Dorm 3.0 Door sign . — Parallax Forums
Peter KG6LSEPeter KG6LSE Posts: 1,383
edited 2011-03-11 14:31 in Robotics
being a Geek in college I must invent a better whiteboard .
I really want to use a IPAD but there is now way Ill stick a 600$ device out of my room .
so I am using the parallax Serial LCD module to display stuff out side of my room
and here is the kicker I can store a TON of pre made messages In the BS2 and with the needed button latch a message . Eg ( Grub time ) ( sleeping ) ( come on in !) so on .
or just default to a list of my contact info .
There was not a schematic as its just 3 wires on a BOE board .
Peter
AND
CODE>>> Attachment not found.
and a video of it VIDEO
  • WhitWhit Posts: 4,194
    edited 2011-01-28 07:10
    Neat project! Nothing says Geek like an LCD message board outside your room.
    Its no iPad, but you could move up to the uOLED-128-G1 for not too much money - http://www.parallax.com/Store/Accessories/Displays/tabid/159/CategoryID/34/List/0/SortField/0/Level/a/ProductID/452/Default.aspx
    You could display your avatar and other cool color graphics too!
    One day you will be older and have kids - You will show them you latest creation - they will look and you (like my daughter does) and say, "Dad, your such a nerd..." OUCH!
    edited 2011-02-01 12:43
    so far the sign is doing good.
    I may have to add a TEMP reading one of thease days .
    Esp considering the weather here ..
    Peter
    EDIT well in true fashon I did my first RCTIME to LCD project
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    TX              PIN     0               ' serial output to LCD
    ' -----[ Constants ]-------------------------------------------------------
    #SELECT $STAMP
      #CASE BS2, BS2E, BS2PE
        T2400       CON     396
        T9600       CON     84
        T19K2       CON     32
      #CASE BS2SX, BS2P
        T2400       CON     1021
        T9600       CON     240
        T19K2       CON     110
    #ENDSELECT
    LcdBaud         CON     T19K2
    LcdBkSpc        CON     $08             ' move cursor left
    LcdRt           CON     $09             ' move cursor right
    LcdLF           CON     $0A             ' move cursor down 1 line
    LcdCls          CON     $0C             ' clear LCD (use PAUSE 5 after)
    LcdCR           CON     $0D             ' move pos 0 of next line
    LcdBLon         CON     $11             ' backlight on
    LcdBLoff        CON     $12             ' backlight off
    LcdOff          CON     $15             ' LCD off
    LcdOn1          CON     $16             ' LCD on; cursor off, blink off
    LcdOn2          CON     $17             ' LCD on; cursor off, blink on
    LcdOn3          CON     $18             ' LCD on; cursor on, blink off
    LcdOn4          CON     $19             ' LCD on; cursor on, blink on
    LcdLine1        CON     $80             ' move to line 1, column 0
    LcdLine2        CON     $94             ' move to line 2, column 0
    LcdCC0          CON     $F8             ' define custom char 0
    LcdCC1          CON     $F9             ' define custom char 1
    LcdCC2          CON     $FA             ' define custom char 2
    LcdCC3          CON     $FB             ' define custom char 3
    LcdCC4          CON     $FC             ' define custom char 4
    LcdCC5          CON     $FD             ' define custom char 5
    LcdCC6          CON     $FE             ' define custom char 6
    LcdCC7          CON     $FF             ' define custom char 7
    ' -----[ Initialization ]--------------------------------------------------
                             ' allow LCD to initialize
    Part1 VAR WORD
    Main:
    SEROUT Tx, T2400,[LcdBLon]'backlight on
    DO
    'READ POT
    HIGH 1
    PAUSE 1
    RCTIME 1,1, Part1
    DEBUG DEC part1 ,CR
     'SEROUT Tx, T2400,[LcdCls]
     PAUSE 100
    SEROUT Tx, T2400,[DEC part1]
    PAUSE 300
    LOOP
    and a
    Video
    so far is super simple but ill admit getting that dev board was just what I needed to get back to building stuff .
