Catalina 2.9 - Page 13 — Parallax Forums
Catalina 2.9
1910111315
    edited 2011-03-17 19:49
    RossH wrote: »
    That is odd. Can you try a different SD Card? If possible, try one that has just been formatted with a cluster size of 32k and an MBR?
    Ross.
    Hmmm... This is even more odd. I took a different SD card and formatted it for FAT/32k and wrote test.bas on it. Now when I type "load test.bas" I get an infinite string of error messages complaining about an unknown character code. It seems it can mount the card and open the file but it reads garbage from the file. I put the card back into my PC and verified that the data was written correctly to the card.
  • RossHRossH Posts: 5,626
    edited 2011-03-17 20:00
    I agree, this is getting more worrying.
    Could be a timing problem in my SD card handling, or it could be a problem with your C3.
    Have you successfully used the SD card on your C3 for anything else?
    Ross.
    edited 2011-03-17 20:02
    RossH wrote: »
    Ross.
    Both cards work fine with xbasic compiled with ZOG running on the same C3.
    edited 2011-03-17 20:15
    David Betz wrote: »
    Okay. Zog presumably uses the SD access code in the original caching driver, whereas Catalina uses separate SD code, and needs to synchronize the two.
    I've run lots of programs that use the SD card and not seen a problem, but a possible explanation is that the timing of SD cards varies and my code just happens to work with the card I use.
    I'll try a few different cards tonight and see if I can get it to fail.
    Ross.
    edited 2011-03-17 20:20
    Could you send me the xbasic.binary file that is working for you? Maybe I have some problem with the way I setup the Catalina toolchain.
    David
    edited 2011-03-17 20:35
    David Betz wrote: »
    David
    Okay - I'll do that when I get home.
    Ross.
  • jazzedjazzed Posts: 11,803
    edited 2011-03-17 20:37
    Nice to see that you've integrated the new homespun features.
    edited 2011-03-17 22:07
    jazzed wrote: »
    Yes, homespun's new features allow me to simplify a lot of things internally. I am trying to make 3.0 a lot "cleaner" than previous versions. I still have some way to go!
    Ros.
    edited 2011-03-18 02:16
    David,
    I think I have identified (but not solved) the problem. It seems to be a problem with the integer version of the library. When I compile with -lcx everything seems to work. When I compile with -lcix it resets the C3 when you try and do a "load".
    Attached is a binary (compiled with libcx) that works on my C3. Here are the makefile options:
    CFLAGS=-x3
    LDFLAGS=$(CFLAGS) -DC3 -M256k -DCACHED -lcx -y
    Can you confirm this works on your C3? Note you will need to use a version of xmm.binary compiled with both the C3 and CACHED option.
    Ross.
    edited 2011-03-18 02:39
    David, Jazzed ...
    Well, I just rebuilt all the libraries, and the problem seems to have disappeared - i.e. xbasic now works whether compiled with -lcix or -lcx.
    In my 3.0 pre-release "upgrade" I tried to include the only the changed library files, but I must have done something wrong. I have emailed you both a complete new compiled set of library files which you should unzip over the upgrade. Or you can just rebuild the library from source.
    David, let me know if this fixes your problem,
    Ross,
    edited 2011-03-18 04:32
    RossH wrote: »
    David, Jazzed ...
    Ross,
    Yes, the new libraries fix my SD card problem. Thanks!
    The Catalina version of xbasic compiles a lot faster than the ZOG version but takes far longer to load. One reason, of course, is that it is almost twice as big but I think payload is also slower than zogload. I wonder if I could modify zogload to load Catalina binaries? As far as execution speed goes, both are very slow running entirely from external memory but they are close enough that I'll have to use a stopwatch to determine which is faster. Anyway, thanks for the help with Catalina!
    edited 2011-03-18 06:05
    Loadable COG code - two options now working:
    1) Compile cog code to an array, include the array in the C program (ends up in external memory), then load and run OR
    2) Compile cog code to a binary file, rename to a .cog file, download to sd card, load into external ram, load and run
    I need to tidy this up and have just one "serial_start". Probably with two functions - one loads the cog from the array in hub, and one loads it from the sd card. There are merits in both systems so all the differences between the two systems ought to come down to calling one load function or the other.
