Really BIG Letters & Numbers - Page 2 — Parallax Forums
2»
    edited 2011-03-05 16:41
    Here are some results I got from two NTSC monitors in my Propeller Lab.
    The first two screen shots are from 20" Toshiba Multimedia TV (1995) MM20E45 (TIMM)
    asset.php?fid=78528&uid=63739&d=1299372085
    asset.php?fid=78529&uid=63739&d=1299372087
    The second two screen shots are from Timothy's 3" LCD (NSTC) Monitor:
    http://www.brilldea.com/product_30LCDanddriver.html
    asset.php?fid=78527&uid=63739&d=1299372083
    asset.php?fid=78530&uid=63739&d=1299372088
    I get considerably good outputs from both of these monitors. Some slight artifacts show up, but not the the extent that you have.
    I wonder how the Parallax monitor differs?
    615 x 417 - 260K
    640 x 480 - 255K
  • PerryPerry Posts: 253
    edited 2011-03-05 18:52
    "tv_text" and "tv_terminal" drivers are fundamently different.
    "tv_text" uses the ROM font for characters (program 872 longs, variable 150 longs)
    "tv_terminal" uses vector graphics to produce characters. (program 1231 longs ,variable 860 longs
    It appears that the "tv_text" driver actually produces clearer characters.
    If you have no use for the graphics functions the "tv_text" driver would be the better choice.
    edited 2011-03-05 19:45
    Publison, thanks for showing the photos from the two monitors. They have excellent results. The 20-inch Japanese Toshiba I would expect to have sharp images. Timothy's 3" LCD (NSTC) Monitor is excellent too. The artifacts are very minimal. This gives a good example of the performance of other brand TVs.
    edited 2011-03-05 20:03
    Perry wrote: »
    I suspect it has something to do with interlace. My display is a B/W tv, don't have an LCD. Parallax does not seem to supply that little 3.5 inch any more. Need to know the exact horz/vert pixels. Try changing
      y_spacing = 12        '13 = normal
    near the top of tvBIGterminal.spin
    Thanks Perry. Wow! That change completely cleared up the bottom of all the characters, which is a substantial improvement overall. However, it introduced artifacts just under the top of the character. Changing the color from green to white did not make any change in the artifacts. The small discontinued Parallax monitor is 320 x 240 pixels.
    583 x 475 - 79K
    edited 2011-03-05 21:14
    It appears that little TV does not handle interlaced signals well. :(
    edited 2011-03-06 02:25
    Potatohead: it definitely does not like interlaced - Andy's mod with the text in ROM driver is rock solid, so I think graphics can stay with the interlaced graphics driver and text can stay with the text in ROM text driver. I also noticed the first interlaced line looks good, second line is ok, but third line and after has artifacts. Lower case is more difficult. However, the change suggested by Perry is an improvement - it makes the upper case characters more readable. It's going to be a compromise with the graphics. Probably the ace with a graphics driver is the color capability. The input given in this thread has helped to have the best solutions for my project, understand what's happening, and offers solutions for setting characters, rows and columns. Thanks to all! I am very grateful.
