Diptrace, 4 layer, blind vias — Parallax Forums
Erik FriesenErik Friesen Posts: 1,071
edited 2011-03-12 05:56 in General Discussion
I an getting ready to send off a new board, and have not done one that uses blind via's before. I am a little unclear on how diptrace, or other programs for that matter, deal with the drill files.
Is this a matter of the board house?
As shown in my example, there are really only three drill layers, and yet diptrace exports four, one for each layer. Does a board house look at each sandwich to determine which of the three layers gets drilled, or what?
  • LeonLeon Posts: 7,620
    edited 2011-03-11 14:15
    Why do you need blind vias? They are very expensive.
    You have four copper layers, you need a drill file for each one.
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2011-03-11 14:19
    What do you mean, 3 layer board? What I have shown above is a four layer.
    I could rework it with some trouble to get around blind vias, I have a fairly tight layout. Is it better to go 6 layers than do blind vias?
    edited 2011-03-11 14:21
    Ok, so if layer 1 drill is from top to second, 2 is second to third, 3 is third to fourth, what is the fourth?
    Ok, its probably obvious, Id rather ask than make a mistake.
    edited 2011-03-11 14:31
    You said it was a board with three drill layers, I thought you meant that it was a three layer board.
    A six-layer board will probably be cheaper than a four-layer board with blind vias.
    edited 2011-03-11 19:29
    Thanks Leon, I'll rework my board a little. Board houses would rather deal with 10mil holes than blind vias, I guess.
    What is the difficulty in blind vias? I don't understand the process well enough to really know. Are vias plated before, or after the layers get sandwiched?
    edited 2011-03-12 01:54
    I'm not sure how they make them, but they are expensive so they are only used on very high-end boards. None of the usual low-cost PCB suppliers will do them.
    http://www.jlc.net/~preid/pcbpro/pcb1.htm
    I suppose each layer has to be drilled alone. According to this tutorial, the vias are only plated once, after drilling the sandwiched board.
