc(FP1)<<16) | (getc(FP1)<<24); // get the long
// printf("%u ",external_cog[i]);
i+=1;
if(FP1)
fclose(FP1); // close the file
FP1=NULL;
printf("external array cog 0 = %u \n",external_cog[0]);
void main ()
int i;
char lineoftext[80]; // for string testing
unsigned long received_byte; // actually a long, not a byte
unsigned long serial_parameters[16]; // reserve hub space for buffer, head tail pointers
clearscreen(); // white on blue vga
printf("Clock speed %u \n",_clockfreq()); // see page 28 of the propeller manual for other useful commands
printf("Catalina running in cog number %i \n",_cogid()); // integer
printf("internal array cog 0 = %u \n",serial_cog[0]);
readcog("serial.cog",serial_cog); // read in serial.cog to external memory overwrites existing data
serial_start(31,30,0,1200,serial_parameters,serial_cog); // start serial cog pins 31,30, mode 0, 1200 baud
printf("Started serial driver\n");
for(i=0; i<10; i++)
serial_tx(65+i,serial_parameters); // test sending a byte 10x (delay for starting a serial terminal program)
sleep(500);
printf("send byte %u \n",65+i);
strcpy(lineoftext,"This is a really long string test with a slow baud rate to check buffer overruns"); // store a string
serial_str(lineoftext,serial_parameters); // send it out
serial_crlf(serial_parameters);
serial_dec(102030405,serial_parameters); // send out a big decimal number
serial_str("Hex value is ",serial_parameters);
serial_hex(102030405,serial_parameters); // send out a hex value
serial_rxflush(serial_parameters); // flush the receive buffer
printf("Type a character within the next 3 seconds \n"); // test the timeout
received_byte = serial_rxtime(3000,serial_parameters); // get a byte with a timeout
printf("character was ascii %u \n",received_byte);
printf("type some characters, will return that character plus 1 \n");
for (i=0;i<19;i++) // test 19 times, so tests buffer restarting
received_byte = serial_rx(serial_parameters); // get a byte
serial_tx(received_byte,serial_parameters); // echo it back
printf("sent back byte %u \n",received_byte);
printf("program finished \n");
while (1); // Prop reboots on exit from main()
void serial_dec([COLOR="red"]signed[/COLOR] long value,unsigned long par[])
char lineoftext[[COLOR="red"]12[/COLOR]]; // 10 digits, sign, terminator
sprintf(lineoftext, "%[COLOR="red"]d[/COLOR]", value);
Regarding your tx issue, this may be related to compiler optimisations (volatile variables). You also have two poke calls in there, one with an uninitialised address.
PUB tx(txbyte)
rx
int address;
[COLOR="red"]poke(address,tx); // poke the tx byte value to hub ram[/COLOR]
With the compiler I use at work this will give the desired affect, as to whether Catalina supports it is a question for Ross (you could also try yourself).
void serial_tx(char tx, [COLOR="red"]volatile[/COLOR] unsigned long par[])
Thanks kuroneko
1) printing negative numbers now
2) Thanks for spotting the uninitialised poke call. The first one was some leftover code from debugging - I have deleted it. That was a good bug to find - it could have caused all sorts of problems later on!
3) Ross will hopefully have some advice as to whether the "volatile" would help here.
I tidied up the code a lot. The "main" now only has one call to the demo function, and it has the one parameter array declaration. This makes it much easier to see how much hub ram a cogject is going to reserve.
I put all the functions in a "demo" routine. I think this could be a handy addition to any cogject. One reason you might not have a demo routine in Spin is that it uses precious memory, but with this program running from external memory, it does not cost so much to add a demo routine.
As per a comment from Heater, I got rid of the IDE modifying the C program. What I was finding is that the PASM part hardly needs editing. In fact, it really needs no editing if an existing object is using the PAR method (ones by Chip Gracey tend to conform to this method, I need to do some more research as to which other ones do).
So now, if you want to build a new program, use Homespun and SPINC to create an array. The vb.net IDE also creates a .cog file, so with one keypress you have a .h array file and a .cog file for the sd card. Copy the .h array back into the program and you probably never will need to edit it.
I added in the author acknowledgement and the MIT license.
I also added a quick list of all the functions at the beginning of the code.
/* PASM serial demo for use with Catalina compiler */
#include <stdio.h>
/* PASM Code - use Homespun and SPINC to create a .h file.The Catalina vb.net IDE can also create a .cog file for the sd card
Make the array an unsigned long with 511 longs
Put the array before any functions so it ends up in external memory (arrays within functions end up in hub memory)
A logical place for the array if there are multiple blocks of pasm code is to place it underneath the pasm code
''* Full-Duplex Serial Driver v1.1 *
''* Author: Chip Gracey *
''* Copyright (c) 2006 Parallax, Inc. *
''* See end of file for terms of use. *
''* C version by James Moxham *
Functions:
serial_start // start the serial driver
serial_tx // send a byte
serial_rx // receive a byte
serial_rxcheck // check if any bytes present
serial_rxflush // flush the receiver buffer
serial_rxtime // check for a byte, time out after n milliseconds
serial_dec // send out number as a decimal number
serial_hex // send out number as a hex number
serial_str // send out a string
serial_crlf // send a carriage return and line feed
readcog // read a .cog file from the sd card to external memory
PASM Start - put 'PASM Start' at the beginning so that the color highlighter knows to highlight the CON PUB DAT. Put 'PASM End' at the end
CON
PUB Main
DAT
org
' Entry
mov rxmask,#1
shl rxmask,t2
rdlong t2,t1
mov txmask,#1
shl txmask,t2
rdlong rxtxmode,t1
rdlong bitticks,t1
rdlong rxbuff,t1
mov txbuff,rxbuff
add txbuff,#16
if_z or dira,txmask
' Receive
test rxmask,ina wc
mov rxcnt,bitticks
shr rxcnt,#1
add rxcnt,cnt
sub t1,cnt
cmps t1,#0 wc
if_nc jmp #:wait
rcr rxdata,#1
djnz rxbits,#:bit
and rxdata,#$FF
add t2,rxbuff
wrbyte rxdata,t2
sub t2,rxbuff
add t2,#1
and t2,#$0F
wrlong t2,par
' Transmit
add t1,#2 << 2
rdlong t2,t1
add t1,#1 << 2
rdlong t3,t1
cmp t2,t3 wz
if_z jmp #transmit
rdbyte txdata,t3
sub t3,txbuff
add t3,#1
and t3,#$0F
wrlong t3,t1
shl txdata,#2
or txdata,#1
mov txbits,#11
mov txcnt,cnt
shr txdata,#1 wc
sub t1,cnt
cmps t1,#0 wc
if_nc jmp #:wait
t1 res 1
t2 res 1
t3 res 1
rxtxmode res 1
bitticks res 1
rxmask res 1
rxbuff res 1
rxdata res 1
rxbits res 1
rxcnt res 1
rxcode res 1
txmask res 1
txbuff res 1
txdata res 1
txbits res 1
txcnt res 1
txcode res 1
PASM End
│ TERMS OF USE: MIT License │
│Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation │
│files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, │
│modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software│
│is furnished to do so, subject to the following conditions: │
│The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.│
│THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE │
│WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR │
│COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, │
│ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. │
int i;
for (i=0;i<40;i++)
void external_memory_cog_load(int cognumber, unsigned long cogdata[], unsigned long parameters_array[]) // load a cog from external memory
int i;
for(i=0;i<512;i++)
stop
unsigned long okay;
par[7] = bit_ticks;
external_memory_cog_load(7,cogdata,par); // load from external ram
// printf("par array is at %u \n",(unsigned long)&par[0]);
// printf("par array entry 1 is at %u \n",(unsigned long)&par[1]);
// printf("par array entry 7 is at %u \n",(unsigned long)&par[7]);
// printf("rx_head is at %u \n",(unsigned long)&par[9]);
// printf("buffer_ptr is %u \n",par[8]);
return okay;
PUB tx(txbyte)
rx
int address;
while ( par[3] == ((par[2] + 1 ) & 0xF)) {} // wait if the head has looped right round and is now one less than the tail
rxbyte--
return rxbyte;
PUB rx : rxbyte
'' returns $00..$FF
return rxbyte;
'' Send string
int i;
void serial_dec(signed long value,unsigned long par[]) // send out decimal value - unsigned
if value < 0
-value
tx("-")
i := 1_000_000_000
repeat 10
if value => i
tx(value / i + "0")
value //= i
result~~
tx("0")
i /= 10
char lineoftext[12] = ""; // enough room for a 32 bit long 2^32 and possibly the minus sign
sprintf(lineoftext, "%d", value); // convert to a string
repeat digits
ungetc(c,stream);
return status;
int i;
FILE *FP1;
i = 0;
exit(1);
fseek(FP1,0,0);
i+=1;
if(FP1)
FP1=NULL;
printf("external array cog first long = 0x%x \n",external_cog[0]); // hex value
void serial_demo(unsigned long serial_parameters[]) // demonstrate the serial cog code
int i;
unsigned long value = 0x80000000; // 80000000 is -1
printf("internal array cog first long = 0x%x \n",serial_cog[0]); // hex value
// readcog("serial.cog",serial_cog); // read in serial.cog to external memory overwrites existing data
for(i=0; i<10; i++)
sleep(500);
serial_crlf(serial_parameters); // new line
serial_dec(value,serial_parameters); // send out a big decimal number
serial_hex(value,serial_parameters); // send out a hex value
printf("character was ascii %d \n",received_byte); // %d is signed
printf("type some characters \n");
for (i=0;i<10;i++) // test 19 times, so tests buffer restarting
printf("demo program finished \n");
void main ()
unsigned long serial_parameters[16]; // reserve hub space in main for buffer, head tail pointers
serial_demo(serial_parameters); // demo routines
while (1); // endless loop as prop reboots on exit from main()
Yes, Catalina understands "volatile", but I'this is not the problem (I just tried it and the code generated is the same in both cases, so nothing is being optimized away).
I think the problem is a missing set of parentheses:
Yes, my cache code was indeed faulty (embarassingly so!). I've fixed it and will post you both a new pre-release once I have tidied it up and done a little more testing.
David, you may be interested in the timing - with the corrected cache code, the time to compile your test program has halved - i.e. from 12 seconds to around 6 seconds. The -x4 option is slightly faster than the -x3 option, but not dramatically so - this is probably because of the much smaller cache size (2k instead of 8k).
Ok, I edited the code in the post 2 above. No delay needed now.
In a general sense, this does bring up a question as to whether there are any precedence differences between Spin and C.
For long lines of code that have multiple operators in them, and sometimes with no comments, one way to make sense of these is to split them up into individual lines. Maybe you need to add a temporary variable, and maybe it is this need for a temporary variable that is the reason there are these lines of code in some programs (though that doesn't explain the lack of any explanatory comments on some of the longer ones!) Maybe it is just the gentle art of obfuscation?
Anyway, with a program running in external memory, it does not matter if you add one temp variable to a function. I'm not even sure if this even slows down the code, - is assigning a value to a variable faster or slower or the same speed as pushing a variable onto the stack?
But the part that has me a little confused is when you come across a complex equation in Spin that is part of a 'repeat' loop. Is there any way to split up the 'while' equation in C into multiple lines?
Maybe you have a temp variable and you assign its value before the while, and then reassign its value at the end of the while block - with multiple lines? This is a bit messy though as it means you have two assignments to the variable.
Hopefully not too many of these are going to come up!
I have thought at times whether one could write a Spin to C translator, but it is the difference in precedence that might be the tricky part.
Anyone who programs in multiple languages soon learns not to depend on precedence rules. Use lots of parentheses instead. If you compare the page I linked above with the SPIN operator precedence table on page 143 of the Propeller Manual, you will see there are lots of differences, as well as missing operators on both sides. SPIN isn't really "C-like" once you get past a few trivial syntactic similarities.
Judicious use of the "register" keyword can make them the same. For example:
void main() {
register int f;
register int g;
int a = 1;
int b = 2;
int c = 3;
int d = 4;
int e = 0;
/* this ... */
e = (a/b)-(c*d);
/* generates the same code as this ... */
f = a/b;
g = c*d;
e = f - g;
C has do ... while as well as simple for and while loops. It would probably be worth figuring out the equivalent C loop to each of the SPIN repeat options.
Thanks for all the hints. Brackets it is, and you may see the register keyword in some of my code.
re do and while, it has taken me years to work out the difference between these, both in C and Basic.
In a nutshell, one tests the variable at the beginning and one at the end. A 'do' will go through the next code at least once. A 'while' will not if the condition is false.
Spin has similar rules. I think if I come across a 'repeat' in the future and it needs to be changed to a 'while' and it has complex maths, I'll be adding lots of brackets.
I have another question now - one of the things I want to code is the highest resolution vga driver and that uses 4 cogs. That means I need to shut down a number of catalina cogs, and if I shut something down, I need to get it working again afterwards.
So the next object to code is the standard spin keyboard.
I must say that the second object is much easier than the first - especially Chip's code as it follows the same rules.
Which cog is the catalina keyboard running in?
I did some experiments with scanf. I think with two drivers running there are going to be problems and I am seeing the Num Lock led flashing so I am using this as a test. Working through the cogs one at a time and running cogstop, if I shut down cog 4 then the keyboard leds do not flash.
However, printf then stops working. Is stdio going to get upset if I shut down the keyboard? And is it cog 4 or have I got that wrong?
This is not so easy to determine, because I was lazy and only registered the HMI plugin itself, not the individual drivers. The way I do it when I need to (e.g. look in demos\multicog\dining_philosphers.c) is just to add one to my own cog id to to get the keyboard driver, since I know it is always the first driver started. But I'll fix this in Catalina 3.0 to explicitly register each driver when it is started, so that you can find it at runtime by searching the registry.
Nothing will stop working if you shut down the keyboard driver. But you'll have to write your own code to start it back up again!
Lots of experiments and the one that prints all the error messages and does not flash the leds is cog 0.
printf("stop keyboard cog \n");
_cogstop(0);
printf("stopped a cog \n");
This reports catalina is running in cog 2.
Does this mean that the keyboard driver goes into the first free cog and that is cog 0?
Shutting down cog 3 or 4 gives very odd behaviour. I guess the next test to see if it is cog 0 is to try getting something from the keyboard.
Addit: yes, cog 0 is the keyboard. This code is incrementing the head counter each keypress and printing 65 when you hit a capital A. Woot!
_cogstop(0);
key_start(26,27,key_parameters,key_cog);
printf("keyboard started \n");
for (i=0;i<10;i++)
sleep(1000);
printf("value of head is %u \n",key_parameters[1]);
printf("value of par_present is %u \n",key_parameters[2]);
printf("value of buffer 0 is %u \n",key_parameters[11]);
printf("value of buffer 1 is %u \n",key_parameters[12]);
How odd. You're probably going to have to wait for Catalina 3.0 to be able to definitively identify the keyboard cog. I'll email you a pre-release as soon as I have one that does what you need.