    But it does work, and this is pretty cool!
    Where do you think a logical place would be for the array that contains the cog code - either at the beginning of the program all in a group, or would you put each array after its associated pasm code? I can see merits in both options so I'm not sure about that.
    /* PASM demo for use with Catalina IDE Precompiler and Compiler */
    #include <stdio.h>
    	unsigned long external_serial[511];					// external memory store for .cog file
    /* PASM Code for compilation using SpinC and inclusion as a data file
    PASM Start mycogject.spin
    CON
        ' add your values here
      _clkfreq = 80_000_000                                              ' 5Mhz Crystal
      _clkmode = xtal1 + pll16x                                          ' x 16
        ' Start of C hub constants
        ' End of C constants
    PUB Main
        coginit(1,@entry,0)                                           ' cog 1, cogstart, dummy value
    DAT
    '* Assembly language serial driver *
                            org
    ' Entry
    entry                   mov     t1,par                'get structure address
                            add     t1,#4 << 2            'skip past heads and tails
                            rdlong  t2,t1                 'get rx_pin
                            mov     rxmask,#1
                            shl     rxmask,t2
                            add     t1,#4                 'get tx_pin
                            rdlong  t2,t1
                            mov     txmask,#1
                            shl     txmask,t2
                            add     t1,#4                 'get rxtx_mode
                            rdlong  rxtxmode,t1
                            add     t1,#4                 'get bit_ticks
                            rdlong  bitticks,t1
                            add     t1,#4                 'get buffer_ptr
                            rdlong  rxbuff,t1
                            mov     txbuff,rxbuff
                            add     txbuff,#16
                            test    rxtxmode,#%100  wz    'init tx pin according to mode
                            test    rxtxmode,#%010  wc
            if_z_ne_c       or      outa,txmask
            if_z            or      dira,txmask
                            mov     txcode,#transmit      'initialize ping-pong multitasking
    ' Receive
    receive                 jmpret  rxcode,txcode         'run a chunk of transmit code, then return
                            test    rxtxmode,#%001  wz    'wait for start bit on rx pin
                            test    rxmask,ina      wc
            if_z_eq_c       jmp     #receive
                            mov     rxbits,#9             'ready to receive byte
                            mov     rxcnt,bitticks
                            shr     rxcnt,#1
                            add     rxcnt,cnt
    :bit                    add     rxcnt,bitticks        'ready next bit period
    :wait                   jmpret  rxcode,txcode         'run a chuck of transmit code, then return
                            mov     t1,rxcnt              'check if bit receive period done
                            sub     t1,cnt
                            cmps    t1,#0           wc
            if_nc           jmp     #:wait
                            test    rxmask,ina      wc    'receive bit on rx pin
                            rcr     rxdata,#1
                            djnz    rxbits,#:bit
                            shr     rxdata,#32-9          'justify and trim received byte
                            and     rxdata,#$FF
                            test    rxtxmode,#%001  wz    'if rx inverted, invert byte
            if_nz           xor     rxdata,#$FF
                            rdlong  t2,par                'save received byte and inc head
                            add     t2,rxbuff
                            wrbyte  rxdata,t2
                            sub     t2,rxbuff
                            add     t2,#1
                            and     t2,#$0F
                            wrlong  t2,par
                            jmp     #receive              'byte done, receive next byte
    ' Transmit
    transmit                jmpret  txcode,rxcode         'run a chunk of receive code, then return
                            mov     t1,par                'check for head <> tail
                            add     t1,#2 << 2
                            rdlong  t2,t1
                            add     t1,#1 << 2
                            rdlong  t3,t1
                            cmp     t2,t3           wz
            if_z            jmp     #transmit
                            add     t3,txbuff             'get byte and inc tail
                            rdbyte  txdata,t3
                            sub     t3,txbuff
                            add     t3,#1
                            and     t3,#$0F
                            wrlong  t3,t1
                            or      txdata,#$100          'ready byte to transmit
                            shl     txdata,#2
                            or      txdata,#1
                            mov     txbits,#11
                            mov     txcnt,cnt
    :bit                    test    rxtxmode,#%100  wz    'output bit on tx pin according to mode
            if_z_and_c      xor     txdata,#1
                            shr     txdata,#1       wc
            if_z            muxc    outa,txmask
            if_nz           muxnc   dira,txmask
                            add     txcnt,bitticks        'ready next cnt
    :wait                   jmpret  txcode,rxcode         'run a chunk of receive code, then return
                            mov     t1,txcnt              'check if bit transmit period done
                            sub     t1,cnt
                            cmps    t1,#0           wc
            if_nc           jmp     #:wait
                            djnz    txbits,#:bit          'another bit to transmit?