  • bsnutbsnut Posts: 521
    edited 2011-02-04 07:55
    KG6LSE,
    Nice job that you did and it says geek all the way. Now, all you have to do find is a use for the rest of the 15 I/O pins.
    edited 2011-02-06 13:27
    I found a thermistor in my junk drawer . so some time Ill get its values and do scaling to make it happy .
    Peter
    edited 2011-03-02 13:09
    I have a Problem . its racking my brain . I dont see anything wrong My Only guess is the buffer in the RFID read thingy ..
    i added the Serial RFID reader and both sections work in there own program but not in the same one ..
    I used stock parallax code and did some trimming on the RFID package to make it be clean ..
    If I uncommnet a section of code it gives me a Error stating "DATA occupies same location as program"
    '   File...... Serial_LCD_Template.BS2
    '   Purpose... Template for Parallax Serial LCD
    '   Author.... (c) Parallax, Inc. -- All Rights Reserved
    '   E-mail.... support@parallax.com
    '   Started...
    '   Updated... 11 FEB 2005
    ' Modded  By Peterthethinker peter Dekluyver
    '   {$STAMP BS2}
    '   {$PBASIC 2.5}
    ' -----[ Program Description ]---------------------------------------------
    ' -----[ Revision History ]------------------------------------------------
    ' -----[ I/O Definitions ]-------------------------------------------------
    LastTag         CON     3
    #DEFINE __No_SPRAM = ($STAMP < BS2P)            ' does module have SPRAM?
        T2400       CON     396
        T9600       CON     84
        T19K2       CON     32
    ' -----[ Variables ]-------------------------------------------------------
      buf           VAR     BYTE(10)                ' RFID bytes buffer
    tagNum          VAR     NIB                     ' from EEPROM table
    idx             VAR     BYTE                    ' tag byte index
    char            VAR     BYTE                    ' character from table
    ' -----[ EEPROM Data ]-----------------------------------------------------
    Tag1            DATA    "0F03027DAA"       'My Tag
    Tag2            DATA    "04129C1A1C"
    Tag3            DATA    "041402CCD7"
    Reset:
      HIGH TX                               ' setup serial output pin
      PAUSE 100                             ' allow LCD to initialize
    ' -----[ Program Code ]----------------------------------------------------
    Main:
    DO
    SEROUT Tx, T2400,[LcdBLon]' backlight on
    SEROUT Tx, T2400,[LcdCLs]
    'SEROUT Tx, T2400,["ROOM #129"]                     ' HERE to
    'SEROUT Tx, T2400,[LcdLine2]''   down a line
    'SEROUT Tx, T2400,["Peter Dekluyver"]
    'PAUSE 2000
    'SEROUT Tx, T2400,[LcdCLs]                            ' HERE is where the Uncomment error is active
    'GOSUB NOW
    PAUSE 1000
    LOOP
    'NOW:
    GOSUB  ROOM
    GOSUB  PHONE
    GOSUB  EMAIL
    GOSUB  SKYPE
    GOSUB  HOURS
    RETURN
    TIMER:
    '  PAUSE 5000
    ' GOSUB  ROOM
    ' GOSUB  PHONE
    ' GOSUB  EMAIL
    ' GOSUB  SKYPE
    ' GOSUB  HOURS
    ' SEROUT Tx, T2400,[LcdBLoff]'backlight OFF
    RETURN
      'GOTO Main
      END
    ' -----[ Subroutines ]-----------------------------------------------------
    RFID:
        '#IF __No_SPRAM #THEN
        SERIN 1, 396, [WAIT($0A), STR buf\10]    ' wait for hdr + ID
      '#ENDIF
    Check_List:
      FOR tagNum = 1 TO LastTag                     ' scan through known tags
        FOR idx = 0 TO 9                            ' scan bytes in tag
          READ (tagNum - 1 * 10 + idx), char        ' get tag data from table
            IF (char <> buf(idx)) THEN Bad_Char     ' compare tag to table
          #ELSE
            GET idx, chkChar                        ' read char from SPRAM
            IF (char <> chkChar) THEN Bad_Char      ' compare to table
          #ENDIF
        NEXT
        GOTO Tag_Found                              ' all bytes match!