PUB present : truefalse
'' Check if keyboard present - valid ~2s after start
'' returns t|f
truefalse := -par_present
I converted it to this which has an extra line as it is converting an unsigned array variable to a signed value
signed long truefalse;
truefalse = par[2]; // 0 = false. In spin, true is -1. In C it is 1, so ? no negative??
truefalse = -truefalse;
return truefalse;
But - given this is C, should we return 1 instead of -1?
Officially, yes. But in reality anything with the least significant bit set will work as "true".
If in doubt use "if (boolean != 0) ...: instead if "if (boolean) ..." - I do this a lot. It sometimes looks a bit silly, but it is a "safe" way to program when dealing with different languages.
printf("hit a key \n"); // needs the \n
printf("you hit %u \n",key_getkey(key_parameters));
if I leave out the \n then it does not print the "hit a key" until *after* I hit the key. If I put the \n in, then it prints "hit a key" as expected. Is this a C feature?
Ross, there are 8 cogs - one is being used for catalina (2) , one is for the keyboard (0) and one is spare (7). What are the others being used for?
/* PASM keyboard object for use with Catalina compiler */
#include <stdio.h>
''* PS/2 Keyboard Driver v1.0.1 *
''* Copyright (c) 2004 Parallax, Inc. *
''* C version by James Moxham. *
Functions
key_start // start the keyboard
key_startx // start keyboard with lock settings
key_present // test if keyboard present - takes 1-2 seconds to boot
key_key // get a key - never waits
key_getkey // get a key - always waits
key_newkey // restart buffer and get a key
key_gotkey // is there a key in the buffer
key_clearkeys // restart buffer
{-----------------REVISION HISTORY-----------------
v1.0.1 - Updated 6/15/2006 to work with Propeller Tool 0.96}
CON
PUB Main
DAT
'* Assembly language PS/2 keyboard driver *
org
' Entry
entry movd :par,#_dpin 'load input parameters _dpin/_cpin/_locks/_auto
mov x,par
add x,#11*4
mov y,#4
:par rdlong 0,x
add :par,dlsb
add x,#4
djnz y,#:par
mov dmask,#1 'set pin masks
shl dmask,_dpin
mov cmask,#1
shl cmask,_cpin
test _dpin,#$20 wc 'modify port registers within code
muxc _d1,dlsb
muxc _d2,dlsb
muxc _d3,#1
muxc _d4,#1
test _cpin,#$20 wc
muxc _c1,dlsb
muxc _c2,dlsb
muxc _c3,#1
mov _head,#0 'reset output parameter _head
' Reset keyboard
reset mov dira,#0 'reset directions
mov dirb,#0
movd :par,#_present 'reset output parameters _present/_states[8]
mov x,#1+8
:par mov 0,#0
add :par,dlsb
djnz x,#:par
mov stat,#8 'set reset flag
' Update parameters
update movd :par,#_head 'update output parameters _head/_present/_states[8]
mov x,par
add x,#1*4
mov y,#1+1+8
:par wrlong 0,x
add :par,dlsb
add x,#4
djnz y,#:par
test stat,#8 wc 'if reset flag, transmit reset command
if_c mov data,#$FF
if_c call #transmit
' Get scancode
newcode mov stat,#0 'reset state
:same call #receive 'receive byte from keyboard
cmp data,#$83+1 wc 'scancode?
if_nc cmp data,#$AA wz 'powerup/reset?
if_nc_and_z jmp #configure
if_nc cmp data,#$E0 wz 'extended?
if_nc_and_z or stat,#1
if_nc_and_z jmp #:same
if_nc cmp data,#$F0 wz 'released?
if_nc_and_z or stat,#2
if_nc jmp #newcode 'unknown, ignore
' Translate scancode and enter into buffer
test stat,#1 wc 'lookup code with extended flag
rcl data,#1
call #look
cmp data,#0 wz 'if unknown, ignore
if_z jmp #newcode
mov t,_states+6 'remember lock keys in _states
mov x,data 'set/clear key bit in _states
shr x,#5
add x,#_states
movd :reg,x
mov y,#1
shl y,data
test stat,#2 wc
:reg muxnc 0,y
if_nc cmpsub data,#$F0 wc 'if released or shift/ctrl/alt/win, done
if_c jmp #update
mov y,_states+7 'get shift/ctrl/alt/win bit pairs
shr y,#16
cmpsub data,#$E0 wc 'translate keypad, considering numlock
if_c test _locks,#%100 wz
if_c_and_z add data,#@keypad1-@table
if_c_and_nz add data,#@keypad2-@table
if_c call #look
if_c jmp #:flags
cmpsub data,#$DD wc 'handle scrlock/capslock/numlock
if_c mov x,#%001_000
if_c shl x,data
if_c andn x,_locks
if_c shr x,#3
if_c shr t,#29 'ignore auto-repeat
if_c andn x,t wz
if_c xor _locks,x
if_c add data,#$DD
if_c_and_nz or stat,#4 'if change, set configure flag to update leds
test y,#%11 wz 'get shift into nz
if_nz cmp data,#$60+1 wc 'check shift1
if_nz_and_c cmpsub data,#$5B wc
if_nz_and_c add data,#@shift1-@table
if_nz_and_c call #look
if_nz_and_c andn y,#%11
if_nz cmp data,#$3D+1 wc 'check shift2
if_nz_and_c cmpsub data,#$27 wc
if_nz_and_c add data,#@shift2-@table
test _locks,#%010 wc 'check shift-alpha, considering capslock
muxnc :shift,#$20
test _locks,#$40 wc
if_nz_and_nc xor :shift,#$20
cmp data,#"z"+1 wc
if_c cmpsub data,#"a" wc
:shift if_c add data,#"A"
if_c andn y,#%11
:flags ror data,#8 'add shift/ctrl/alt/win flags
mov x,#4 '+$100 if shift
:loop test y,#%11 wz '+$200 if ctrl
shr y,#2 '+$400 if alt
if_nz or data,#1 '+$800 if win
ror data,#1
djnz x,#:loop
rol data,#12
rdlong x,par 'if room in buffer and key valid, enter
sub x,#1
and x,#$F
cmp x,_head wz
if_nz test data,#$FF wz
if_nz mov x,par
if_nz add x,#11*4
if_nz add x,_head
if_nz add x,_head
if_nz wrword data,x
if_nz add _head,#1
if_nz and _head,#$F
test stat,#4 wc 'if not configure flag, done
if_nc jmp #update 'else configure to update leds
' Configure keyboard
configure mov data,#$F3 'set keyboard auto-repeat
call #transmit
mov data,_auto
and data,#%11_11111
call #transmit
mov data,#$ED 'set keyboard lock-leds
call #transmit
mov data,_locks
rev data,#-3 & $1F
test data,#%100 wc
rcl data,#1
and data,#%111
call #transmit
mov x,_locks 'insert locks into _states
and x,#%111
shl _states+7,#3
or _states+7,x
ror _states+7,#3
mov _present,#1 'set _present
jmp #update 'done
' Lookup byte in table
look ror data,#2 'perform lookup
movs :reg,data
add :reg,#table
shr data,#27
mov x,data
:reg mov data,0
shr data,x
jmp #rand 'isolate byte
' Transmit byte to keyboard
transmit
_c1 or dira,cmask 'pull clock low
movs napshr,#13 'hold clock for ~128us (must be >100us)
call #nap
_d1 or dira,dmask 'pull data low
movs napshr,#18 'hold data for ~4us
call #nap
_c2 xor dira,cmask 'release clock
test data,#$0FF wc 'append parity and stop bits to byte
muxnc data,#$100
or data,dlsb
mov x,#10 'ready 10 bits
transmit_bit call #wait_c0 'wait until clock low
shr data,#1 wc 'output data bit
_d2 muxnc dira,dmask
mov wcond,c1 'wait until clock high
call #wait
djnz x,#transmit_bit 'another bit?
mov wcond,c0d0 'wait until clock and data low
call #wait
mov wcond,c1d1 'wait until clock and data high
call #wait
call #receive_ack 'receive ack byte with timed wait
cmp data,#$FA wz 'if ack error, reset keyboard
if_nz jmp #reset
transmit_ret ret
' Receive byte from keyboard
receive test _cpin,#$20 wc 'wait indefinitely for initial clock low
waitpne cmask,cmask
receive_ack
mov x,#11 'ready 11 bits
receive_bit call #wait_c0 'wait until clock low
movs napshr,#16 'pause ~16us
call #nap
_d3 test dmask,ina wc 'input data bit
rcr data,#1
call #wait
djnz x,#receive_bit 'another bit?
shr data,#22 'align byte
test data,#$1FF wc 'if parity error, reset keyboard
if_nc jmp #reset
rand and data,#$FF 'isolate byte
look_ret
receive_ack_ret
receive_ret ret
' Wait for clock/data to be in required state(s)
wait_c0 mov wcond,c0 '(wait until clock low)
wait mov y,tenms 'set timeout to 10ms
wloop movs napshr,#18 'nap ~4us
call #nap
_c3 test cmask,ina wc 'check required state(s)
_d4 test dmask,ina wz 'loop until got state(s) or timeout
wcond if_never djnz y,#wloop '(replaced with c0/c1/c0d0/c1d1)
tjz y,#reset 'if timeout, reset keyboard
wait_ret
wait_c0_ret ret
c0 if_c djnz y,#wloop '(if_never replacements)
c1 if_nc djnz y,#wloop
c0d0 if_c_or_nz djnz y,#wloop
c1d1 if_nc_or_z djnz y,#wloop
' Nap
nap rdlong t,#0 'get clkfreq
napshr shr t,#18/16/13 'shr scales time
min t,#3 'ensure waitcnt won't snag
add t,cnt 'add cnt to time
waitcnt t,#0 'wait until time elapses (nap)
nap_ret ret
' Initialized data
dlsb long 1 << 9
tenms long 10_000 / 4
' Lookup table
' ascii scan extkey regkey ()=keypad
table word $0000 '00
word $00D8 '01 F9
word $0000 '02
word $00D4 '03 F5
word $00D2 '04 F3
word $00D0 '05 F1
word $00D1 '06 F2
word $00DB '07 F12
word $0000 '08
word $00D9 '09 F10
word $00D7 '0A F8
word $00D5 '0B F6
word $00D3 '0C F4
word $0009 '0D Tab
word $0060 '0E `
word $0000 '0F
word $0000 '10
word $F5F4 '11 Alt-R Alt-L
word $00F0 '12 Shift-L
word $0000 '13
word $F3F2 '14 Ctrl-R Ctrl-L
word $0071 '15 q
word $0031 '16 1
word $0000 '17
word $0000 '18
word $0000 '19
word $007A '1A z
word $0073 '1B s
word $0061 '1C a
word $0077 '1D w
word $0032 '1E 2
word $F600 '1F Win-L
word $0000 '20
word $0063 '21 c
word $0078 '22 x
word $0064 '23 d
word $0065 '24 e
word $0034 '25 4
word $0033 '26 3
word $F700 '27 Win-R
word $0000 '28
word $0020 '29 Space
word $0076 '2A v
word $0066 '2B f
word $0074 '2C t
word $0072 '2D r
word $0035 '2E 5
word $CC00 '2F Apps
word $0000 '30
word $006E '31 n
word $0062 '32 b
word $0068 '33 h
word $0067 '34 g
word $0079 '35 y
word $0036 '36 6
word $CD00 '37 Power
word $0000 '38
word $0000 '39
word $006D '3A m
word $006A '3B j
word $0075 '3C u
word $0037 '3D 7
word $0038 '3E 8
word $CE00 '3F Sleep
word $0000 '40
word $002C '41 ,
word $006B '42 k
word $0069 '43 i
word $006F '44 o
word $0030 '45 0
word $0039 '46 9
word $0000 '47
word $0000 '48
word $002E '49 .
word $EF2F '4A (/) /
word $006C '4B l
word $003B '4C ;
word $0070 '4D p
word $002D '4E -
word $0000 '4F
word $0000 '50
word $0000 '51
word $0027 '52 '
word $0000 '53
word $005B '54 [
word $003D '55 =
word $0000 '56
word $0000 '57
word $00DE '58 CapsLock
word $00F1 '59 Shift-R
word $EB0D '5A (Enter) Enter
word $005D '5B ]
word $0000 '5C
word $005C '5D \
word $CF00 '5E WakeUp
word $0000 '5F
word $0000 '60
word $0000 '61
word $0000 '62
word $0000 '63
word $0000 '64
word $0000 '65
word $00C8 '66 BackSpace
word $0000 '67
word $0000 '68
word $C5E1 '69 End (1)
word $0000 '6A
word $C0E4 '6B Left (4)
word $C4E7 '6C Home (7)
word $0000 '6D
word $0000 '6E
word $0000 '6F
word $CAE0 '70 Insert (0)
word $C9EA '71 Delete (.)
word $C3E2 '72 Down (2)
word $00E5 '73 (5)
word $C1E6 '74 Right (6)
word $C2E8 '75 Up (8)
word $00CB '76 Esc
word $00DF '77 NumLock
word $00DA '78 F11
word $00EC '79 (+)
word $C7E3 '7A PageDn (3)
word $00ED '7B (-)
word $DCEE '7C PrScr (*)
word $C6E9 '7D PageUp (9)
word $00DD '7E ScrLock
word $0000 '7F
word $0000 '80
word $0000 '81
word $0000 '82
word $00D6 '83 F7
keypad1 byte $CA, $C5, $C3, $C7, $C0, 0, $C1, $C4, $C2, $C6, $C9, $0D, "+-*", $2F
keypad2 byte "0123456789.", $0D, "+-*",$2F
shift1 byte "{|}", 0, 0, "~"
shift2 byte $22, 0, 0, 0, 0, "<_>?)!@#$%^&*(", 0, ":", 0, "+"
dmask res 1
cmask res 1
stat res 1
data res 1
x res 1
y res 1
t res 1
_head res 1 'write-only
_present res 1 'write-only
_states res 8 'write-only
_dpin res 1 'read-only at start
_cpin res 1 'read-only at start
_locks res 1 'read-only at start
_auto res 1 'read-only at start
'' _________
'' Key Codes
'' 00..DF = keypress and keystate
'' E0..FF = keystate only
'' 09 Tab
'' 0D Enter
'' 20 Space
'' 21 !
'' 22 "
'' 23 #
'' 24 $
'' 25 %
'' 26 &
'' 27 '
'' 28 (
'' 29 )
'' 2A *
'' 2B +
'' 2C ,
'' 2D -
'' 2E .
'' 2F /
'' 30 0..9
'' 3A :
'' 3B ;
'' 3C <
'' 3D =
'' 3E >
'' 3F ?