                            jmp     #transmit             'byte done, transmit next byte
    ' Uninitialized data
    t1                      res     1
    t2                      res     1
    t3                      res     1
    rxtxmode                res     1
    bitticks                res     1
    rxmask                  res     1
    rxbuff                  res     1
    rxdata                  res     1
    rxbits                  res     1
    rxcnt                   res     1
    rxcode                  res     1
    txmask                  res     1
    txbuff                  res     1
    txdata                  res     1
    txbits                  res     1
    txcnt                   res     1
    txcode                  res     1
    PASM End
    void mycogject(int cognumber, unsigned long *parameters_array)                                        // this name copied from the .spin name in the pasm section - names must match eg void mycogject matches mycogject.spin. Also first code after this must be the .h array file. Put your code after the };
            * @file mycogject_array.h
            * Created with spin.binary PASM to C Array Converter.
            * Copyright (c) 2011, John Doe
           unsigned long mycogject_array[] =
               0xa0bca9f0, 0x80fca810, 0x08bcaa54, 0xa0fcb201,
               0x2cbcb255, 0x80fca804, 0x08bcaa54, 0xa0fcbe01,
               0x2cbcbe55, 0x80fca804, 0x08bcae54, 0x80fca804,
               0x08bcb054, 0x80fca804, 0x08bcb454, 0xa0bcc05a,
               0x80fcc010, 0x627cae04, 0x617cae02, 0x689be85f,
               0x68abec5f, 0xa0fcc833, 0x5cbcbc64, 0x627cae01,
               0x613cb3f2, 0x5c640016, 0xa0fcb809, 0xa0bcba58,
               0x28fcba01, 0x80bcbbf1, 0x80bcba58, 0x5cbcbc64,
               0xa0bca85d, 0x84bca9f1, 0xc17ca800, 0x5c4c001f,
               0x613cb3f2, 0x30fcb601, 0xe4fcb81e, 0x28fcb617,
               0x60fcb6ff, 0x627cae01, 0x6cd4b6ff, 0x08bcabf0,
               0x80bcaa5a, 0x003cb655, 0x84bcaa5a, 0x80fcaa01,
               0x60fcaa0f, 0x083cabf0, 0x5c7c0016, 0x5cbcc85e,
               0xa0bca9f0, 0x80fca808, 0x08bcaa54, 0x80fca804,
               0x08bcac54, 0x863caa56, 0x5c680033, 0x80bcac60,
               0x00bcc256, 0x84bcac60, 0x80fcac01, 0x60fcac0f,
               0x083cac54, 0x68fcc300, 0x2cfcc202, 0x68fcc201,
               0xa0fcc40b, 0xa0bcc7f1, 0x627cae04, 0x617cae02,
               0x6ce0c201, 0x29fcc201, 0x70abe85f, 0x7497ec5f,
               0x80bcc658, 0x5cbcc85e, 0xa0bca863, 0x84bca9f1,
               0xc17ca800, 0x5c4c004d, 0xe4fcc446, 0x5c7c0033
    	printf("first long is %u \n",mycogject_array[0]);
           _coginit((int)parameters_array>>2, (int)mycogject_array>>2, cognumber);  // array name built from spin file name
    void external_cog_load(int cognumber, unsigned long cogdata[], unsigned long *parameters_array)    	//  load a cog from external memory
    	unsigned long hubcog[511];
    	int i;
    	for(i=0;i<512;i++)
    		hubcog[i]=cogdata[i];					// move from external memory to a local array in hub
     	_coginit((int)parameters_array>>2, (int)hubcog>>2, cognumber);		// load the cog
    void clearscreen()                                                   // white text on dark blue background
           int i;
           for (i=0;i<40;i++)
                   t_setpos(0,0,i);                                      // move cursor to next line
                   t_color(0,0x08FC);                                    // RRGGBBxx eg dark blue background 00001000 white text 11111100
