Computer won't communicate with BS1
I am using a bs1 module with the super carrier board. i have a usb to serial adapter that i used on my boe bot. just to check the cable and the board, i tried it with the boe bot itself AND putting the bs2 module in the super carrier. both times it communicated successfully. but when i put the bs1 in the board (yes i put it in the right direction and NO, the bs2 was not in at the same time), it says scanning... then says no basic stamp found, please help, another bs2 module is a little more expensive than i want to use for this project. yes i also switch the little things at the top to "bs1" and "1.0" still nothing. is there anything special about the bs1 where it can't or won't use the usb connector? i hope not, my laptop doesn't have a serial port
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/BS1/List/0/SortField/4/ProductID/44/Default.aspx
** you can buy that or make your own if you have the parts for it (the schematic is made available) **
PE -- attached pic w/ red-line indicating BS1 programming header
That's pretty cynical, especially for not having "looked a whole lot yet." At the link I posted there is a "hotlink" right after 'Downloads & Resources' -- http://www.parallax.com/tabid/391/Default.aspx
About the only thing that Parallax does not make available to the public is the Interpreter/s that they put into the BS1 and BS2 PICs, everything else is pretty much up for grabs.
As to whether you ought to get a BS2 -- you know you best. Be that as it may, you'll get a lot more advice about a BS2. There are still some BS1 devotees out there (erco), but one might say they're a vanishing breed.
I figure that you'll need to buy (or find, whatever) more components in the future.
N.B. - If you ever see a chicken in a coupe then thing is in a car. This is our new chicken coupe. As you can see, it's a wrecked Camaro we got at the salvage yard...
It's a kit, so you have to stuff the board and solder the components. If you haven't any competency in that regard then it wouldn't be the place to start.
It works/programs like any other BS2 Stamp.
All the connections, excepting the programming connector (the 9_pin D-Sub), are through SIP pins (provided). It too can be stuffed into a breadboard, with some finesse and patience. You run wires to it just like a Stamp; it's in a different form, that's all.
Proceed with your programming using LEDs (with resistors) to simulate your field outputs and rig up some switches to simulate your field inputs. You can find examples in PBASIC (part of the Stamp IDE / programming suite.)
In the final version, you'll have to get hold of some terminal strips and that like to facilitate all your field (real world) wiring, etc.
It won't be perfect from the start, perfect it along the way.
The OEM board is just a reference design for the chip set. The intent is for you to design the chips into your own board. On the other hand, you can use the OEM kit as a cheaper kit form of the BS1 or BS2.
(Looks like I ought to blow it out every once in a while.)
As you may note, I "love" (love) Molex C-Grid connectors.
One can solder wires/leads right to the board instead of using the SIP strip.
There are many options, everyone has to find his own way in this regard.