'' 40 @
'' 41..5A A..Z
'' 5B [
'' 5C \
'' 5D ]
'' 5E ^
'' 5F _
'' 60 `
'' 61..7A a..z
'' 7B {
'' 7C |
'' 7D }
'' 7E ~
'' 80-BF (future international character support)
'' C0 Left Arrow
'' C1 Right Arrow
'' C2 Up Arrow
'' C3 Down Arrow
'' C4 Home
'' C5 End
'' C6 Page Up
'' C7 Page Down
'' C8 Backspace
'' C9 Delete
'' CA Insert
'' CB Esc
'' CC Apps
'' CD Power
'' CE Sleep
'' CF Wakeup
'' D0..DB F1..F12
'' DC Print Screen
'' DD Scroll Lock
'' DE Caps Lock
'' DF Num Lock
'' E0..E9 Keypad 0..9
'' EA Keypad .
'' EB Keypad Enter
'' EC Keypad +
'' ED Keypad -
'' EE Keypad *
'' EF Keypad /
'' F0 Left Shift
'' F1 Right Shift
'' F2 Left Ctrl
'' F3 Right Ctrl
'' F4 Left Alt
'' F5 Right Alt
'' F6 Left Win
'' F7 Right Win
'' FD Scroll Lock State
'' FE Caps Lock State
'' FF Num Lock State
'' +100 if Shift
'' +200 if Ctrl
'' +400 if Alt
'' +800 if Win
'' eg. Ctrl-Alt-Delete = $6C9
'' Note: Driver will buffer up to 15 keystrokes, then ignore overflow.
PASM End
? TERMS OF USE: MIT License ?
?Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation ?
?files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, ?
?modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software?
?is furnished to do so, subject to the following conditions: ?
?The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.?
?THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE ?
?WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR ?
?COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ?
?ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. ?
unsigned long key_cog[511] =
0x54fc093d, 0xa0be61f0, 0x80fe602c, 0xa0fe6204,
0x08bc0130, 0x80bc08d8, 0x80fe6004, 0xe4fe6204,
0xa0fe5801, 0x2cbe593d, 0xa0fe5a01, 0x2cbe5b3e,
0x617e7a20, 0x70bd3ed8, 0x70bd52d8, 0x70fd7601,
0x70fd9401, 0x617e7c20, 0x70bd38d8, 0x70bd44d8,
0x70fd9201, 0xa0fe6600, 0xa0ffec00, 0xa0ffee00,
0x54fc3534, 0xa0fe6009, 0xa0fc0000, 0x80bc34d8,
0xe4fe601a, 0xa0fe5c08, 0x54fc4533, 0xa0be61f0,
0x80fe6004, 0xa0fe620a, 0x083c0130, 0x80bc44d8,
0x80fe6004, 0xe4fe6222, 0x617e5c08, 0xa0f25eff,
0x5cf1689c, 0xa0fe5c00, 0x5cfd88b5, 0x857e5e84,
0x864e5eaa, 0x5c480080, 0x864e5ee0, 0x68ca5c01,
0x5c48002a, 0x864e5ef0, 0x68ca5c02, 0x5c48002a,
0x5c4c0029, 0x617e5c01, 0x34fe5e01, 0x5cfd8894,
0x867e5e00, 0x5c680029, 0xa0be653b, 0xa0be612f,
0x28fe6005, 0x80fe6135, 0x54bc8530, 0xa0fe6201,
0x2cbe632f, 0x617e5c02, 0x74bc0131, 0xe1ce5ef0,
0x5c70001e, 0xa0be633c, 0x28fe6210, 0xe1fe5ee0,
0x62727e04, 0x80e25f08, 0x80d25f18, 0x5cf18894,
0x5c70006a, 0xe1fe5edd, 0xa0f26008, 0x2cb2612f,
0x64b2613f, 0x28f26003, 0x28f2641d, 0x66b26132,
0x6cb27f30, 0x80f25edd, 0x68d25c04, 0x627e6203,
0x85565e61, 0xe1d25e5b, 0x80d25f28, 0x5cd18894,
0x64d26203, 0x85565e3e, 0xe1d25e27, 0x80d25f2e,
0x5cd18894, 0x64d26203, 0x617e7e02, 0x74fcd020,
0x617e7e40, 0x6cc4d020, 0x857e5e7b, 0xe1f25e61,
0x80f25e41, 0x64f26203, 0x20fe5e08, 0xa0fe6004,
0x627e6203, 0x28fe6202, 0x68d65e01, 0x20fe5e01,
0xe4fe606c, 0x24fe5e0c, 0x08be61f0, 0x84fe6001,
0x60fe600f, 0x863e6133, 0x62565eff, 0xa09661f0,
0x80d6602c, 0x80966133, 0x80966133, 0x04165f30,
0x80d66601, 0x60d6660f, 0x617e5c04, 0x5c4c001e,
0xa0fe5ef3, 0x5cfd689c, 0xa0be5f40, 0x60fe5e7f,
0x5cfd689c, 0xa0fe5eed, 0x5cfd689c, 0xa0be5f3f,
0x3cfe5e1d, 0x617e5e04, 0x34fe5e01, 0x60fe5e07,
0x5cfd689c, 0xa0be613f, 0x60fe6007, 0x2cfe7803,
0x68be7930, 0x20fe7803, 0xa0fe6801, 0x5c7c001e,
0x20fe5e02, 0x50bd332f, 0x80fd32da, 0x28fe5e1b,
0xa0be612f, 0xa0be5e00, 0x28be5f30, 0x5c7c00c3,
0x68bfed2d, 0x50fda60d, 0x5cfdaed2, 0x68bfed2c,
0x50fda612, 0x5cfdaed2, 0x6cbfed2d, 0x617e5eff,
0x74fe5f00, 0x68be5ed8, 0xa0fe600a, 0x5cfd9ac5,
0x29fe5e01, 0x74bfed2c, 0xa0bd96cf, 0x5cfd9ac6,
0xe4fe60a7, 0xa0bd96d0, 0x5cfd9ac6, 0xa0bd96d1,
0x5cfd9ac6, 0x5cfd88b7, 0x867e5efa, 0x5c540016,
0x5c7c0000, 0x617e7c20, 0xf43e5b2d, 0xa0fe600b,
0x5cfd9ac5, 0x50fda610, 0x5cfdaed2, 0x613e59f2,
0x30fe5e01, 0xa0bd96cf, 0x5cfd9ac6, 0xe4fe60b8,
0x28fe5e16, 0x617e5fff, 0x5c4c0016, 0x60fe5eff,
0x5c7c0000, 0xa0bd96ce, 0xa0be62d9, 0x50fda612,
0x5cfdaed2, 0x613e5bf2, 0x623e59f2, 0xe4c262c7,
0xec7e6216, 0x5c7c0000, 0xe4f262c7, 0xe4ce62c7,
0xe4f662c7, 0xe4ee62c7, 0x08fe6400, 0x28fe6400,
0x48fe6403, 0x80be65f1, 0xf8fe6400, 0x5c7c0000,
0x00000200, 0x000009c4, 0x00d80000, 0x00d40000,
0x00d000d2, 0x00db00d1, 0x00d90000, 0x00d500d7,
0x000900d3, 0x00000060, 0xf5f40000, 0x000000f0,
0x0071f3f2, 0x00000031, 0x00000000, 0x0073007a,
0x00770061, 0xf6000032, 0x00630000, 0x00640078,
0x00340065, 0xf7000033, 0x00200000, 0x00660076,
0x00720074, 0xcc000035, 0x006e0000, 0x00680062,
0x00790067, 0xcd000036, 0x00000000, 0x006a006d,
0x00370075, 0xce000038, 0x002c0000, 0x0069006b,
0x0030006f, 0x00000039, 0x002e0000, 0x006cef2f,
0x0070003b, 0x0000002d, 0x00000000, 0x00000027,
0x003d005b, 0x00000000, 0x00f100de, 0x005deb0d,
0x005c0000, 0x0000cf00, 0x00000000, 0x00000000,
0x00000000, 0x000000c8, 0xc5e10000, 0xc0e40000,
0x0000c4e7, 0x00000000, 0xc9eacae0, 0x00e5c3e2,
0xc2e8c1e6, 0x00df00cb, 0x00ec00da, 0x00edc7e3,
0xc6e9dcee, 0x000000dd, 0x00000000, 0x00d60000,
0xc7c3c5ca, 0xc4c100c0, 0x0dc9c6c2, 0x2f2a2d2b,
0x33323130, 0x37363534, 0x0d2e3938, 0x2f2a2d2b,
0x007d7c7b, 0x00227e00, 0x3c000000, 0x293f3e5f,
0x24234021, 0x2a265e25, 0x003a0028, 0x0000002b
int i;
for (i=0;i<40;i++)
int i;
for(i=0;i<512;i++)
unsigned long key_startx(unsigned long dpin,unsigned long cpin, unsigned long keylocks, unsigned long keyauto, int cognumber, unsigned long par[], unsigned long cogdata[])
PUB startx(dpin, cpin, locks, auto) : okay
'' Like start, but allows you to specify lock settings and auto-repeat
'' locks = lock setup
'' bit 6 disallows shift-alphas (case set soley by CapsLock)
'' bits 5..3 disallow toggle of NumLock/CapsLock/ScrollLock state
'' bits 2..0 specify initial state of NumLock/CapsLock/ScrollLock
'' (eg. %0_001_100 = disallow ScrollLock, NumLock initially 'on')
'' auto = auto-repeat setup
'' bits 6..5 specify delay (0=.25s, 1=.5s, 2=.75s, 3=1s)
'' bits 4..0 specify repeat rate (0=30cps..31=2cps)
'' (eg %01_00000 = .5s delay, 30cps repeat)
stop
longmove(@par_keys, @dpin, 4)
okay := cog := cognew(@entry, @par_tail) + 1
unsigned long okay;
par[11] = dpin; // longmove(@par_keys, @dpin, 4)
par[12] = cpin; // move 4 bytes into array, replaces the longmove
par[13] = keylocks;
par[14] = keyauto;
external_memory_cog_load(cognumber,cogdata,par); // load from external ram
return okay;
unsigned long key_start(unsigned long dpin,unsigned long cpin, int cognumber, unsigned long par[], unsigned long cogdata[])
VAR
long cog
long par_tail 'key buffer tail read/write (19 contiguous longs)
long par_head 'key buffer head read-only
long par_present 'keyboard present read-only
long par_states[8] 'key states (256 bits) read-only
long par_keys[8] 'key buffer (16 words) read-only (also used to pass initial parameters)
PUB start(dpin, cpin) : okay
'' Start keyboard driver - starts a cog
'' dpin = data signal on PS/2 jack
'' cpin = clock signal on PS/2 jack
'' use 100-ohm resistors between pins and jack
'' use 10K-ohm resistors to pull jack-side signals to VDD
'' connect jack-power to 5V, jack-gnd to VSS
'' all lock-keys will be enabled, NumLock will be initially 'on',
'' and auto-repeat will be set to 15cps with a delay of .5s
okay := startx(dpin, cpin, %0_000_100, %01_01000)
unsigned long okay;
par[0] = 0; // par_tail
par[1] = 0; // par_head
par[2] = 0; // par_present
key_startx(dpin, cpin, 0x4, 0x28, cognumber, par, cogdata); // okay := startx(dpin, cpin, %0_000_100, %01_01000)
return okay;
unsigned long key_present(unsigned long par[])
'' returns t|f
return truefalse;
unsigned long key_key(unsigned long par[]) // returns keycode, never waits, 0 if nothing
PUB key : keycode
'' Get key (never waits)
'' returns key (0 if buffer empty)
if par_tail <> par_head
keycode := par_keys.word[par_tail]
par_tail := ++par_tail & $F
unsigned long keycode = 0;
int address;
if (par[0] != par[1]) // if par_tail <> par_head
buffer_ptr = par[0] + par[0]; // increments in words, not bytes
buffer_ptr += (unsigned long)&par[11]; // pointer to start of buffer
address = buffer_ptr; // convert to integer
keycode = peek(address); // get the key code by peeking it
par[0] = (par[0] +1) & 0xF; // add one to tail
// printf("keycode %c address = %i tail %u \n",keycode,address,par[0]);
return keycode;
unsigned long key_getkey(unsigned long par[])
PUB getkey : keycode
'' Get next key (may wait for keypress)
'' returns key
repeat until (keycode := key)
unsigned long keycode;
while ((keycode = key_key(par)) == 0) {} // keep checking while returns 0
return keycode;
unsigned long key_newkey(unsigned long par[]) // clear buffer and get new key
PUB newkey : keycode
'' Clear buffer and get new key (always waits for keypress)
'' returns key
par_tail := par_head
keycode := getkey
par[0] = par[1]; // par_tail := par_head
return key_getkey(par); // get the keypress (waits)
unsigned long key_gotkey(unsigned long par[]) // check if any key in buffer
PUB gotkey : truefalse
'' Check if any key in buffer
'' returns t|f
truefalse := par_tail <> par_head
unsigned long truefalse = 0; // 0 is false
if (par[0] == par[1])
truefalse = 0xFFFFFFFF; // -1 is true
return truefalse;
void key_clearkeys(unsigned long par[])
PUB clearkeys
'' Clear key buffer
void key_demo(unsigned long key_parameters[]) // demonstrate the keyboard cog code
char name[11]; // input string
int i;
int j;
unsigned long k;
clearscreen(); // clear the screen and white on blue
_cogstop(0); // keyboard is in cog 0
key_start(26,27,7,key_parameters,key_cog); // start in cog 7
sleep(1000); // delay to start up the keyboard
// printf("Keyboard not present =0, present = -1 (or 1) %d \n",key_present(key_parameters));
// printf("hit a key \n"); // needs the \n
// printf("you hit %u \n",key_getkey(key_parameters)); // test getkey
// printf("hit another key \n");
// printf("you hit %u \n",key_newkey(key_parameters)); // test newkey
printf("hit some keys (20 keypresses) \n");
for (i=0;i<20;i++)
k = key_getkey(key_parameters);
printf("key %c with ascii value %u \n",k,k);
// printf("head %u tail %u \n",key_parameters[1],key_parameters[0]);
void main ()
unsigned long key_parameters[18]; // reserve hub space in main for buffer, head tail pointers
key_demo(key_parameters); // demo routines
Dr_A,
You'd have to send me your exact compilation command for me to tell. A mouse? An SD card plugin? One or more floating point plugins? Perhaps a clock? Also, some of the Hi Res VGA drivers actually take two cogs, not one (the Morpheus VGA driver takes three!).
The only extra cog I can be use of is that at least one is being used for the HMI plugin itself, which adds functionality to the various underlying device drivers. You've probably never realized it, but Catalina adds a visible flashing cursor to all video drivers - even the ones that don't natively support such a thing. The HMI plugin adds a heap of functionality like that to the various native keyboard, mouse and screen drivers.
