Bill's TODO list
Bill Henning
Hi guys,
I have not been around much due to consulting and family; however my workload - and family needs for my time - have lightened up, so I thought I'd post a list of what I am working on:
TRAVEL SCHEDULE
UPEW 2011 in Rocklin CA (May 21,22)
SOFTWARE TASKS
1) single-cog VGA hirez text modes
Looks like kuroneko found a solution that should work, I will be trying it this week
2) FlexMem fast driver, >3MB/sec
the test 2MB/sec driver is running, I now have to convert it to using timer-generated clocks to get it above 3MB/sec... close to 4MB/sec with a single cog may be feasible.
3) VMCOG2
Large memory version - I have it figured out and half changed over
Two software projects for UPEW, to be announced later
HARDWARE TASKS
I have ordered production quantities of the following boards that I've discussed before, and will have them available for sale soon:
CPUModule
DIG-8-IN-V
DIG-8-OUT-V
FlexMem
Proteus (pcb rev.2)
I also have a new prototying board coming, and the second prototype of a new exciting propeller platform. More details on those after I receive and test them.
DOCUMENTATION
I have to document and start making available 485Plug and all the boards above, and write more documentation for PropCade and the new Morpheus and Mem+ (pcb rev.2) boards (which I also have in stock).
ALL of the above boards were laid out by Sapieha, and are works of art.
If you guys would prefer that I addressed the TODO list for software in a different order than I posted above, please let me know!
TRAVEL SCHEDULE
SOFTWARE TASKS
3) VMCOG2
HARDWARE TASKS
CPUModule
DIG-8-IN-V
DIG-8-OUT-V
FlexMem
Proteus (pcb rev.2)
DOCUMENTATION
Please take a look at how the ASM works for the following driver: http://obex.parallax.com/objects/655/
I believe caching during the HSYNC is the only way.
Generally, it is *barely* possible to do 80x24 text in VGA mode at 80MHz; I tried to make a driver like that a while ago and it was close to working well ... but ...
I found that there was not enough time in the hb/hs/hf time to keep the font in the hub and do all the needed font decoding, I had to have at least two blank scan lines (of the background color) before every row of active characters. This led to an annoying stripe effect when the characters were inverted, and did not allow graphics block characters to vertically touch each other. I used an 8 pixel wide, 9 pixel tall 96 character font packed into 214 longs in the cog with weird packing and addressing to get the timing right.
Each line of the font was double scanned.
I gave up on it when I decided it was not worth the trouble as it would mean losing graphics characters, and looks horrible inverted.
At 640x480 using 8x12 font that's 80x40 characters. If the screen is kept to just 2 colors I KNOW its possible. Just alot of work.
Will your FlexMem and Propcade boards work with the 4 bit wide Winbond W25Q chips that have been mentioned recently? There is one available as a PDIP.
David
Add an item if you could: attend UPEW in May. We're hoping to see you at that time. - Ken
1. Write a TODO list.
PropCade can use a 2 bit mode with flash, but there is no benefit over a counter driven 1 bit mode (unless you use 2 cogs and weird interleaving).
A SOIC8 W25Q64 is around $5.50 for 64Mbits, and another 64Mbit SOIC-8 (one bit wide) part I can get for only $1.72 (neither part includes taxes, duty, shipping etc) - so no one should now be surprised if I start selling 256Mbit FlexMem Flash boards
(Geez, another cat escapes the bag)
FlexMem is set up to use four 1-bit devices (DIP/SOIC8/TDFN8 and I think WSON8 might also work on it, I will test that...), so while it cannot use a four bit device (in 4 bit mode) it can use 4x 64Mbit SOIC8 devices to provide 256Mbits of flash on one board. I should be receiving the first batch of production boards mid next week
I can easily make a 4 bit Winbond chip compatible FlexMem board, however I am not sure there is an advantage over using 4 single bit devices (ok, write error checking would be easier) given the above...
While I can't give more details yet, don't be too surprised if I have some more boards at UPEW
Sorry I've been MIA... life has been - interesting - and too busy.
I added it to the first post
I'll email you an update later. Don't worry, I'll have more neat new products
You are correct; sorry - I should have been more specific.
Since PropCade runs at 100MHz, I will be generating a 25MHz clock with CTRA so I can use code like the 20Mbit SD card read/write code.
This will let me burst read/write to the cog memory at close to 25Mbps. Even with hub reading/writing overhead I should be able to get roughly 2.5MB/sec burst read/write for sram and flash on PropCade.
I open source most of the code I write
David
It is available now, and in stock... I'll figure out the BOM pricing tomorrow for the full kit. The only reason I have not made a web page for it yet is lack of time.
How many would you need? Since you are using a Spinneret, I assume you will need the 3.3V version
Would you prefer the RJ45 connector version, or the 3-screw terminal version?
For the RJ45 version, you can use standard CAT-5 or CAT-6 Ethernet cables for the RS485 network cables.
Bill
For debugging, run five wires from the spinneret board to 485Plug as follows:
(Spinneret pin numbers taken from the Spinneret docs, page 7)
This will use P26&P27 for tx (direction), rx (data) equivalents of hcomm during testing.
Once your code works, you can just plug 485Plug into the PropPlug header, and run a wire from J1-pin1 to 485Plug pin5 to power the 485Plug, freeing up J1 for other uses.
Note: the 485 pins are numbered in reverse order compared to the PropPlug on the silk screen
Take a look at these:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=296-14011-5-ND
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=296-23801-5-ND
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=296-13862-5-ND
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=296-14047-5-ND
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=296-18521-5-ND