    void sleep(int milliseconds)                                         // sleep function
           _waitcnt(_cnt()+(milliseconds*(_clockfreq()/1000))-4296);
    char peek(int address)                                               // function implementation of peek
           return *((char *)address);
    void poke(int address, char value)                                   // function implementation of poke
           *((char *)address) = value;
    unsigned long serial_start(unsigned long rxpin,unsigned long txpin,unsigned long mode, unsigned long baudrate, unsigned long par[])
    PUB start(rxpin, txpin, mode, baudrate) : okay
    '' Start serial driver - starts a cog
    '' returns false if no cog available
    '' mode bit 0 = invert rx
    '' mode bit 1 = invert tx
    '' mode bit 2 = open-drain/source tx
    '' mode bit 3 = ignore tx echo on rx
      stop
      longfill(@rx_head, 0, 4)
      longmove(@rx_pin, @rxpin, 3)
      bit_ticks := clkfreq / baudrate
      buffer_ptr := @rx_buffer
      okay := cog := cognew(@entry, @rx_head) + 1
    	unsigned long okay;
    	unsigned long bit_ticks;
    	unsigned long buffer_ptr;
    	par[0] = 0;						// rx_head   longfill(@rx_head, 0, 4)
    	par[1] = 0;						// rx_tail
    	par[2] = 0;						// tx_head
    	par[3] = 0;						// tx_tail
    	par[4] = rxpin;					//   longmove(@rx_pin, @rxpin, 3)
    	par[5] = txpin;					// note - if rewrite the pasm code could save a couple of hub longs here
    	par[6] = mode;					// as rxpin and txpin are not used anywhere else
    	bit_ticks = _clockfreq() / baudrate;   		//   bit_ticks := clkfreq / baudrate
    	par[7] = bit_ticks;
    	buffer_ptr = (unsigned long)&par[9];		//   buffer_ptr := @rx_buffer  points to start of circular buffer
    	par[8] = buffer_ptr;					// pointer to the start of the circular buffers
    								// rx buffer is 9 to 12 and tx buffer is 13 to 16 (16 bytes =4 longs)
    	mycogject(7,par);					// pass the packaged up array
    	// okay returns the cog number or -1 if a fail page 119 manual. Ignored here
    	printf("par array is at %u \n",(unsigned long)&par[0]);
    	printf("par array entry 1 is at %u \n",(unsigned long)&par[1]);
    	printf("par array entry 7 is at %u \n",(unsigned long)&par[7]);
    	printf("rx_head is at %u \n",(unsigned long)&par[9]);
    	printf("buffer_ptr is %u \n",par[8]);
    	return okay;
    unsigned long new_serial_start(unsigned long rxpin,unsigned long txpin,unsigned long mode, unsigned long baudrate, unsigned long par[], unsigned long cogdata[])
      stop
    	unsigned long okay;
    	par[7] = bit_ticks;
    	//mycogject(7,par);					// pass the packaged up array
    	external_cog_load(7,cogdata,par);			// load from external ram
    	return okay;
    void serial_tx(char tx,unsigned long par[])
    PUB tx(txbyte)
    '' Send byte (may wait for room in buffer)
      repeat until (tx_tail <> (tx_head + 1) & $F)
      tx_buffer[tx_head] := txbyte
      tx_head := (tx_head + 1) & $F
      if rxtx_mode & %1000
        rx
    	unsigned long tx_head;
    	int address;
    	while ( par[3] == (par[2] + 1 ) & 0xF) {} 	// par[2] is tx_head, par[3] is tx_tail
    	poke(address,tx);				// poke the tx byte value to hub ram
    	tx_head = par[2];				// get the head value
    	address = par[8] + 16 + tx_head;		// location of rx buffer plus 16 to get tx buffer plus the head value
    	tx_head = tx_head + 1;			// add one
    	tx_head = tx_head & 0xF; 			// logical and with 15
    	par[2] = tx_head;				// store it back again
    							// need to add the echo mode?