I would guess you are compiling with the -lcx library, which buffers all I/O. Recompile your program with -lc and you may see slightly different behaviour. You could probably also call fflush() to force a write. I would have to try this to be sure - but this is quite acceptable C behaviour.
I've just emailed you both an updated 3.0 pre-release which fixes the cache problem. It should speed up performance by a factor of two or more.
Ross.
Hi Ross,
Thanks for the update! I tried this new version and it was not noticably faster at running my xbasic test program. The old version of Catalina using the -x3 memory layout took 12 seconds and this version took 11 seconds. That could easily be explained by errors in pushing the stopwatch button on my watch. In any case, it's good to have the cache bug fixed since I'm sure it could have caused problems.
Works for me. Did you remember to recompile the utilities folder with the new cache size?
Ross.
Yes. "build_all C3 CACHED_2K"?
Ross.
Ross.
David (& Jazzed)
I'll see about fixing it if I get time tomorrow.
Ross.
PUB dec(value) | i '' Print a decimal number if value < 0 -value tx("-") i := 1_000_000_000 repeat 10 if value => i tx(value / i + "0") value //= i result~~ elseif result or i == 1 tx("0") i /= 10becomes
void serial_dec(unsigned long value,unsigned long par[]) // send out decimal value - unsigned { char lineoftext[11] = ""; // enough room for a 32 bit long 2^32 sprintf(lineoftext, "%u", value); // convert to a string serial_str(lineoftext,par); // send out the string }The startup cog code is in an array, and you can either leave it as it is, or overwrite it with a .cog file.
void serial_tx(char tx,unsigned long par[]) { /* PUB tx(txbyte) '' Send byte (may wait for room in buffer) repeat until (tx_tail <> (tx_head + 1) & $F) tx_buffer[tx_head] := txbyte tx_head := (tx_head + 1) & $F if rxtx_mode & %1000 rx */ unsigned long tx_head; int address; while ( par[3] == (par[2] + 1 ) & 0xF) { // par[2] is tx_head, par[3] is tx_tail sleep(100); // small delay to send out some bytes, should only happen with slow baud rates // printf("head is one less than the tail, buffer full"); } poke(address,tx); // poke the tx byte value to hub ram tx_head = par[2]; // get the head value address = par[8] + 16 + tx_head; // location of rx buffer plus 16 to get tx buffer plus the head value poke(address,tx); // poke the tx byte value to hub ram tx_head = tx_head + 1; // add one tx_head = tx_head & 0xF; // logical and with 15 par[2] = tx_head; // store it back again // need to add the echo mode? }I now need to think about the "merging" of multiple cogjects - eg things like multiple entries for "stdio", multiple copies of functions (like the cog loader) and other include files, and merging things into the "main" function. I might see if I can find another object to work on...
/* PASM demo for use with Catalina IDE Precompiler and Compiler */ #include <stdio.h> // PASM blocks of code and associated arrays /* PASM Code for compilation using SpinC and inclusion as a data file PASM Start serial.spin CON ' add your values here _clkfreq = 80_000_000 ' 5Mhz Crystal _clkmode = xtal1 + pll16x ' x 16 ' Start of C hub constants ' End of C constants PUB Main coginit(1,@entry,0) ' cog 1, cogstart, dummy value DAT '*********************************** '* Assembly language serial driver * '*********************************** org ' ' ' Entry ' entry mov t1,par 'get structure address add t1,#4 << 2 'skip past heads and tails rdlong t2,t1 'get rx_pin mov rxmask,#1 shl rxmask,t2 add t1,#4 'get tx_pin rdlong t2,t1 mov txmask,#1 shl txmask,t2 add t1,#4 'get rxtx_mode rdlong rxtxmode,t1 add t1,#4 'get bit_ticks rdlong bitticks,t1 add t1,#4 'get buffer_ptr rdlong rxbuff,t1 mov txbuff,rxbuff add txbuff,#16 test rxtxmode,#%100 wz 'init tx pin according to mode test rxtxmode,#%010 wc if_z_ne_c or outa,txmask if_z or dira,txmask mov txcode,#transmit 'initialize ping-pong multitasking ' ' ' Receive ' receive jmpret rxcode,txcode 'run a chunk of transmit code, then return test rxtxmode,#%001 wz 'wait for start bit on rx pin test rxmask,ina wc if_z_eq_c jmp #receive mov rxbits,#9 'ready to receive byte mov rxcnt,bitticks shr rxcnt,#1 add rxcnt,cnt :bit add rxcnt,bitticks 'ready next bit period :wait jmpret rxcode,txcode 'run a chuck of transmit code, then return mov t1,rxcnt 'check if bit receive period done sub t1,cnt cmps t1,#0 wc if_nc jmp #:wait test rxmask,ina wc 'receive bit on rx pin rcr rxdata,#1 djnz rxbits,#:bit shr rxdata,#32-9 'justify and trim received byte and rxdata,#$FF test rxtxmode,#%001 wz 'if rx inverted, invert byte if_nz xor rxdata,#$FF rdlong t2,par 'save received byte and inc head add t2,rxbuff wrbyte rxdata,t2 sub t2,rxbuff add t2,#1 and t2,#$0F wrlong t2,par jmp #receive 'byte done, receive next byte ' ' ' Transmit ' transmit jmpret txcode,rxcode 'run a chunk of receive code, then return mov t1,par 'check for head <> tail add t1,#2 << 2 rdlong t2,t1 add t1,#1 << 2 rdlong t3,t1 cmp t2,t3 wz if_z jmp #transmit add t3,txbuff 'get byte and inc tail rdbyte txdata,t3 sub t3,txbuff add t3,#1 and t3,#$0F wrlong t3,t1 or txdata,#$100 'ready byte to transmit shl txdata,#2 or txdata,#1 mov txbits,#11 mov txcnt,cnt :bit test rxtxmode,#%100 wz 'output bit on tx pin according to mode test rxtxmode,#%010 wc if_z_and_c xor txdata,#1 shr txdata,#1 wc if_z muxc outa,txmask if_nz muxnc dira,txmask add txcnt,bitticks 'ready next cnt :wait jmpret txcode,rxcode 'run a chunk of receive code, then return mov t1,txcnt 'check if bit transmit period done sub t1,cnt cmps t1,#0 wc if_nc jmp #:wait djnz txbits,#:bit 'another bit to transmit? jmp #transmit 'byte done, transmit next byte ' ' ' Uninitialized data ' t1 res 1 t2 res 1 t3 res 1 rxtxmode res 1 bitticks res 1 rxmask res 1 rxbuff res 1 rxdata res 1 rxbits res 1 rxcnt res 1 rxcode res 1 txmask res 1 txbuff res 1 txdata res 1 txbits res 1 txcnt res 1 txcode res 1 PASM End */ unsigned long serial_cog[511] = { 0xa0bca9f0, 0x80fca810, 0x08bcaa54, 0xa0fcb201, 0x2cbcb255, 0x80fca804, 0x08bcaa54, 0xa0fcbe01, 0x2cbcbe55, 0x80fca804, 0x08bcae54, 0x80fca804, 0x08bcb054, 0x80fca804, 0x08bcb454, 0xa0bcc05a, 0x80fcc010, 0x627cae04, 0x617cae02, 0x689be85f, 0x68abec5f, 0xa0fcc833, 0x5cbcbc64, 0x627cae01, 0x613cb3f2, 0x5c640016, 0xa0fcb809, 0xa0bcba58, 0x28fcba01, 0x80bcbbf1, 0x80bcba58, 0x5cbcbc64, 0xa0bca85d, 0x84bca9f1, 0xc17ca800, 0x5c4c001f, 0x613cb3f2, 0x30fcb601, 0xe4fcb81e, 0x28fcb617, 0x60fcb6ff, 0x627cae01, 0x6cd4b6ff, 0x08bcabf0, 0x80bcaa5a, 0x003cb655, 0x84bcaa5a, 0x80fcaa01, 0x60fcaa0f, 0x083cabf0, 0x5c7c0016, 0x5cbcc85e, 0xa0bca9f0, 0x80fca808, 0x08bcaa54, 0x80fca804, 0x08bcac54, 0x863caa56, 0x5c680033, 0x80bcac60, 0x00bcc256, 0x84bcac60, 0x80fcac01, 0x60fcac0f, 0x083cac54, 0x68fcc300, 0x2cfcc202, 0x68fcc201, 0xa0fcc40b, 0xa0bcc7f1, 0x627cae04, 0x617cae02, 0x6ce0c201, 0x29fcc201, 0x70abe85f, 0x7497ec5f, 0x80bcc658, 0x5cbcc85e, 0xa0bca863, 0x84bca9f1, 0xc17ca800, 0x5c4c004d, 0xe4fcc446, 0x5c7c0033 }; // start of C functions void external_cog_load(int cognumber, unsigned long cogdata[], unsigned long *parameters_array) // load a cog from external memory { unsigned long hubcog[511]; // create a local array, this is in hub ram, not external ram int i; for(i=0;i<512;i++) { hubcog[i]=cogdata[i]; // move from external memory to a local array in hub } _coginit((int)parameters_array>>2, (int)hubcog>>2, cognumber); // load the cog } void clearscreen() // white text on dark blue background { int i; for (i=0;i<40;i++) { t_setpos(0,0,i); // move cursor to next line t_color(0,0x08FC); // RRGGBBxx eg dark blue background 00001000 white text 11111100 } } void sleep(int milliseconds) // sleep function { _waitcnt(_cnt()+(milliseconds*(_clockfreq()/1000))-4296); } char peek(int address) // function implementation of peek { return *((char *)address); } void poke(int address, char value) // function implementation of poke { *((char *)address) = value; } unsigned long serial_start(unsigned long rxpin,unsigned long txpin,unsigned long mode, unsigned long baudrate, unsigned long par[], unsigned long cogdata[]) { /* PUB start(rxpin, txpin, mode, baudrate) : okay '' Start serial driver - starts a cog '' returns false if no cog available '' '' mode bit 0 = invert rx '' mode bit 1 = invert tx '' mode bit 2 = open-drain/source tx '' mode bit 3 = ignore tx echo on rx stop longfill(@rx_head, 0, 4) longmove(@rx_pin, @rxpin, 3) bit_ticks := clkfreq / baudrate buffer_ptr := @rx_buffer okay := cog := cognew(@entry, @rx_head) + 1 */ unsigned long okay; unsigned long bit_ticks; unsigned long buffer_ptr; par[0] = 0; // rx_head longfill(@rx_head, 0, 4) par[1] = 0; // rx_tail par[2] = 0; // tx_head par[3] = 0; // tx_tail par[4] = rxpin; // longmove(@rx_pin, @rxpin, 3) par[5] = txpin; // note - if rewrite the pasm code could save a couple of hub longs here par[6] = mode; // as rxpin and txpin are not used anywhere else bit_ticks = _clockfreq() / baudrate; // bit_ticks := clkfreq / baudrate par[7] = bit_ticks; buffer_ptr = (unsigned long)&par[9]; // buffer_ptr := @rx_buffer points to start of circular buffer par[8] = buffer_ptr; // pointer to the start of the circular buffers // rx buffer is 9 to 12 and tx buffer is 13 to 16 (16 bytes =4 longs) external_cog_load(7,cogdata,par); // load from external ram // okay returns the cog number or -1 if a fail page 119 manual. Ignored here printf("par array is at %u \n",(unsigned long)&par[0]); printf("par array entry 1 is at %u \n",(unsigned long)&par[1]); printf("par array entry 7 is at %u \n",(unsigned long)&par[7]); printf("rx_head is at %u \n",(unsigned long)&par[9]); printf("buffer_ptr is %u \n",par[8]); return okay; } void serial_tx(char tx,unsigned long par[]) { /* PUB tx(txbyte) '' Send byte (may wait for room in buffer) repeat until (tx_tail <> (tx_head + 1) & $F) tx_buffer[tx_head] := txbyte tx_head := (tx_head + 1) & $F if rxtx_mode & %1000 rx */ unsigned long tx_head; int address; while ( par[3] == (par[2] + 1 ) & 0xF) { // par[2] is tx_head, par[3] is tx_tail sleep(100); // small delay to send out some bytes, should only happen with slow baud rates // printf("head is one less than the tail, buffer full"); } poke(address,tx); // poke the tx byte value to hub ram tx_head = par[2]; // get the head value address = par[8] + 16 + tx_head; // location of rx buffer plus 16 to get tx buffer plus the head value poke(address,tx); // poke the tx byte value to hub ram tx_head = tx_head + 1; // add one tx_head = tx_head & 0xF; // logical and with 15 par[2] = tx_head; // store it back again // need to add the echo mode? } unsigned long serial_rxcheck(unsigned long par[]) { /* PUB rxcheck : rxbyte '' Check if byte received (never waits) '' returns -1 if no byte received, $00..$FF if byte rxbyte-- if rx_tail <> rx_head rxbyte := rx_buffer[rx_tail] rx_tail := (rx_tail + 1) & $F */ unsigned long rxbyte; // actually is a long, so can return -1 FFFFFFFF if nothing and 0-FF if a byte int address; // hub address rxbyte = 0; // set explicitly to zero rxbyte = rxbyte - 1; // return ffffffff if nothing if (par[1] != par[0]) { address = par[8] + par[1]; // par[8] is the rx buffer, par[1] is rx_tail rxbyte = peek(address); // get the return byte from the buffer par[1] = (par[1] +1) & 0xF; // add one to tail } return rxbyte; } unsigned long serial_rx(unsigned long par[]) { /* PUB rx : rxbyte '' Receive byte (may wait for byte) '' returns $00..$FF repeat while (rxbyte := rxcheck) < 0 */ unsigned long rxbyte; // actually is a long, not a byte while ((rxbyte = serial_rxcheck(par)) == -1) {} // 0xffffffff and -1 works, but " < 0" gives a compiler error return rxbyte; // return the value } void serial_rxflush(unsigned long par[]) // flush receive buffer { while (serial_rxcheck(par) != -1) {} // keep checking until buffer clear } unsigned long serial_rxtime(unsigned long ms,unsigned long par[]) // wait ms milliseconds for byte, -1 if nothing { unsigned long rxbyte = -1; unsigned long counter = 0; // start a counter, 10ms ticks ms = ms / 10; // internal delay for 1ms ticks is too high while (((rxbyte = serial_rxcheck(par)) == -1) & (counter < ms)) // wait until a byte or counter times out { _waitcnt(_cnt()+(10*(_clockfreq()/1000))-4296); // wait 10 milliseconds counter +=1; // add one to counter } return rxbyte; } void serial_str(char lineoftext[],unsigned long par[]) // send out the string { /* '' Send string repeat strsize(stringptr) tx(byte[stringptr++]) */ int i; for(i=0; i<strlen(lineoftext);i++) { serial_tx(lineoftext[i],par); // send out the bytes one at a time } } void serial_dec(unsigned long value,unsigned long par[]) // send out decimal value - unsigned { /* '' Print a decimal number if value < 0 -value tx("-") i := 1_000_000_000 repeat 10 if value => i tx(value / i + "0") value //= i result~~ elseif result or i == 1 tx("0") i /= 10 */ char lineoftext[11] = ""; // enough room for a 32 bit long 2^32 sprintf(lineoftext, "%u", value); // convert to a string // printf ("lineoftext is now: %s\n", lineoftext); serial_str(lineoftext,par); // send out the string } void serial_hex(unsigned long value, unsigned long par[]) // send out a hex value /* '' Print a hexadecimal number value <<= (8 - digits) << 2 repeat digits tx(lookupz((value <-= 4) & $F : "0".."9", "A".."F")) */ { char lineoftext[8] = ""; // enough room for FFFFFFFF sprintf(lineoftext,"%x",value); // convert to hex value serial_str(lineoftext,par); // send it out } void serial_crlf(unsigned long par[]) // send a crlf { serial_tx(13,par); // cr serial_tx(10,par); // lf } int EoF (FILE* stream) { register int c, status = ((c = fgetc(stream)) == EOF); ungetc(c,stream); return status; } void readcog(char *filename,unsigned long external_cog[]) // read in a .cog file into external memory array { int i; FILE *FP1; i = 0; if((FP1=fopen(filename,"rb"))==0) // open the file { fprintf(stderr,"Can't open file %s\n",filename); exit(1); } fseek(FP1,0,0); while(!EoF(FP1) & (i<511)) // run until end of file { external_cog[i] = getc(FP1) | (getc(FP1)<<8) | (getc(FP1)<<16) | (getc(FP1)<<24); // get the long // printf("%u ",external_cog[i]); i+=1; } if(FP1) { fclose(FP1); // close the file FP1=NULL; } printf("external array cog 0 = %u \n",external_cog[0]); } void main () { int i; char lineoftext[80]; // for string testing unsigned long received_byte; // actually a long, not a byte unsigned long serial_parameters[16]; // reserve hub space for buffer, head tail pointers clearscreen(); // white on blue vga printf("Clock speed %u \n",_clockfreq()); // see page 28 of the propeller manual for other useful commands printf("Catalina running in cog number %i \n",_cogid()); // integer printf("internal array cog 0 = %u \n",serial_cog[0]); readcog("serial.cog",serial_cog); // read in serial.cog to external memory overwrites existing data serial_start(31,30,0,1200,serial_parameters,serial_cog); // start serial cog pins 31,30, mode 0, 1200 baud printf("Started serial driver\n"); for(i=0; i<10; i++) { serial_tx(65+i,serial_parameters); // test sending a byte 10x (delay for starting a serial terminal program) sleep(500); printf("send byte %u \n",65+i); } strcpy(lineoftext,"This is a really long string test with a slow baud rate to check buffer overruns"); // store a string serial_str(lineoftext,serial_parameters); // send it out serial_crlf(serial_parameters); serial_dec(102030405,serial_parameters); // send out a big decimal number serial_crlf(serial_parameters); serial_str("Hex value is ",serial_parameters); serial_hex(102030405,serial_parameters); // send out a hex value serial_crlf(serial_parameters); serial_rxflush(serial_parameters); // flush the receive buffer printf("Type a character within the next 3 seconds \n"); // test the timeout received_byte = serial_rxtime(3000,serial_parameters); // get a byte with a timeout printf("character was ascii %u \n",received_byte); printf("type some characters, will return that character plus 1 \n"); for (i=0;i<19;i++) // test 19 times, so tests buffer restarting { received_byte = serial_rx(serial_parameters); // get a byte serial_tx(received_byte,serial_parameters); // echo it back printf("sent back byte %u \n",received_byte); } printf("program finished \n"); while (1); // Prop reboots on exit from main() }Is that something easy to do?