    Bad_Char:                                       ' try next tag
      NEXT
    Tag_Found:
      DEBUG "gold" ,CR   ' TO PC
     SEROUT Tx, T2400,["Welcome Peter"]
     PAUSE 500
     PAUSE 250
     SEROUT Tx, T2400,["To THE ROOM"]
     PAUSE 2000
     PAUSE 100
      RETURN
      END
    ''''''''''''''''''''''''''''''''''''BLINK
    BLINK:
     SEROUT Tx, T2400,[LcdBLon]'backlight OFF
     PAUSE 50
     PAUSE 50
    RETURN
    ''''''''''''''''''''''''''''''''''''MYROOM
    ROOM:
     SEROUT Tx, T2400,["Welcome to"]
     PAUSE 500
     PAUSE 250
     SEROUT Tx, T2400,["My Room"]
     PAUSE 2000
     PAUSE 100
    RETURN
    ''''''''''''''''''''''''''''''''''''PHONE
    PHONE:
     SEROUT Tx, T2400,["My Phone # Is"]
     PAUSE 500
     PAUSE 250
     SEROUT Tx, T2400,["(909)-634-4250"]
     PAUSE 2000
     PAUSE 100
    RETURN
    ''''''''''''''''''''''''''''''''''''EMAIL
    EMAIL:
     PAUSE 100
     SEROUT Tx, T2400,["My Email is "]
     PAUSE 750
     SEROUT Tx, T2400,["Peterthethinker"]
     PAUSE 500
     PAUSE 250
     SEROUT Tx, T2400,["@yahoo.com"]
     PAUSE  3000
     PAUSE 100
    RETURN
    ''''''''''''''''''''''''''''''''''''SKYPE
    SKYPE:
     PAUSE 100
     SEROUT Tx, T2400,["Skype Me @"]
     PAUSE 500
     PAUSE 250
     SEROUT Tx, T2400,["MVP-studios"]
     PAUSE 2000
     PAUSE 100
    RETURN
    ''''''''''''''''''''''''''''''''''''HOURS
    HOURS:
     SEROUT Tx, T2400,["My Hours are "]
     PAUSE 1000
     PAUSE 100
     SEROUT Tx, T2400,["MON/WED"]
     PAUSE 500
     PAUSE 250
     SEROUT Tx, T2400,["OPEN ALL DAY!"]
     PAUSE 2000
     SEROUT Tx, T2400,["TUES/THRS"]
     PAUSE 1000
     PAUSE 100
     SEROUT Tx, T2400,["BIO 8AM-NOON"]
     PAUSE 500
     PAUSE 250
     SEROUT Tx, T2400,["History 3PM-5PM"]
     PAUSE 3000
     PAUSE 100
     SEROUT Tx, T2400,["WEEKENDS"]
     PAUSE 500
     PAUSE 250
     SEROUT Tx, T2400,["OPEN ALL DAY"]
     PAUSE 3000
     PAUSE 100
    RETURN
    Peter
    edited 2011-03-04 16:26
    OK this is Odd .
    I did a copy paste in to a fresh BS2 file on a second computer and its not giving me any fits
    '   Started...