    unsigned long serial_rxcheck(unsigned long par[])
    PUB rxcheck : rxbyte
    '' Check if byte received (never waits)
    '' returns -1 if no byte received, $00..$FF if byte
      rxbyte--
      if rx_tail <> rx_head
        rxbyte := rx_buffer[rx_tail]
        rx_tail := (rx_tail + 1) & $F
    	unsigned long rxbyte;			// actually is a long, so can return -1 FFFFFFFF if nothing and 0-FF if a byte
    	int address;					// hub address
    	rxbyte = 0;					// set explicitly to zero
    	rxbyte = rxbyte - 1;				// return ffffffff if nothing
    	if (par[1] != par[0])
    		address = par[8] + par[1];		// par[8] is the rx buffer, par[1] is rx_tail
    		rxbyte = peek(address);		// get the return byte from the buffer
    		par[1] = (par[1] +1) & 0xF;		// add one to tail
    	return rxbyte;
    unsigned long serial_rx(unsigned long par[])
    PUB rx : rxbyte
    '' Receive byte (may wait for byte)
    '' returns $00..$FF
      repeat while (rxbyte := rxcheck) < 0
    	unsigned long rxbyte;			// actually is a long, not a byte
    	while ((rxbyte = serial_rxcheck(par)) == -1) {} // 0xffffffff and -1 works, but " < 0" gives a compiler error
    	return rxbyte;				// return the value
    int EoF (FILE* stream)
      	register int c, status = ((c = fgetc(stream)) == EOF);
      	ungetc(c,stream);
      	return status;
    void readcog(char *filename,unsigned long external_cog[])			// read in a .cog file into external memory array
    	int i;
    	FILE *FP1;
    	i = 0;
    	if((FP1=fopen(filename,"rb"))==0)					// open the file
      		fprintf(stderr,"Can't open file %s\n",filename);
    		exit(1);
      	fseek(FP1,0,0);
      	while(!EoF(FP1) & (i<511))							// run until end of file
    		external_cog[i] = getc(FP1) | (getc(FP1)<<8) | (getc(FP1)<<16) | (getc(FP1)<<24);	// get the long
    		// printf("%u ",external_cog[i]);
    		i+=1;
    	if(FP1)
         		fclose(FP1);							// close the file
         		FP1=NULL;
    	printf("cog data 0 = %i \n",external_cog[0]);
    void main ()
    	int i;
    	unsigned long received_byte;
    	unsigned long serial_parameters[16];				// reserve hub space for buffer, head tail pointers
           clearscreen();
           printf("Clock speed %u \n",_clockfreq());                     // see page 28 of the propeller manual for other useful commands
           printf("Catalina running in cog number %i \n",_cogid());      // integer
    	readcog("serial.cog",external_serial);				// read in serial.cog to external memory
    //	serial_start(31,30,0,1200,serial_parameters);			// start serial cog pins 31,30, mode 0, 1200 baud
    	new_serial_start(31,30,0,1200,serial_parameters,external_serial);			// start serial cog pins 31,30, mode 0, 1200 baud
           printf("Started serial driver\n");
    	for(i=0; i<10; i++)
    		serial_tx(65+i,serial_parameters); 					// test sending a byte
    		sleep(500);
    		printf("send byte %u \n",65+i);
    	printf("type some characters, will return that character plus 1 \n");
    	for (i=0;i<19;i++)							// test 19 times, so tests buffer restarting
    		received_byte = serial_rx(serial_parameters);		// get a byte
    		received_byte = received_byte + 1;				// add one and send it back
    		serial_tx(received_byte,serial_parameters);
    		printf("sent back byte %u \n",received_byte);
    	printf("program finished \n");
    	while (1); // Prop reboots on exit from main()
    edited 2011-03-18 14:22
    I just timed running my xbasic test program on the C3 under both Catalina C and GCC/ZOG. Here are the results:
    Catalina: 12 seconds
    GCC/ZOG: 17 seconds
    This isn't a competely fair comparison because the Catalina version was using the hires TV driver and the ZOG version was using the lowres TV driver. For some reason the hires driver isn't working under ZOG at the moment.