void serial_dec([COLOR="red"]signed[/COLOR] long value,unsigned long par[]) { char lineoftext[[COLOR="red"]12[/COLOR]]; // 10 digits, sign, terminator sprintf(lineoftext, "%[COLOR="red"]d[/COLOR]", value); serial_str(lineoftext,par); }Regarding your tx issue, this may be related to compiler optimisations (volatile variables). You also have two poke calls in there, one with an uninitialised address.void serial_tx(char tx,unsigned long par[]) { /* PUB tx(txbyte) '' Send byte (may wait for room in buffer) repeat until (tx_tail <> (tx_head + 1) & $F) tx_buffer[tx_head] := txbyte tx_head := (tx_head + 1) & $F if rxtx_mode & %1000 rx */ unsigned long tx_head; int address; while ( par[3] == (par[2] + 1 ) & 0xF) { // par[2] is tx_head, par[3] is tx_tail sleep(100); // small delay to send out some bytes, should only happen with slow baud rates // printf("head is one less than the tail, buffer full"); } [COLOR="red"]poke(address,tx); // poke the tx byte value to hub ram[/COLOR] tx_head = par[2]; // get the head value address = par[8] + 16 + tx_head; // location of rx buffer plus 16 to get tx buffer plus the head value poke(address,tx); // poke the tx byte value to hub ram tx_head = tx_head + 1; // add one tx_head = tx_head & 0xF; // logical and with 15 par[2] = tx_head; // store it back again // need to add the echo mode? }With the compiler I use at work this will give the desired affect, as to whether Catalina supports it is a question for Ross (you could also try yourself).1) printing negative numbers now
/* PASM serial demo for use with Catalina compiler */ #include <stdio.h> /* PASM Code - use Homespun and SPINC to create a .h file.The Catalina vb.net IDE can also create a .cog file for the sd card Make the array an unsigned long with 511 longs Put the array before any functions so it ends up in external memory (arrays within functions end up in hub memory) A logical place for the array if there are multiple blocks of pasm code is to place it underneath the pasm code ''*************************************** ''* Full-Duplex Serial Driver v1.1 * ''* Author: Chip Gracey * ''* Copyright (c) 2006 Parallax, Inc. * ''* See end of file for terms of use. * ''* C version by James Moxham * ''*************************************** Functions: serial_start // start the serial driver serial_tx // send a byte serial_rx // receive a byte serial_rxcheck // check if any bytes present serial_rxflush // flush the receiver buffer serial_rxtime // check for a byte, time out after n milliseconds serial_dec // send out number as a decimal number serial_hex // send out number as a hex number serial_str // send out a string serial_crlf // send a carriage return and line feed readcog // read a .cog file from the sd card to external memory PASM Start - put 'PASM Start' at the beginning so that the color highlighter knows to highlight the CON PUB DAT. Put 'PASM End' at the end CON ' add your values here _clkfreq = 80_000_000 ' 5Mhz Crystal _clkmode = xtal1 + pll16x ' x 16 ' Start of C hub constants ' End of C constants PUB Main coginit(1,@entry,0) ' cog 1, cogstart, dummy value DAT '*********************************** '* Assembly language serial driver * '*********************************** org ' ' ' Entry ' entry mov t1,par 'get structure address add t1,#4 << 2 'skip past heads and tails rdlong t2,t1 'get rx_pin mov rxmask,#1 shl rxmask,t2 add t1,#4 'get tx_pin rdlong t2,t1 mov txmask,#1 shl txmask,t2 add t1,#4 'get rxtx_mode rdlong rxtxmode,t1 add t1,#4 'get bit_ticks rdlong bitticks,t1 add t1,#4 'get buffer_ptr rdlong rxbuff,t1 mov txbuff,rxbuff add txbuff,#16 test rxtxmode,#%100 wz 'init tx pin according to mode test rxtxmode,#%010 wc if_z_ne_c or outa,txmask if_z or dira,txmask mov txcode,#transmit 'initialize ping-pong multitasking ' ' ' Receive ' receive jmpret rxcode,txcode 'run a chunk of transmit code, then return test rxtxmode,#%001 wz 'wait for start bit on rx pin test rxmask,ina wc if_z_eq_c jmp #receive mov rxbits,#9 'ready to receive byte mov rxcnt,bitticks shr rxcnt,#1 add rxcnt,cnt :bit add rxcnt,bitticks 'ready next bit period :wait jmpret rxcode,txcode 'run a chuck of transmit code, then return mov t1,rxcnt 'check if bit receive period done sub t1,cnt cmps t1,#0 wc if_nc jmp #:wait test rxmask,ina wc 'receive bit on rx pin rcr rxdata,#1 djnz rxbits,#:bit shr rxdata,#32-9 'justify and trim received byte and rxdata,#$FF test rxtxmode,#%001 wz 'if rx inverted, invert byte if_nz xor rxdata,#$FF rdlong t2,par 'save received byte and inc head add t2,rxbuff wrbyte rxdata,t2 sub t2,rxbuff add t2,#1 and t2,#$0F wrlong t2,par jmp #receive 'byte done, receive next byte ' ' ' Transmit ' transmit jmpret txcode,rxcode 'run a chunk of receive code, then return mov t1,par 'check for head <> tail add t1,#2 << 2 rdlong t2,t1 add t1,#1 << 2 rdlong t3,t1 cmp t2,t3 wz if_z jmp #transmit add t3,txbuff 'get byte and inc tail rdbyte txdata,t3 sub t3,txbuff add t3,#1 and t3,#$0F wrlong t3,t1 or txdata,#$100 'ready byte to transmit shl txdata,#2 or txdata,#1 mov txbits,#11 mov txcnt,cnt :bit test rxtxmode,#%100 wz 'output bit on tx pin according to mode test rxtxmode,#%010 wc if_z_and_c xor txdata,#1 shr txdata,#1 wc if_z muxc outa,txmask if_nz muxnc dira,txmask add txcnt,bitticks 'ready next cnt :wait jmpret txcode,rxcode 'run a chunk of receive code, then return mov t1,txcnt 'check if bit transmit period done sub t1,cnt cmps t1,#0 wc if_nc jmp #:wait djnz txbits,#:bit 'another bit to transmit? jmp #transmit 'byte done, transmit next byte ' ' ' Uninitialized data ' t1 res 1 t2 res 1 t3 res 1 rxtxmode res 1 bitticks res 1 rxmask res 1 rxbuff res 1 rxdata res 1 rxbits res 1 rxcnt res 1 rxcode res 1 txmask res 1 txbuff res 1 txdata res 1 txbits res 1 txcnt res 1 txcode res 1 PASM End ┌──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┐ │ TERMS OF USE: MIT License │ ├──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┤ │Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation │ │files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, │ │modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software│ │is furnished to do so, subject to the following conditions: │ │ │ │The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.│ │ │ │THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE │ │WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR │ │COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, │ │ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. │ └──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┘ */ unsigned long serial_cog[511] = { 0xa0bca9f0, 0x80fca810, 0x08bcaa54, 0xa0fcb201, 0x2cbcb255, 0x80fca804, 0x08bcaa54, 0xa0fcbe01, 0x2cbcbe55, 0x80fca804, 0x08bcae54, 0x80fca804, 0x08bcb054, 0x80fca804, 0x08bcb454, 0xa0bcc05a, 0x80fcc010, 0x627cae04, 0x617cae02, 0x689be85f, 0x68abec5f, 0xa0fcc833, 0x5cbcbc64, 0x627cae01, 0x613cb3f2, 0x5c640016, 0xa0fcb809, 0xa0bcba58, 0x28fcba01, 0x80bcbbf1, 0x80bcba58, 0x5cbcbc64, 0xa0bca85d, 0x84bca9f1, 0xc17ca800, 0x5c4c001f, 0x613cb3f2, 0x30fcb601, 0xe4fcb81e, 0x28fcb617, 0x60fcb6ff, 0x627cae01, 0x6cd4b6ff, 0x08bcabf0, 0x80bcaa5a, 0x003cb655, 0x84bcaa5a, 0x80fcaa01, 0x60fcaa0f, 0x083cabf0, 0x5c7c0016, 0x5cbcc85e, 0xa0bca9f0, 0x80fca808, 0x08bcaa54, 0x80fca804, 0x08bcac54, 0x863caa56, 0x5c680033, 0x80bcac60, 0x00bcc256, 0x84bcac60, 0x80fcac01, 0x60fcac0f, 0x083cac54, 0x68fcc300, 0x2cfcc202, 0x68fcc201, 0xa0fcc40b, 0xa0bcc7f1, 0x627cae04, 0x617cae02, 0x6ce0c201, 0x29fcc201, 0x70abe85f, 0x7497ec5f, 0x80bcc658, 0x5cbcc85e, 0xa0bca863, 0x84bca9f1, 0xc17ca800, 0x5c4c004d, 0xe4fcc446, 0x5c7c0033 }; // start of C functions void clearscreen() // white text on dark blue background { int i; for (i=0;i<40;i++) { t_setpos(0,0,i); // move cursor to next line t_color(0,0x08FC); // RRGGBBxx eg dark blue background 00001000 white text 11111100 } } void sleep(int milliseconds) // sleep function { _waitcnt(_cnt()+(milliseconds*(_clockfreq()/1000))-4296); } char peek(int address) // function implementation of peek { return *((char *)address); } void poke(int address, char value) // function implementation of poke { *((char *)address) = value; } void external_memory_cog_load(int cognumber, unsigned long cogdata[], unsigned long parameters_array[]) // load a cog from external memory { unsigned long hubcog[511]; // create a local array, this is in hub ram, not external ram int i; for(i=0;i<512;i++) { hubcog[i]=cogdata[i]; // move from external memory to a local array in hub } _coginit((int)parameters_array>>2, (int)hubcog>>2, cognumber); // load the cog } unsigned long serial_start(unsigned long rxpin,unsigned long txpin,unsigned long mode, unsigned long baudrate, unsigned long par[], unsigned long cogdata[]) { /* PUB start(rxpin, txpin, mode, baudrate) : okay '' Start serial driver - starts a cog '' returns false if no cog available '' '' mode bit 0 = invert rx '' mode bit 1 = invert tx '' mode bit 2 = open-drain/source tx '' mode bit 3 = ignore tx echo on rx stop longfill(@rx_head, 0, 4) longmove(@rx_pin, @rxpin, 3) bit_ticks := clkfreq / baudrate buffer_ptr := @rx_buffer okay := cog := cognew(@entry, @rx_head) + 1 */ unsigned long okay; unsigned long bit_ticks; unsigned long buffer_ptr; par[0] = 0; // rx_head longfill(@rx_head, 0, 4) par[1] = 0; // rx_tail par[2] = 0; // tx_head par[3] = 0; // tx_tail par[4] = rxpin; // longmove(@rx_pin, @rxpin, 3) par[5] = txpin; // note - if rewrite the pasm code could save a couple of hub longs here par[6] = mode; // as rxpin and txpin are not used anywhere else bit_ticks = _clockfreq() / baudrate; // bit_ticks := clkfreq / baudrate par[7] = bit_ticks; buffer_ptr = (unsigned long)&par[9]; // buffer_ptr := @rx_buffer points to start of circular buffer par[8] = buffer_ptr; // pointer to the start of the circular buffers // rx buffer is 9 to 12 and tx buffer is 13 to 16 (16 bytes =4 longs) external_memory_cog_load(7,cogdata,par); // load from external ram // okay returns the cog number or -1 if a fail page 119 manual. Ignored here // printf("par array is at %u \n",(unsigned long)&par[0]); // printf("par array entry 1 is at %u \n",(unsigned long)&par[1]); // printf("par array entry 7 is at %u \n",(unsigned long)&par[7]); // printf("rx_head is at %u \n",(unsigned long)&par[9]); // printf("buffer_ptr is %u \n",par[8]); return okay; } void serial_tx(char tx,unsigned long par[]) { /* PUB tx(txbyte) '' Send byte (may wait for room in buffer) repeat until (tx_tail <> (tx_head + 1) & $F) tx_buffer[tx_head] := txbyte tx_head := (tx_head + 1) & $F if rxtx_mode & %1000 rx */ unsigned long tx_head; int address; while ( par[3] == ((par[2] + 1 ) & 0xF)) {} // wait if the head has looped right round and is now one less than the tail tx_head = par[2]; // get the head value address = par[8] + 16 + tx_head; // location of rx buffer plus 16 to get tx buffer plus the head value poke(address,tx); // poke the tx byte value to hub ram tx_head = tx_head + 1; // add one tx_head = tx_head & 0xF; // logical and with 15 par[2] = tx_head; // store it back again // need to add the echo mode? } unsigned long serial_rxcheck(unsigned long par[]) { /* PUB rxcheck : rxbyte '' Check if byte received (never waits) '' returns -1 if no byte received, $00..$FF if byte rxbyte-- if rx_tail <> rx_head rxbyte := rx_buffer[rx_tail] rx_tail := (rx_tail + 1) & $F */ unsigned long rxbyte; // actually is a long, so can return -1 FFFFFFFF if nothing and 0-FF if a byte int address; // hub address rxbyte = 0; // set explicitly to zero rxbyte = rxbyte - 1; // return ffffffff if nothing if (par[1] != par[0]) { address = par[8] + par[1]; // par[8] is the rx buffer, par[1] is rx_tail rxbyte = peek(address); // get the return byte from the buffer par[1] = (par[1] +1) & 0xF; // add one to tail } return rxbyte; } unsigned long serial_rx(unsigned long par[]) { /* PUB rx : rxbyte '' Receive byte (may wait for byte) '' returns $00..