    '   {$STAMP BS2}
    ' {$PBASIC 2.5}
    LastTag         CON     3
        T2400       CON     396
        T9600       CON     84
        T19K2       CON     32
    Reset:
    Main:
    DO
    PAUSE 2000
    GOSUB NOW
    PAUSE 1000
    LOOP
    NOW:
    GOSUB  ROOM
    GOSUB  PHONE
    GOSUB  EMAIL
    GOSUB  SKYPE
    GOSUB  HOURS
    RETURN
    TIMER:
    '  PAUSE 5000
    ' GOSUB  ROOM
    ' GOSUB  PHONE
    ' GOSUB  EMAIL
    ' GOSUB  SKYPE
    ' GOSUB  HOURS
    RETURN
      'GOTO Main
      END
    RFID:
      '#ENDIF
    Check_List:
          #ELSE
          #ENDIF
        NEXT
      NEXT
    Tag_Found:
     PAUSE 500
     PAUSE 250
     PAUSE 2000
     PAUSE 100
      RETURN
      END
    BLINK:
     PAUSE 50
     PAUSE 50
    RETURN
    ROOM:
     PAUSE 500
     PAUSE 250
     PAUSE 2000
     PAUSE 100
    RETURN
    PHONE:
     PAUSE 500
     PAUSE 250
     PAUSE 2000
     PAUSE 100
    RETURN
    EMAIL:
     PAUSE 100
     PAUSE 750
     PAUSE 500
     PAUSE 250
     PAUSE  3000
     PAUSE 100
    RETURN
    SKYPE:
     PAUSE 100
     PAUSE 500
     PAUSE 250
     PAUSE 2000
     PAUSE 100
    RETURN
    HOURS:
     PAUSE 1000
     PAUSE 100
     PAUSE 500
     PAUSE 250
     PAUSE 2000
     PAUSE 1000
     PAUSE 100
     PAUSE 500
     PAUSE 250
     PAUSE 3000
     PAUSE 100
     PAUSE 500
     PAUSE 250
     PAUSE 3000
     PAUSE 100
    RETURN
  • bot7711bot7711 Posts: 16
    edited 2011-03-04 17:23
    Are you still having your problem? I noticed you commented out you NOW: lable in the first program, you had a ' in front of it.
    edited 2011-03-04 19:59
    it runs BUT here is the kicker . Unless I scan a card ( good or bad ) it will not pass over the RFID code back to the main code .
    what I am trying to do is If a valid card is at the reader at the time of scan GOSUB hello peter yada yada . but if no card is there at the time of scan pass on to the next message in the list ..
    I think is the wait command thats messing with me //
    Peter
    edited 2011-03-04 22:48
    OK I added a switch to trigger the RFID reader . its not what I wanted but it wil do for a few day til I find how to do ti the way I want .
    '   Started...
    '   {$STAMP BS2}
    ' {$PBASIC 2.5}
    LastTag         CON     3
        T2400       CON     396
        T9600       CON     84
        T19K2       CON     32
    Reset:
    Main:
    DO
    IF IN3 =0 THEN GOSUB RFID ELSE GOSUB RoomNum
    IF IN3 =0 THEN GOSUB RFID ELSE GOSUB WELCOME
    IF IN3 =0 THEN GOSUB RFID ELSE GOSUB Phone
    IF IN3 =0 THEN GOSUB RFID ELSE GOSUB EMAIL
    IF IN3 =0 THEN GOSUB RFID ELSE GOSUB SKYPE
    IF IN3 =0 THEN GOSUB RFID ELSE GOSUB Hours
    PAUSE 1000
    LOOP
    ' -----[ END OF Program Code ]----------------------------------------------------
    ' -----[ RFID Subroutine ]-----------------------------------------------------
    RFID:
       LOW 2' NOT USED
        SERIN 1, T2400, [WAIT($0A), STR buf\10]    ' wait for hdr + ID
      #ELSE
        SERIN 1, T2400, [WAIT($0A), SPSTR 10]
      #ENDIF
      HIGH 2 ' NOT USED
    Check_List:
          #ELSE
          #ENDIF
        NEXT
    RETURN
    Bad_Char:
                                     '  try next tag
      NEXT
    RETURN
    Bad_Tag:
      tagNum = 0
    GOTO tagdone
    Tag_Found:
     DEBUG buf,CR
     PAUSE 500
     PAUSE 250
     SEROUT Tx, T2400,["TO THE ROOM"]