    Of course, both of these results are horrible. This is a fairly simple program and shouldn''t take this long to compile into bytecodes and run. I need to test both C compilers with data in SRAM and stack in hub memory. That should speed up execution significantly. Unfortunately, neither C compiler supports that mode yet. I could also try data/stack in hub. That mode is supported in Catalina and could probably be added to ZOG fairly easily. It isn't done yet though so the test will have to wait.
    In case you're interested, here is my test program:
    10 dim z$(3) = { "foo", "bar", "silly" }
    20 dim q$ = "abc"
    30 def greeting$ = "Hello, world!"
    40 testargs(greeting$, 42)
    50 for x = 1 to 10
    60   print x, square(x)
    70 next x
    80 r$ = "abd"
    90 s$ = "cdf"
    100 t$ = "cde"
    110 if q$ < r$ then print "ok"
    120 if s$ < t$ then print "bad"
    130 print "q$ is '"; q$; "'"
    140 print "length of q$ is "; len(q$)
    150 print "first character of q$ is "; asc(q$)
    160 for x = 0 to 2
    170   print z$(x)
    180 next x
    190 print left$(greeting$, 5)
    200 print right$(greeting$, 6)
    210 print mid$(greeting$, 2, 6)
    211 xx = 4
    212 yy = 3
    215 print "4 - 3 = " + str$(xx - yy)
    220 def square(n)
    230   return n * n
    240 end def
    250 def testargs(a$, i)
    260   print a$, i
    270 end def
    edited 2011-03-18 15:11
    That code looks interesting David. I wonder what a C version would run at?
    Some musings re self contained cog programs:
    1) Define the cog arrays at the beginning of the program -eg unsigned long serial_cog[511] and then all the data. The data corresponds to the pasm code. If you want to load a .cog off an sd card, it will overwrite this array with the sd card data. If you want to use the pure sd card system, don't put any data in this array (and you could leave out the pasm part too once .cog objects become standardised enough).
    2) The equivalent of adding Spin objects I think becomes a merge of two files. Merge all the .cog arrays at the beginning so they end up one after the other. Then merge all the pasm comment code, one after the other. Then merge all the functions, one after the other. Then merge the main programs. This could be a command line program - two source files and a destination file. Then repeat for more objects. I think this might allow the release of C objects for use in a non object oriented language (and this ought to work the same for BCX basic and maybe PropBasic as well?). The merge program would need to know the start and end of the blocks but this is pretty easy with comment lines.
    edited 2011-03-18 15:24
    I just tried building xbasic with -x4 to put the data in hub memory and the resulting binary didn't work. Nothing appeared on the TV when I loaded it. I also tried -DPC to use the serial HMI and got no response from the serial port. Is there anything else I need to do to build for this memory model other than using -x4?
    edited 2011-03-18 17:37
    Ross,
    I think you said at one point that you had not used my combined C3 SPI driver for Catalina but instead used separate drivers for SRAM/flash and the SD card. How do you coordinate between those two drivers? I'm wondering what I would have to do to use the SPI SRAM in my C code if I'm using the -x4 memory model that doesn't use it for Catalina itself.
    David
    edited 2011-03-18 18:35
    David,
    I just compiled xbasic to use the -x4 mode. You have to remember that with everything except code in Hub RAM, you probably cannot afford to dedicate 8K just as cache. I used a 2K cache and it works. You may be able to use a 4K cache - I didn't try that.
    Here are the make options I used:
    CFLAGS=-x4
    LDFLAGS=$(CFLAGS) -DC3 -M256k -DCACHED_2K -D PC -DCR_ON_LF -lcix -y
    Also note that you need to recompile the "utilities" folder using a command like:
    build C3 CACHED_2K
    I used the Parallax Serial Terminal program and everything seems to work ok. Doesn't seem to be any faster, although its difficult to tell with this program - you need to come up with a more compute intensive basic program to compare the two - all this program does is a small amount of I/O and I wouldn't expect much difference there.