$FF repeat while (rxbyte := rxcheck) < 0 */ unsigned long rxbyte; // actually is a long, not a byte while ((rxbyte = serial_rxcheck(par)) == -1) {} // 0xffffffff and -1 works, but " < 0" gives a compiler error return rxbyte; // return the value } void serial_rxflush(unsigned long par[]) // flush receive buffer { while (serial_rxcheck(par) != -1) {} // keep checking until buffer clear } unsigned long serial_rxtime(unsigned long ms,unsigned long par[]) // wait ms milliseconds for byte, -1 if nothing { unsigned long rxbyte = -1; unsigned long counter = 0; // start a counter, 10ms ticks ms = ms / 10; // internal delay for 1ms ticks is too high while (((rxbyte = serial_rxcheck(par)) == -1) & (counter < ms)) // wait until a byte or counter times out { _waitcnt(_cnt()+(10*(_clockfreq()/1000))-4296); // wait 10 milliseconds counter +=1; // add one to counter } return rxbyte; } void serial_str(char lineoftext[],unsigned long par[]) // send out the string { /* '' Send string repeat strsize(stringptr) tx(byte[stringptr++]) */ int i; for(i=0; i<strlen(lineoftext);i++) { serial_tx(lineoftext[i],par); // send out the bytes one at a time } } void serial_dec(signed long value,unsigned long par[]) // send out decimal value - unsigned { /* '' Print a decimal number if value < 0 -value tx("-") i := 1_000_000_000 repeat 10 if value => i tx(value / i + "0") value //= i result~~ elseif result or i == 1 tx("0") i /= 10 */ char lineoftext[12] = ""; // enough room for a 32 bit long 2^32 and possibly the minus sign sprintf(lineoftext, "%d", value); // convert to a string // printf ("lineoftext is now: %s\n", lineoftext); serial_str(lineoftext,par); // send out the string } void serial_hex(unsigned long value, unsigned long par[]) // send out a hex value /* '' Print a hexadecimal number value <<= (8 - digits) << 2 repeat digits tx(lookupz((value <-= 4) & $F : "0".."9", "A".."F")) */ { char lineoftext[8] = ""; // enough room for FFFFFFFF sprintf(lineoftext,"%x",value); // convert to hex value serial_str(lineoftext,par); // send it out } void serial_crlf(unsigned long par[]) // send a crlf { serial_tx(13,par); // cr serial_tx(10,par); // lf } int EoF (FILE* stream) { register int c, status = ((c = fgetc(stream)) == EOF); ungetc(c,stream); return status; } void readcog(char *filename,unsigned long external_cog[]) // read in a .cog file into external memory array { int i; FILE *FP1; i = 0; if((FP1=fopen(filename,"rb"))==0) // open the file { fprintf(stderr,"Can't open file %s\n",filename); exit(1); } fseek(FP1,0,0); while(!EoF(FP1) & (i<511)) // run until end of file { external_cog[i] = getc(FP1) | (getc(FP1)<<8) | (getc(FP1)<<16) | (getc(FP1)<<24); // get the long // printf("%u ",external_cog[i]); i+=1; } if(FP1) { fclose(FP1); // close the file FP1=NULL; } printf("external array cog first long = 0x%x \n",external_cog[0]); // hex value } void serial_demo(unsigned long serial_parameters[]) // demonstrate the serial cog code { int i; unsigned long value = 0x80000000; // 80000000 is -1 char lineoftext[80]; // for string testing unsigned long received_byte; // actually a long, not a byte clearscreen(); // white on blue vga printf("Clock speed %u \n",_clockfreq()); // see page 28 of the propeller manual for other useful commands printf("Catalina running in cog number %i \n",_cogid()); // integer printf("internal array cog first long = 0x%x \n",serial_cog[0]); // hex value // readcog("serial.cog",serial_cog); // read in serial.cog to external memory overwrites existing data serial_start(31,30,0,1200,serial_parameters,serial_cog); // start serial cog pins 31,30, mode 0, 1200 baud printf("Started serial driver\n"); for(i=0; i<10; i++) { serial_tx(65+i,serial_parameters); // test sending a byte 10x (delay for starting a serial terminal program) sleep(500); printf("send byte %u \n",65+i); } serial_crlf(serial_parameters); strcpy(lineoftext,"This is a really long string test with a slow baud rate to check buffer overruns"); // store a string serial_str(lineoftext,serial_parameters); // send it out serial_crlf(serial_parameters); // new line serial_dec(value,serial_parameters); // send out a big decimal number serial_crlf(serial_parameters); // new line serial_str("Hex value is ",serial_parameters); serial_hex(value,serial_parameters); // send out a hex value serial_crlf(serial_parameters); serial_rxflush(serial_parameters); // flush the receive buffer printf("Type a character within the next 3 seconds \n"); // test the timeout received_byte = serial_rxtime(3000,serial_parameters); // get a byte with a timeout printf("character was ascii %d \n",received_byte); // %d is signed printf("type some characters \n"); for (i=0;i<10;i++) // test 19 times, so tests buffer restarting { received_byte = serial_rx(serial_parameters); // get a byte serial_tx(received_byte,serial_parameters); // echo it back printf("sent back byte %u \n",received_byte); } printf("demo program finished \n"); } void main () { unsigned long serial_parameters[16]; // reserve hub space in main for buffer, head tail pointers serial_demo(serial_parameters); // demo routines while (1); // endless loop as prop reboots on exit from main() }Yes, Catalina understands "volatile", but I'this is not the problem (I just tried it and the code generated is the same in both cases, so nothing is being optimized away).
I think the problem is a missing set of parentheses:
should be In C, == has higher precednce than &. See here: http://www.difranco.net/cop2220/op-prec.htm
Ross.
Yes, my cache code was indeed faulty (embarassingly so!). I've fixed it and will post you both a new pre-release once I have tidied it up and done a little more testing.
David, you may be interested in the timing - with the corrected cache code, the time to compile your test program has halved - i.e. from 12 seconds to around 6 seconds. The -x4 option is slightly faster than the -x3 option, but not dramatically so - this is probably because of the much smaller cache size (2k instead of 8k).
Ross.
Ok, I edited the code in the post 2 above. No delay needed now.
In a general sense, this does bring up a question as to whether there are any precedence differences between Spin and C.
For long lines of code that have multiple operators in them, and sometimes with no comments, one way to make sense of these is to split them up into individual lines. Maybe you need to add a temporary variable, and maybe it is this need for a temporary variable that is the reason there are these lines of code in some programs (though that doesn't explain the lack of any explanatory comments on some of the longer ones!) Maybe it is just the gentle art of obfuscation?
Anyway, with a program running in external memory, it does not matter if you add one temp variable to a function. I'm not even sure if this even slows down the code, - is assigning a value to a variable faster or slower or the same speed as pushing a variable onto the stack?
But the part that has me a little confused is when you come across a complex equation in Spin that is part of a 'repeat' loop. Is there any way to split up the 'while' equation in C into multiple lines?
Maybe you have a temp variable and you assign its value before the while, and then reassign its value at the end of the while block - with multiple lines? This is a bit messy though as it means you have two assignments to the variable.
Hopefully not too many of these are going to come up!
I have thought at times whether one could write a Spin to C translator, but it is the difference in precedence that might be the tricky part.
Or.... plan B - ask Ross!
void main() { register int f; register int g; int a = 1; int b = 2; int c = 3; int d = 4; int e = 0; /* this ... */ e = (a/b)-(c*d); /* generates the same code as this ... */ f = a/b; g = c*d; e = f - g; }C has do ... while as well as simple for and while loops. It would probably be worth figuring out the equivalent C loop to each of the SPIN repeat options. I think you want a do ... while loop. Not me! But Dave Hein has done some good work on this already.Ross.
re do and while, it has taken me years to work out the difference between these, both in C and Basic.
In a nutshell, one tests the variable at the beginning and one at the end. A 'do' will go through the next code at least once. A 'while' will not if the condition is false.
Spin has similar rules. I think if I come across a 'repeat' in the future and it needs to be changed to a 'while' and it has complex maths, I'll be adding lots of brackets.
I have another question now - one of the things I want to code is the highest resolution vga driver and that uses 4 cogs. That means I need to shut down a number of catalina cogs, and if I shut something down, I need to get it working again afterwards.
So the next object to code is the standard spin keyboard.
I must say that the second object is much easier than the first - especially Chip's code as it follows the same rules.
Which cog is the catalina keyboard running in?
I did some experiments with scanf. I think with two drivers running there are going to be problems and I am seeing the Num Lock led flashing so I am using this as a test. Working through the cogs one at a time and running cogstop, if I shut down cog 4 then the keyboard leds do not flash.
However, printf then stops working. Is stdio going to get upset if I shut down the keyboard? And is it cog 4 or have I got that wrong?
This is not so easy to determine, because I was lazy and only registered the HMI plugin itself, not the individual drivers. The way I do it when I need to (e.g. look in demos\multicog\dining_philosphers.c) is just to add one to my own cog id to to get the keyboard driver, since I know it is always the first driver started. But I'll fix this in Catalina 3.0 to explicitly register each driver when it is started, so that you can find it at runtime by searching the registry.
Nothing will stop working if you shut down the keyboard driver. But you'll have to write your own code to start it back up again!
Ross.
printf("Catalina running in cog number %i \n",_cogid()); // integer printf("stop keyboard cog \n"); _cogstop(0); printf("stopped a cog \n");This reports catalina is running in cog 2.
Does this mean that the keyboard driver goes into the first free cog and that is cog 0?
Shutting down cog 3 or 4 gives very odd behaviour. I guess the next test to see if it is cog 0 is to try getting something from the keyboard.
Addit: yes, cog 0 is the keyboard. This code is incrementing the head counter each keypress and printing 65 when you hit a capital A. Woot!
printf("Catalina running in cog number %i \n",_cogid()); // integer _cogstop(0); key_start(26,27,key_parameters,key_cog); printf("keyboard started \n"); for (i=0;i<10;i++) { sleep(1000); printf("value of head is %u \n",key_parameters[1]); printf("value of par_present is %u \n",key_parameters[2]); printf("value of buffer 0 is %u \n",key_parameters[11]); printf("value of buffer 1 is %u \n",key_parameters[12]); }How odd. You're probably going to have to wait for Catalina 3.0 to be able to definitively identify the keyboard cog. I'll email you a pre-release as soon as I have one that does what you need.
Ross.
Ross.
What would be your thoughts on True and False http://forums.parallax.com/showthread.php?129146-TRUE-or-FALSE see post #6 from Dave
I converted it to this which has an extra line as it is converting an unsigned array variable to a signed value
But - given this is C, should we return 1 instead of -1?
Officially, yes. But in reality anything with the least significant bit set will work as "true".
If in doubt use "if (boolean != 0) ...: instead if "if (boolean) ..." - I do this a lot. It sometimes looks a bit silly, but it is a "safe" way to program when dealing with different languages.
Ross.
A small thing
printf("hit a key \n"); // needs the \n printf("you hit %u \n",key_getkey(key_parameters));if I leave out the \n then it does not print the "hit a key" until *after* I hit the key. If I put the \n in, then it prints "hit a key" as expected. Is this a C feature?
Ross, there are 8 cogs - one is being used for catalina (2) , one is for the keyboard (0) and one is spare (7). What are the others being used for?