     PAUSE 2000
     PAUSE 100
     TOGGLE 10   ' for alarm  later on
     GOSUB blink
     GOSUB blink
     GOSUB blink
     GOSUB blink
     GOSUB blink
    GOTO tagdone
    tagdone:
    RETURN
    BLINK:
     PAUSE 50
     PAUSE 50
     PAUSE 50
     PAUSE 50
     PAUSE 50
     PAUSE 50
    RETURN
    ''''''''''''''''''''''''''''''''''RoomNum
    RoomNum:
    PAUSE 2000
    PAUSE 100
    RETURN
    ''''''''''''''''''''''''''''''''''''WELCOME
    Welcome:
     PAUSE 500
     PAUSE 250
     PAUSE 2000
     PAUSE 100
    RETURN
    PHONE:
     PAUSE 500
     PAUSE 250
     PAUSE 2000
     PAUSE 100
    RETURN
    EMAIL:
     PAUSE 100
     PAUSE 750
     PAUSE 500
     PAUSE 250
     PAUSE  3000
     PAUSE 100
    RETURN
    SKYPE:
     PAUSE 100
     PAUSE 500
     PAUSE 250
     PAUSE 2000
     PAUSE 100
    RETURN
    HOURS:
     PAUSE 1000
     PAUSE 100
     PAUSE 500
     PAUSE 250
     PAUSE 2000
     PAUSE 1000
     PAUSE 100
     PAUSE 500
     PAUSE 250
     PAUSE 3000
     PAUSE 100
     PAUSE 500
     PAUSE 250
     PAUSE 3000
     PAUSE 100
    RETURN
    edited 2011-03-06 18:11
    This might help you in what you want to
    Tag_Found:
    ON tagNum GOSUB Routine0,  Routine1, Routine2, Routine3
    ' -----[Card's Subroutines ]-----------------------------------------------------
    ' To use differnet Card for differnet amount of Time
    ' Card # 0 is fot Unauthorized CARD
    ' Card # 1 is fot 15 Minutes and 00 Seconds
    ' Card # 2 is fot 30 Minutes and 00 Seconds
    ' Card # 3 is fot 59 Minutes and 59 Seconds
       'Unauthorized CARD Routine
        'Unauthorized CARD Led Light......
      Routine0:
       mins=$00
       secs=$00
      GOSUB Set_Time
      HIGH  Invaild_Card                                                         'Turn ON Led
      DO
      HIGH   tick
      PAUSE 500
      LOW   tick
        GOSUB Get_Time
        IF mins=$00 AND secs=$20 THEN EXIT
       DEBUG HOME, HEX2 mins, ":", HEX2 secs, CR
       DEBUG CR, CR, "Unauthorized CARD", CR
      LOOP
      DEBUG CLS, CLS                                                             ' Turn OFF Led
      LOW  Invaild_Card
      GOTO main
     '15 Minutes CARD Routine
      Routine1:
      mins=$00
      secs=$00
      GOSUB Set_Time
       GOSUB Get_Time
      DO
      HIGH   tick
      PAUSE 30
      LOW   tick
       IF mins=$00 AND secs=$05 THEN
      HIGH   relay
      HIGH   card15
      ENDIF
        ' Turn ON  Relay
        IF mins=$15 AND secs=$00 THEN EXIT
       GOSUB Get_Time
      DEBUG CR, CR, "15 MIN CARD ", CR
      LOOP
      DEBUG CLS, CLS
      LOW  relay
      LOW  card15        ' Turn OFF  Relay
      GOTO main
     '30 Minutes CARD Routine
      Routine2:
      mins=$00
      secs=$00
      GOSUB Set_Time
       GOSUB Get_Time
      DO
      HIGH   tick
      PAUSE 30
      LOW   tick
      HIGH   relay
      HIGH   card30
      ENDIF
        ' Turn ON  Relay
        IF mins=$30 AND secs=$00 THEN EXIT
       GOSUB Get_Time
      DEBUG CR, CR, "30 MIN CARD "
      LOOP
      DEBUG CLS, CLS
      LOW  relay
      LOW  card30        ' Turn OFF  Relay
      GOTO main
      '60 Minutes CARD Routine
      Routine3:
      mins=$00
      secs=$00
      GOSUB Set_Time
      GOSUB Get_Time
      DO
      HIGH   tick
      PAUSE 30
      LOW   tick
      IF mins=$00 AND secs=$05 THEN                                                 ' Turn ON Relay
