Diptrace, 4 layer, blind vias
I an getting ready to send off a new board, and have not done one that uses blind via's before. I am a little unclear on how diptrace, or other programs for that matter, deal with the drill files.
Is this a matter of the board house?
As shown in my example, there are really only three drill layers, and yet diptrace exports four, one for each layer. Does a board house look at each sandwich to determine which of the three layers gets drilled, or what?
You have four copper layers, you need a drill file for each one.
I could rework it with some trouble to get around blind vias, I have a fairly tight layout. Is it better to go 6 layers than do blind vias?
Ok, its probably obvious, Id rather ask than make a mistake.
A six-layer board will probably be cheaper than a four-layer board with blind vias.
What is the difficulty in blind vias? I don't understand the process well enough to really know. Are vias plated before, or after the layers get sandwiched?
I suppose each layer has to be drilled alone. According to this tutorial, the vias are only plated once, after drilling the sandwiched board.