    Ross.
    edited 2011-03-18 18:39
    David Betz wrote: »
    Hi David,
    You appear to be describing what Catalina does in the -x3 mode - i.e. all the code is in SPI Flash. All the global data (and the heap) is in SPI RAM. The stack and all local data is in Hub.
    Ross.
    edited 2011-03-18 18:41
    Hi Dr_A,
    I'm impressed with what you've achieved so far - I hope you will keep it up. This weekend I have to spend working school projects with my kids - but I hope next week to try out your IDE and try out some 'cogjects'!
    Ross.
    RossH wrote: »
    Hi David,
    Ross.
    Yes, that's exactly what I meant. I'll have to try that. Thanks! Do I have to rebuild the utilities to try that memory model?
    edited 2011-03-18 18:48
    David Betz wrote: »
    Ross,
    David
    David,
    The coordination is done using XMM API functions XMM_Activate and XMM_TriState (or equivalents). We are not really tristating any pins on the C3 (the terminology is a hangover from a platform where this was in fact the case - on the C3 we are instead assigning logical control of the SPI Bus) but the kernel has to make sure that it calls XMM_TriState before requesting a service from another cog that might need to use the SPI bus, and those cogs must do the equivalent of XMM_Activate to gain access to the SPI Bus and XMM_Tristate before returning control to the kernel.
    To access the SPI RAM from C, I don't see why you don't just use the Catalina -x3 mode. That's what it's for.
    Ross.
    edited 2011-03-18 19:02
    RossH wrote: »
    Because it's very slow. I figured my code would run faster if I put the code in flash, data in hub memory and just used the SRAM as a buffer for the editor and for scratch space for the compiler.
    edited 2011-03-18 21:28
    David Betz wrote: »
    When you use the -x3 mode, that's essentially what you are doing. If you want data in Hub RAM then declare it as local (e.g. local to the main function). If you want data in SPI RAM then declare it as global (or allocate it on the heap).
    For xbasic I didn't notice much speed difference between -x3 and -x4, so I wouldn't expect much of a performance gain in any case.
    Ross.
    edited 2011-03-18 21:29
    David Betz wrote: »
    No, you only have to rebuild the utilities if you change cache size.
    Ross.
    edited 2011-03-18 22:58
    RossH wrote: »
    Ross.
    Thanks Ross! I'll have to give that a try tomorrow.
    Edit: Ummm... I must be losing my mind. The -x3 layout is what I started out with. I hadn't realized that it was putting the stack and locals in hub memory. I thought that they were being placed in SRAM along with the rest of the R/W data. So I guess I've pretty much gotten as much as I can out of Catalina. My only hope for better performance is to get ZOG working with the stack and locals in hub memory. That won't be easy though since the ZPU is big-endian and the Propeller is little-endian and there are endless conflicts trying to resolve that difference.
    edited 2011-03-18 23:29
    RossH wrote: »
    David,
    CFLAGS=-x4
    build C3 CACHED_2K
    Ross.
    I just tried -x4 as you described above except with the standard HIRES_TV HMI and it sort of works but loading test.bas fails. Is that likely because I ran out of memory?
    edited 2011-03-18 23:34
    Hi David,
    That's what I've been trying to tell you! :smile:
    However, I think there is scope for improvement - I've just been running some benchmarks, and the cache is not behaving nearly as well as it should. I think there may be something wrong in the cache hit detection - i.e. it is not detecting a cache hit when it should, and is reloading from SPI too often.
    I'll let you know what I find out - but my time this weekend is fairly limited.
    Ross.
    edited 2011-03-18 23:35
    David Betz wrote: »
    Most likely. Try reducing the cache size (I suppose 1K is all that's left!) or use the LORES_TV option.
    Ross.
    RossH wrote: »
    Most likely. Try reducing the cache size.
    Ross.
    You mean it can go lower than 2K? I tried it again with -DPC and now I can load test.bas but it crashes when I type RUN.
    edited 2011-03-18 23:36
    Yes, you can go to 1K. But I had it working with PC and (I think) a 2K cache. Post your exact options.