/* PASM keyboard object for use with Catalina compiler */ #include <stdio.h> /* PASM Code - use Homespun and SPINC to create a .h file. The Catalina vb.net IDE can also create a .cog file for the sd card Make the array an unsigned long with 511 longs Put the array before any functions so it ends up in external memory (arrays within functions end up in hub memory) A logical place for the array if there are multiple blocks of pasm code is to place it underneath the pasm code ''*************************************** ''* PS/2 Keyboard Driver v1.0.1 * ''* Author: Chip Gracey * ''* Copyright (c) 2004 Parallax, Inc. * ''* See end of file for terms of use. * ''* C version by James Moxham. * ''*************************************** Functions key_start // start the keyboard key_startx // start keyboard with lock settings key_present // test if keyboard present - takes 1-2 seconds to boot key_key // get a key - never waits key_getkey // get a key - always waits key_newkey // restart buffer and get a key key_gotkey // is there a key in the buffer key_clearkeys // restart buffer {-----------------REVISION HISTORY----------------- v1.0.1 - Updated 6/15/2006 to work with Propeller Tool 0.96} PASM Start - put 'PASM Start' at the beginning so that the color highlighter knows to highlight the CON PUB DAT. Put 'PASM End' at the end CON ' add your values here _clkfreq = 80_000_000 ' 5Mhz Crystal _clkmode = xtal1 + pll16x ' x 16 ' Start of C hub constants ' End of C constants PUB Main coginit(1,@entry,0) ' cog 1, cogstart, dummy value DAT '****************************************** '* Assembly language PS/2 keyboard driver * '****************************************** org ' ' ' Entry ' entry movd :par,#_dpin 'load input parameters _dpin/_cpin/_locks/_auto mov x,par add x,#11*4 mov y,#4 :par rdlong 0,x add :par,dlsb add x,#4 djnz y,#:par mov dmask,#1 'set pin masks shl dmask,_dpin mov cmask,#1 shl cmask,_cpin test _dpin,#$20 wc 'modify port registers within code muxc _d1,dlsb muxc _d2,dlsb muxc _d3,#1 muxc _d4,#1 test _cpin,#$20 wc muxc _c1,dlsb muxc _c2,dlsb muxc _c3,#1 mov _head,#0 'reset output parameter _head ' ' ' Reset keyboard ' reset mov dira,#0 'reset directions mov dirb,#0 movd :par,#_present 'reset output parameters _present/_states[8] mov x,#1+8 :par mov 0,#0 add :par,dlsb djnz x,#:par mov stat,#8 'set reset flag ' ' ' Update parameters ' update movd :par,#_head 'update output parameters _head/_present/_states[8] mov x,par add x,#1*4 mov y,#1+1+8 :par wrlong 0,x add :par,dlsb add x,#4 djnz y,#:par test stat,#8 wc 'if reset flag, transmit reset command if_c mov data,#$FF if_c call #transmit ' ' ' Get scancode ' newcode mov stat,#0 'reset state :same call #receive 'receive byte from keyboard cmp data,#$83+1 wc 'scancode? if_nc cmp data,#$AA wz 'powerup/reset? if_nc_and_z jmp #configure if_nc cmp data,#$E0 wz 'extended? if_nc_and_z or stat,#1 if_nc_and_z jmp #:same if_nc cmp data,#$F0 wz 'released? if_nc_and_z or stat,#2 if_nc_and_z jmp #:same if_nc jmp #newcode 'unknown, ignore ' ' ' Translate scancode and enter into buffer ' test stat,#1 wc 'lookup code with extended flag rcl data,#1 call #look cmp data,#0 wz 'if unknown, ignore if_z jmp #newcode mov t,_states+6 'remember lock keys in _states mov x,data 'set/clear key bit in _states shr x,#5 add x,#_states movd :reg,x mov y,#1 shl y,data test stat,#2 wc :reg muxnc 0,y if_nc cmpsub data,#$F0 wc 'if released or shift/ctrl/alt/win, done if_c jmp #update mov y,_states+7 'get shift/ctrl/alt/win bit pairs shr y,#16 cmpsub data,#$E0 wc 'translate keypad, considering numlock if_c test _locks,#%100 wz if_c_and_z add data,#@keypad1-@table if_c_and_nz add data,#@keypad2-@table if_c call #look if_c jmp #:flags cmpsub data,#$DD wc 'handle scrlock/capslock/numlock if_c mov x,#%001_000 if_c shl x,data if_c andn x,_locks if_c shr x,#3 if_c shr t,#29 'ignore auto-repeat if_c andn x,t wz if_c xor _locks,x if_c add data,#$DD if_c_and_nz or stat,#4 'if change, set configure flag to update leds test y,#%11 wz 'get shift into nz if_nz cmp data,#$60+1 wc 'check shift1 if_nz_and_c cmpsub data,#$5B wc if_nz_and_c add data,#@shift1-@table if_nz_and_c call #look if_nz_and_c andn y,#%11 if_nz cmp data,#$3D+1 wc 'check shift2 if_nz_and_c cmpsub data,#$27 wc if_nz_and_c add data,#@shift2-@table if_nz_and_c call #look if_nz_and_c andn y,#%11 test _locks,#%010 wc 'check shift-alpha, considering capslock muxnc :shift,#$20 test _locks,#$40 wc if_nz_and_nc xor :shift,#$20 cmp data,#"z"+1 wc if_c cmpsub data,#"a" wc :shift if_c add data,#"A" if_c andn y,#%11 :flags ror data,#8 'add shift/ctrl/alt/win flags mov x,#4 '+$100 if shift :loop test y,#%11 wz '+$200 if ctrl shr y,#2 '+$400 if alt if_nz or data,#1 '+$800 if win ror data,#1 djnz x,#:loop rol data,#12 rdlong x,par 'if room in buffer and key valid, enter sub x,#1 and x,#$F cmp x,_head wz if_nz test data,#$FF wz if_nz mov x,par if_nz add x,#11*4 if_nz add x,_head if_nz add x,_head if_nz wrword data,x if_nz add _head,#1 if_nz and _head,#$F test stat,#4 wc 'if not configure flag, done if_nc jmp #update 'else configure to update leds ' ' ' Configure keyboard ' configure mov data,#$F3 'set keyboard auto-repeat call #transmit mov data,_auto and data,#%11_11111 call #transmit mov data,#$ED 'set keyboard lock-leds call #transmit mov data,_locks rev data,#-3 & $1F test data,#%100 wc rcl data,#1 and data,#%111 call #transmit mov x,_locks 'insert locks into _states and x,#%111 shl _states+7,#3 or _states+7,x ror _states+7,#3 mov _present,#1 'set _present jmp #update 'done ' ' ' Lookup byte in table ' look ror data,#2 'perform lookup movs :reg,data add :reg,#table shr data,#27 mov x,data :reg mov data,0 shr data,x jmp #rand 'isolate byte ' ' ' Transmit byte to keyboard ' transmit _c1 or dira,cmask 'pull clock low movs napshr,#13 'hold clock for ~128us (must be >100us) call #nap _d1 or dira,dmask 'pull data low movs napshr,#18 'hold data for ~4us call #nap _c2 xor dira,cmask 'release clock test data,#$0FF wc 'append parity and stop bits to byte muxnc data,#$100 or data,dlsb mov x,#10 'ready 10 bits transmit_bit call #wait_c0 'wait until clock low shr data,#1 wc 'output data bit _d2 muxnc dira,dmask mov wcond,c1 'wait until clock high call #wait djnz x,#transmit_bit 'another bit? mov wcond,c0d0 'wait until clock and data low call #wait mov wcond,c1d1 'wait until clock and data high call #wait call #receive_ack 'receive ack byte with timed wait cmp data,#$FA wz 'if ack error, reset keyboard if_nz jmp #reset transmit_ret ret ' ' ' Receive byte from keyboard ' receive test _cpin,#$20 wc 'wait indefinitely for initial clock low waitpne cmask,cmask receive_ack mov x,#11 'ready 11 bits receive_bit call #wait_c0 'wait until clock low movs napshr,#16 'pause ~16us call #nap _d3 test dmask,ina wc 'input data bit rcr data,#1 mov wcond,c1 'wait until clock high call #wait djnz x,#receive_bit 'another bit? shr data,#22 'align byte test data,#$1FF wc 'if parity error, reset keyboard if_nc jmp #reset rand and data,#$FF 'isolate byte look_ret receive_ack_ret receive_ret ret ' ' ' Wait for clock/data to be in required state(s) ' wait_c0 mov wcond,c0 '(wait until clock low) wait mov y,tenms 'set timeout to 10ms wloop movs napshr,#18 'nap ~4us call #nap _c3 test cmask,ina wc 'check required state(s) _d4 test dmask,ina wz 'loop until got state(s) or timeout wcond if_never djnz y,#wloop '(replaced with c0/c1/c0d0/c1d1) tjz y,#reset 'if timeout, reset keyboard wait_ret wait_c0_ret ret c0 if_c djnz y,#wloop '(if_never replacements) c1 if_nc djnz y,#wloop c0d0 if_c_or_nz djnz y,#wloop c1d1 if_nc_or_z djnz y,#wloop ' ' ' Nap ' nap rdlong t,#0 'get clkfreq napshr shr t,#18/16/13 'shr scales time min t,#3 'ensure waitcnt won't snag add t,cnt 'add cnt to time waitcnt t,#0 'wait until time elapses (nap) nap_ret ret ' ' ' Initialized data ' ' dlsb long 1 << 9 tenms long 10_000 / 4 ' ' ' Lookup table ' ascii scan extkey regkey ()=keypad ' table word $0000 '00 word $00D8 '01 F9 word $0000 '02 word $00D4 '03 F5 word $00D2 '04 F3 word $00D0 '05 F1 word $00D1 '06 F2 word $00DB '07 F12 word $0000 '08 word $00D9 '09 F10 word $00D7 '0A F8 word $00D5 '0B F6 word $00D3 '0C F4 word $0009 '0D Tab word $0060 '0E ` word $0000 '0F word $0000 '10 word $F5F4 '11 Alt-R Alt-L word $00F0 '12 Shift-L word $0000 '13 word $F3F2 '14 Ctrl-R Ctrl-L word $0071 '15 q word $0031 '16 1 word $0000 '17 word $0000 '18 word $0000 '19 word $007A '1A z word $0073 '1B s word $0061 '1C a word $0077 '1D w word $0032 '1E 2 word $F600 '1F Win-L word $0000 '20 word $0063 '21 c word $0078 '22 x word $0064 '23 d word $0065 '24 e word $0034 '25 4 word $0033 '26 3 word $F700 '27 Win-R word $0000 '28 word $0020 '29 Space word $0076 '2A v word $0066 '2B f word $0074 '2C t word $0072 '2D r word $0035 '2E 5 word $CC00 '2F Apps word $0000 '30 word $006E '31 n word $0062 '32 b word $0068 '33 h word $0067 '34 g word $0079 '35 y word $0036 '36 6 word $CD00 '37 Power word $0000 '38 word $0000 '39 word $006D '3A m word $006A '3B j word $0075 '3C u word $0037 '3D 7 word $0038 '3E 8 word $CE00 '3F Sleep word $0000 '40 word $002C '41 , word $006B '42 k word $0069 '43 i word $006F '44 o word $0030 '45 0 word $0039 '46 9 word $0000 '47 word $0000 '48 word $002E '49 . word $EF2F '4A (/) / word $006C '4B l word $003B '4C ; word $0070 '4D p word $002D '4E - word $0000 '4F word $0000 '50 word $0000 '51 word $0027 '52 ' word $0000 '53 word $005B '54 [ word $003D '55 = word $0000 '56 word $0000 '57 word $00DE '58 CapsLock word $00F1 '59 Shift-R word $EB0D '5A (Enter) Enter word $005D '5B ] word $0000 '5C word $005C '5D \ word $CF00 '5E WakeUp word $0000 '5F word $0000 '60 word $0000 '61 word $0000 '62 word $0000 '63 word $0000 '64 word $0000 '65 word $00C8 '66 BackSpace word $0000 '67 word $0000 '68 word $C5E1 '69 End (1) word $0000 '6A word $C0E4 '6B Left (4) word $C4E7 '6C Home (7) word $0000 '6D word $0000 '6E word $0000 '6F word $CAE0 '70 Insert (0) word $C9EA '71 Delete (.) word $C3E2 '72 Down (2) word $00E5 '73 (5) word $C1E6 '74 Right (6) word $C2E8 '75 Up (8) word $00CB '76 Esc word $00DF '77 NumLock word $00DA '78 F11 word $00EC '79 (+) word $C7E3 '7A PageDn (3) word $00ED '7B (-) word $DCEE '7C PrScr (*) word $C6E9 '7D PageUp (9) word $00DD '7E ScrLock word $0000 '7F word $0000 '80 word $0000 '81 word $0000 '82 word $00D6 '83 F7 keypad1 byte $CA, $C5, $C3, $C7, $C0, 0, $C1, $C4, $C2, $C6, $C9, $0D, "+-*", $2F keypad2 byte "0123456789.", $0D, "+-*",$2F shift1 byte "{|}", 0, 0, "~" shift2 byte $22, 0, 0, 0, 0, "<_>?)!@#$%^&*(", 0, ":", 0, "+" ' ' ' Uninitialized data ' dmask res 1 cmask res 1 stat res 1 data res 1 x res 1 y res 1 t res 1 _head res 1 'write-only _present res 1 'write-only _states res 8 'write-only _dpin res 1 'read-only at start _cpin res 1 'read-only at start _locks res 1 'read-only at start _auto res 1 'read-only at start '' '' '' _________ '' Key Codes '' '' 00..DF = keypress and keystate '' E0..FF = keystate only '' '' '' 09 Tab '' 0D Enter '' 20 Space '' 21 ! '' 22 " '' 23 # '' 24 $ '' 25 % '' 26 & '' 27 ' '' 28 ( '' 29 ) '' 2A * '' 2B + '' 2C , '' 2D - '' 2E . '' 2F / '' 30 0..9 '' 3A : '' 3B ; '' 3C < '' 3D = '' 3E > '' 3F ? '' 40 @ '' 41..5A A..Z '' 5B [ '' 5C \ '' 5D ] '' 5E ^ '' 5F _ '' 60 ` '' 61..7A a..z '' 7B { '' 7C | '' 7D } '' 7E ~ '' '' 80-BF (future international character support) '' '' C0 Left Arrow '' C1 Right Arrow '' C2 Up Arrow '' C3 Down Arrow '' C4 Home '' C5 End '' C6 Page Up '' C7 Page Down '' C8 Backspace '' C9 Delete '' CA Insert '' CB Esc '' CC Apps '' CD Power '' CE Sleep '' CF Wakeup '' '' D0..DB F1..F12 '' DC Print Screen '' DD Scroll Lock '' DE Caps Lock '' DF Num Lock '' '' E0..E9 Keypad 0..9 '' EA Keypad . '' EB Keypad Enter '' EC Keypad + '' ED Keypad - '' EE Keypad * '' EF Keypad / '' '' F0 Left Shift '' F1 Right Shift '' F2 Left Ctrl '' F3 Right Ctrl '' F4 Left Alt '' F5 Right Alt '' F6 Left Win '' F7 Right Win '' '' FD Scroll Lock State '' FE Caps Lock State '' FF Num Lock State '' '' +100 if Shift '' +200 if Ctrl '' +400 if Alt '' +800 if Win '' '' eg. Ctrl-Alt-Delete = $6C9 '' '' '' Note: Driver will buffer up to 15 keystrokes, then ignore overflow. PASM End ???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????? ? TERMS OF USE: MIT License ? ???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????? ?Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation ? ?files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, ? ?modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software? ?is furnished to do so, subject to the following conditions: ? ? ? ?The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.? ? ? ?THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE ? ?WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR ? ?COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ? ?ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. ? ???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????? */ unsigned long key_cog[511] = { 0x54fc093d, 0xa0be61f0, 0x80fe602c, 0xa0fe6204, 0x08bc0130, 0x80bc08d8, 0x80fe6004, 0xe4fe6204, 0xa0fe5801, 0x2cbe593d, 0xa0fe5a01, 0x2cbe5b3e, 0x617e7a20, 0x70bd3ed8, 0x70bd52d8, 0x70fd7601, 0x70fd9401, 0x617e7c20, 0x70bd38d8, 0x70bd44d8, 0x70fd9201, 0xa0fe6600, 0xa0ffec00, 0xa0ffee00, 0x54fc3534, 0xa0fe6009, 0xa0fc0000, 0x80bc34d8, 0xe4fe601a, 0xa0fe5c08, 0x54fc4533, 0xa0be61f0, 0x80fe6004, 0xa0fe620a, 0x083c0130, 0x80bc44d8, 0x80fe6004, 0xe4fe6222, 0x617e5c08, 0xa0f25eff, 0x5cf1689c, 0xa0fe5c00, 0x5cfd88b5, 0x857e5e84, 0x864e5eaa, 0x5c480080, 0x864e5ee0, 0x68ca5c01, 0x5c48002a, 0x864e5ef0, 0x68ca5c02, 0x5c48002a, 0x5c4c0029, 0x617e5c01, 0x34fe5e01, 0x5cfd8894, 0x867e5e00, 0x5c680029, 0xa0be653b, 0xa0be612f, 0x28fe6005, 0x80fe6135, 0x54bc8530, 0xa0fe6201, 0x2cbe632f, 0x617e5c02, 0x74bc0131, 0xe1ce5ef0, 0x5c70001e, 0xa0be633c, 0x28fe6210, 0xe1fe5ee0, 0x62727e04, 0x80e25f08, 0x80d25f18, 0x5cf18894, 0x5c70006a, 0xe1fe5edd, 0xa0f26008, 0x2cb2612f, 0x64b2613f, 0x28f26003, 0x28f2641d, 0x66b26132, 0x6cb27f30, 0x80f25edd, 0x68d25c04, 0x627e6203, 0x85565e61, 0xe1d25e5b, 0x80d25f28, 0x5cd18894, 0x64d26203, 0x85565e3e, 0xe1d25e27, 0x80d25f2e, 0x5cd18894, 0x64d26203, 0x617e7e02, 0x74fcd020, 0x617e7e40, 0x6cc4d020, 0x857e5e7b, 0xe1f25e61, 0x80f25e41, 0x64f26203, 0x20fe5e08, 0xa0fe6004, 0x627e6203, 0x28fe6202, 0x68d65e01, 0x20fe5e01, 0xe4fe606c, 0x24fe5e0c, 0x08be61f0, 0x84fe6001, 0x60fe600f, 0x863e6133, 0x62565eff, 0xa09661f0, 0x80d6602c, 0x80966133, 0x80966133, 0x04165f30, 0x80d66601, 0x60d6660f, 0x617e5c04, 0x5c4c001e, 0xa0fe5ef3, 0x5cfd689c, 0xa0be5f40, 0x60fe5e7f, 0x5cfd689c, 0xa0fe5eed, 0x5cfd689c, 0xa0be5f3f, 0x3cfe5e1d, 0x617e5e04, 0x34fe5e01, 0x60fe5e07, 0x5cfd689c, 0xa0be613f, 0x60fe6007, 0x2cfe7803, 0x68be7930, 0x20fe7803, 0xa0fe6801, 0x5c7c001e, 0x20fe5e02, 0x50bd332f, 0x80fd32da, 0x28fe5e1b, 0xa0be612f, 0xa0be5e00, 0x28be5f30, 0x5c7c00c3, 0x68bfed2d, 0x50fda60d, 0x5cfdaed2, 0x68bfed2c, 0x50fda612, 0x5cfdaed2, 0x6cbfed2d, 0x617e5eff, 0x74fe5f00, 0x68be5ed8, 0xa0fe600a, 0x5cfd9ac5, 0x29fe5e01, 0x74bfed2c, 0xa0bd96cf, 0x5cfd9ac6, 0xe4fe60a7, 0xa0bd96d0, 0x5cfd9ac6, 0xa0bd96d1, 0x5cfd9ac6, 0x5cfd88b7, 0x867e5efa, 0x5c540016, 0x5c7c0000, 0x617e7c20, 0xf43e5b2d, 0xa0fe600b, 0x5cfd9ac5, 0x50fda610, 0x5cfdaed2, 0x613e59f2, 0x30fe5e01, 0xa0bd96cf, 0x5cfd9ac6, 0xe4fe60b8, 0x28fe5e16, 0x617e5fff, 0x5c4c0016, 0x60fe5eff, 0x5c7c0000, 0xa0bd96ce, 0xa0be62d9, 0x50fda612, 0x5cfdaed2, 0x613e5bf2, 0x623e59f2, 0xe4c262c7, 0xec7e6216, 0x5c7c0000, 0xe4f262c7, 0xe4ce62c7, 0xe4f662c7, 0xe4ee62c7, 0x08fe6400, 0x28fe6400, 0x48fe6403, 0x80be65f1, 0xf8fe6400, 0x5c7c0000, 0x00000200, 0x000009c4, 0x00d80000, 0x00d40000, 0x00d000d2, 0x00db00d1, 0x00d90000, 0x00d500d7, 0x000900d3, 0x00000060, 0xf5f40000, 0x000000f0, 0x0071f3f2, 0x00000031, 0x00000000, 0x0073007a, 0x00770061, 0xf6000032, 0x00630000, 0x00640078, 0x00340065, 0xf7000033, 0x00200000, 0x00660076, 0x00720074, 0xcc000035, 0x006e0000, 0x00680062, 0x00790067, 0xcd000036, 0x00000000, 0x006a006d, 0x00370075, 0xce000038, 0x002c0000, 0x0069006b, 0x0030006f, 0x00000039, 0x002e0000, 0x006cef2f, 0x0070003b, 0x0000002d, 0x00000000, 0x00000027, 0x003d005b, 0x00000000, 0x00f100de, 0x005deb0d, 0x005c0000, 0x0000cf00, 0x00000000, 0x00000000, 0x00000000, 0x000000c8, 0xc5e10000, 0xc0e40000, 0x0000c4e7, 0x00000000, 0xc9eacae0, 0x00e5c3e2, 0xc2e8c1e6, 0x00df00cb, 0x00ec00da, 0x00edc7e3, 0xc6e9dcee, 0x000000dd, 0x00000000, 0x00d60000, 0xc7c3c5ca, 0xc4c100c0, 0x0dc9c6c2, 0x2f2a2d2b, 0x33323130, 0x37363534, 0x0d2e3938, 0x2f2a2d2b, 0x007d7c7b, 0x00227e00, 0x3c000000, 0x293f3e5f, 0x24234021, 0x2a265e25, 0x003a0028, 0x0000002b }; // start of C functions void clearscreen() // white text on dark blue background { int i; for (i=0;i<40;i++) { t_setpos(0,0,i); // move cursor to next line t_color(0,0x08FC); // RRGGBBxx eg dark blue background 00001000 white text 11111100 } } void sleep(int milliseconds) // sleep function { _waitcnt(_cnt()+(milliseconds*(_clockfreq()/1000))-4296); } char peek(int address) // function implementation of peek { return *((char *)address); } void poke(int address, char value) // function implementation of poke { *((char *)address) = value; } void external_memory_cog_load(int cognumber, unsigned long cogdata[], unsigned long parameters_array[]) // load a cog from external memory { unsigned long hubcog[511]; // create a local array, this is in hub ram, not external ram int i; for(i=0;i<512;i++) { hubcog[i]=cogdata[i]; // move from external memory to a local array in hub } _coginit((int)parameters_array>>2, (int)hubcog>>2, cognumber); // load the cog } unsigned long key_startx(unsigned long dpin,unsigned long cpin, unsigned long keylocks, unsigned long keyauto, int cognumber, unsigned long par[], unsigned long cogdata[]) /* PUB startx(dpin, cpin, locks, auto) : okay '' Like start, but allows you to specify lock settings and auto-repeat '' '' locks = lock setup '' bit 6 disallows shift-alphas (case set soley by CapsLock) '' bits 5..3 disallow toggle of NumLock/CapsLock/ScrollLock state '' bits 2..0 specify initial state of NumLock/CapsLock/ScrollLock '' (eg. %0_001_100 = disallow ScrollLock, NumLock initially 'on') '' '' auto = auto-repeat setup '' bits 6..5 specify delay (0=.25s, 1=.5s, 2=.75s, 3=1s) '' bits 4..0 specify repeat rate (0=30cps..31=2cps) '' (eg %01_00000 = .5s delay, 30cps repeat) stop longmove(@par_keys, @dpin, 4) okay := cog := cognew(@entry, @par_tail) + 1 */ { unsigned long okay; par[11] = dpin; // longmove(@par_keys, @dpin, 4) par[12] = cpin; // move 4 bytes into array, replaces the longmove par[13] = keylocks; par[14] = keyauto; external_memory_cog_load(cognumber,cogdata,par); // load from external ram // okay returns the cog number or -1 if a fail page 119 manual. Ignored here return okay; } unsigned long key_start(unsigned long dpin,unsigned long cpin, int cognumber, unsigned long par[], unsigned long cogdata[]) /* VAR long cog long par_tail 'key buffer tail read/write (19 contiguous longs) long par_head 'key buffer head read-only long par_present 'keyboard present read-only long par_states[8] 'key states (256 bits) read-only long par_keys[8] 'key buffer (16 words) read-only (also used to pass initial parameters) PUB start(dpin, cpin) : okay '' Start keyboard driver - starts a cog '' returns false if no cog available '' '' dpin = data signal on PS/2 jack '' cpin = clock signal on PS/2 jack '' '' use 100-ohm resistors between pins and jack '' use 10K-ohm resistors to pull jack-side signals to VDD '' connect jack-power to 5V, jack-gnd to VSS '' '' all lock-keys will be enabled, NumLock will be initially 'on', '' and auto-repeat will be set to 15cps with a delay of .5s okay := startx(dpin, cpin, %0_000_100, %01_01000) */ { unsigned long okay; par[0] = 0; // par_tail par[1] = 0; // par_head par[2] = 0; // par_present key_startx(dpin, cpin, 0x4, 0x28, cognumber, par, cogdata); // okay := startx(dpin, cpin, %0_000_100, %01_01000) return okay; } unsigned long key_present(unsigned long par[]) /* PUB present : truefalse '' Check if keyboard present - valid ~2s after start '' returns t|f truefalse := -par_present */ { signed long truefalse; truefalse = par[2]; // 0 = false. In spin, true is -1. In C it is 1, so ? no negative?? truefalse = -truefalse; return truefalse; } unsigned long key_key(unsigned long par[]) // returns keycode, never waits, 0 if nothing /* PUB key : keycode '' Get key (never waits) '' returns key (0 if buffer empty) if par_tail <> par_head keycode := par_keys.word[par_tail] par_tail := ++par_tail & $F */ { unsigned long keycode = 0; unsigned long buffer_ptr; int address; if (par[0] != par[1]) // if par_tail <> par_head { buffer_ptr = par[0] + par[0]; // increments in words, not bytes buffer_ptr += (unsigned long)&par[11]; // pointer to start of buffer address = buffer_ptr; // convert to integer keycode = peek(address); // get the key code by peeking it par[0] = (par[0] +1) & 0xF; // add one to tail // printf("keycode %c address = %i tail %u \n",keycode,address,par[0]); } return keycode; } unsigned long key_getkey(unsigned long par[]) /* PUB getkey : keycode '' Get next key (may wait for keypress) '' returns key repeat until (keycode := key) */ { unsigned long keycode; while ((keycode = key_key(par)) == 0) {} // keep checking while returns 0 return keycode; } unsigned long key_newkey(unsigned long par[]) // clear buffer and get new key /* PUB newkey : keycode '' Clear buffer and get new key (always waits for keypress) '' returns key par_tail := par_head keycode := getkey */ { par[0] = par[1]; // par_tail := par_head return key_getkey(par); // get the keypress (waits) } unsigned long key_gotkey(unsigned long par[]) // check if any key in buffer /* PUB gotkey : truefalse '' Check if any key in buffer '' returns t|f truefalse := par_tail <> par_head */ { unsigned long truefalse = 0; // 0 is false if (par[0] == par[1]) { truefalse = 0xFFFFFFFF; // -1 is true } return truefalse; } void key_clearkeys(unsigned long par[]) /* PUB clearkeys '' Clear key buffer par_tail := par_head */ { par[0] = par[1]; // par_tail := par_head } void key_demo(unsigned long key_parameters[]) // demonstrate the keyboard cog code { char name[11]; // input string int i; int j; unsigned long k; clearscreen(); // clear the screen and white on blue printf("Catalina running in cog number %i \n",_cogid()); // integer _cogstop(0); // keyboard is in cog 0 key_start(26,27,7,key_parameters,key_cog); // start in cog 7 printf("keyboard started \n"); sleep(1000); // delay to start up the keyboard // printf("Keyboard not present =0, present = -1 (or 1) %d \n",key_present(key_parameters)); // printf("hit a key \n"); // needs the \n // printf("you hit %u \n",key_getkey(key_parameters)); // test getkey // printf("hit another key \n"); // printf("you hit %u \n",key_newkey(key_parameters)); // test newkey printf("hit some keys (20 keypresses) \n"); for (i=0;i<20;i++) { k = key_getkey(key_parameters); printf("key %c with ascii value %u \n",k,k); // printf("head %u tail %u \n",key_parameters[1],key_parameters[0]); } printf("program finished \n"); } void main () { unsigned long key_parameters[18]; // reserve hub space in main for buffer, head tail pointers key_demo(key_parameters); // demo routines while (1); // endless loop as prop reboots on exit from main() }Dr_A,
You'd have to send me your exact compilation command for me to tell. A mouse? An SD card plugin? One or more floating point plugins? Perhaps a clock? Also, some of the Hi Res VGA drivers actually take two cogs, not one (the Morpheus VGA driver takes three!).
The only extra cog I can be use of is that at least one is being used for the HMI plugin itself, which adds functionality to the various underlying device drivers. You've probably never realized it, but Catalina adds a visible flashing cursor to all video drivers - even the ones that don't natively support such a thing. The HMI plugin adds a heap of functionality like that to the various native keyboard, mouse and screen drivers.
Ross.
I would guess you are compiling with the -lcx library, which buffers all I/O. Recompile your program with -lc and you may see slightly different behaviour. You could probably also call fflush() to force a write. I would have to try this to be sure - but this is quite acceptable C behaviour.
Ross.
Hi Ross,
Thanks for the update! I tried this new version and it was not noticably faster at running my xbasic test program. The old version of Catalina using the -x3 memory layout took 12 seconds and this version took 11 seconds. That could easily be explained by errors in pushing the stopwatch button on my watch. In any case, it's good to have the cache bug fixed since I'm sure it could have caused problems.
David