      HIGH   relay
      HIGH   card60
       ENDIF
        IF mins=$59 AND secs=$59 THEN EXIT
       GOSUB Get_Time                                                               ' 60 MIN CARD
      DEBUG CR, CR, "60 MIN CARD "
      LOOP
      DEBUG CLS, CLS
      LOW   relay
      LOW   card60        ' Turn OFF  Relay
      GOTO main
    GOTO tagdone
    tagdone:
    RETURN
    You have to tell your code where to go next
    edited 2011-03-10 06:05
    sam I looked . yours go to the SUBs after a card is scanned ..right?
    My device goals were 2 things . it reads a RFID reader so I can disarm a alarm and display a " welcome home peter " message .
    it also displays a constant message if no RFID card is present ..
    the last function is where I had to cheat .
    I used a push tact switch to enable the GOSUB . IN3 is low then read .
    as if I just go to it and do the RFID SUB as a poor mans polling ,
    the code will hang and wait for a serial input .til the end of time .
    I think its the wait command in the RFID read section .
    I feel a Prop or some other 2 or more core MCU is needed .. OR interrupts.. both a BS2 cant do as far as i am aware
    peter
    The Basic Stamp can do what you want to Just Here something else I did
    DO
    'SEROUT CommPin, BaudValue, [CLRP]                            ' Clears any prior position info
    LOW  H25_Fan                                                  ' Turn OFF Cooling Fan
    DEBUG " Pick_One" ,CR
    cntr = cntr + 1 * ByPass_Switch                              ' This Routine was add because if you pushed the ByPass
    IF ( cntr = 5 ) THEN                                         ' switch again it would go HOME not just STOP
    IF Home_Switch   = 0 THEN                                     ' This is the HOME INPUT SWICH on the
    GOSUB Backwards                                               ' gate opener arm retracked postion switch
    ELSEIF IN2 = 1 THEN
    GOSUB Forwards                                                ' This  part of the routine need to be fix
    ELSE                                                          ' ELSEIF IN2 = 1 THEN
    GOSUB Start
    ENDIF
    ENDIF
    Reader1:
    LOW Enable1                                                         ' activate the reader - 1
     DEBUG "Reader1"
        SERIN RX1, T2400, 150, Reader2, [WAIT($0A), STR buf\10]          ' wait for hdr + ID
      #ELSE
        SERIN RX1, T2400, 150, Reader2, [WAIT($0A), SPSTR 10]
      #ENDIF
      HIGH Enable1                                                       ' deactivate reader - 1
      PAUSE 200
       GOTO Check_List
    Reader2:
      LOW Enable2                                                        ' activate the reader - 2
      DEBUG "Reader2"
        SERIN RX2, T2400, 150, Pick_One, [WAIT($0A), STR buf\10]          ' wait for hdr + ID
        #ELSE
        SERIN RX2, T2400, 150, Pick_One, [WAIT($0A), SPSTR 10]
      #ENDIF
      HIGH Enable2                                                       ' deactivate reader - 2
      PAUSE 200
     GOTO Check_List
    LOOP
    This what you have now
    SERIN RX, T2400, [WAIT($0A), STR buf\10] ' wait for hdr + ID
    Use this
    This line time out then gose to other card reader
    Here where you would put your own code name routine I have this Reader2
