Really BIG Letters & Numbers — Parallax Forums
HumanoidoHumanoido Posts: 5,770
edited 2011-03-06 02:25 in Propeller 1
How can I make BIG letters and numbers
on a Parallax small 3.5-inch display? (240 x 320 pixels)
    edited 2011-03-01 19:45
    Which graphics/text driver do you want to use? Should be possible on most.
    OBC
    edited 2011-03-01 20:39
    So far I'm using the Parallax TV driver by Chip Gracey that uses the Propeller ROM fonts because those appear slightly larger than the other default TV drivers.
    edited 2011-03-02 07:41
    I did a TV driver that mixes really big numbers with ROM font via a set of 8x8 user defined characters, which I posted to the forums some time ago but I didn't bother putting it in the obex because of the collective yawn.
    http://forums.parallax.com/showthread.php?113018-Low-Resolution-Graphics-mixed-with-ROM-font-text
  • RaymanRayman Posts: 15,692
    edited 2011-03-02 08:14
    Just use Graphics.spin. See the Graphics_Demo...
    edited 2011-03-02 08:57
    Roger: I'm already using your program. It works great for larger numbers and has a lot of good applications for numbers, especially on the smaller TVs. But I need big text too.
    Rayman: Thanks for that idea, I'll give the graphics program a try for large characters.
    edited 2011-03-02 09:00
    TV_text can produce huge characters. You just need to specify the number of rows and columns, and it will scale the characters accordingly to fill the screen.
  • jrjr.jrjr. Posts: 45
    edited 2011-03-02 10:58
    Kye's implementation of the BMP4TXTEngine.spin works well, albeit slow.
    I think I can trick it with buffering and get the result I need, I don't think I have
    the chops (in pasm) for the assembler mods to Chip's (rather undocumented) base code yet.
    It is pretty, even when scaled 4X.
    I'm using it for a CNC VGA display from a PC serial port,
    used for a remote display of CNC coordinates in manual mode.
    jr
    edited 2011-03-02 12:12
    I guess what we really need to know is how big is "Really BIG" letters and numbers?
    I know that a couple of Doug's text drivers support nice 40 column and 20 column characters.
    (20 column would likely be visible on the screen that you are using. Naturally, there is a trade off. :) )
    OBC
    edited 2011-03-03 01:12
    TV_text can produce huge characters. You just need to specify the number of rows and columns, and it will scale the characters accordingly to fill the screen. -Phil
    Thanks for the idea Phil. However, no matter what value is used for cols or rows, the resulting screen characters are not scaled. Can this program actually scale the ROM fonts up or down?
    ''*  TV Text 40x13 v1.0                 *
    ''*  Author: Chip Gracey                *
    ''*  Copyright (c) 2006 Parallax, Inc.  *
    ''*  See end of file for terms of use.  *
    CON
      cols = 40
      rows = 13
      screensize = cols * rows
      lastrow = screensize - cols
      tv_count = 14
    edited 2011-03-03 01:15
    jrjr. wrote: »
    jr
    jrjr, where? do you have a link for that?
    edited 2011-03-03 01:19
    I guess what we really need to know is how big is "Really BIG" letters and numbers? I know that a couple of Doug's text drivers support nice 40 column and 20 column characters. (20 column would likely be visible on the screen that you are using. Naturally, there is a trade off. :) ) OBC
    Thanks OBC, since 40 x 13 is way too small for lower case letters (a single character will blur on the screen) and caps are the minimum size, I would be interested in trying 20 characters to a line. Do you have a link to one of Doug's screen objects that may scale for my app (if yes, need link)?
    edited 2011-03-03 02:08
    Maybe you have some ideas for making the characters bigger with TV_Terminal.spin and TV_Terminal_Demo.spin (found in the OBEX).
    edited 2011-03-03 08:19
    Take a look at the monitor firmware for the Prop Backpack for an example of how to make the characters bigger. The ROM font is scaled, but not smoothly. Individual pixels turn into 2x2 blocks, 3x3 blocks, etc. But the text is still quite readable.
    edited 2011-03-03 17:46
    Humanoido wrote: »
    Retrotext should do what you need. We've been using it for gaming, but IIRC there is 20 characters per line.
    http://www.savagecircuits.com/forums/showthread.php?444-Retrotext-Text-Driver-for-gaming
    OBC
  • AribaAriba Posts: 2,694
    edited 2011-03-03 18:17
    Humanoido wrote: »
    CON
      cols = 40
      rows = 13
      tv_count = 14
    You can scale the pixels with the 2 parametrs hx and vx in the DAT section (tv_params). Make theme 2 times higher and half the cols and rows tiles.
    Andy
    edited 2011-03-03 19:19
    Humanoido,
    "1 to 4 Color Flexible VGA Bitmap Driver Terminal"
    buried in the obex.
    like I said, slow but pretty.
    I might have bonked the whole thing but it's working.
    colors are a bit limited in depth, but I'm hoping for
    B&W so I'm easy.
    jack
    edited 2011-03-03 19:27
    If you don't want smaller characters in the mix, you can get TV_TEXT to display 4 lines of 20 to 30 characters pretty easily, but it requires manipulating vx and hx in the constants and staying in certain constraints. I've done it for several projects, and if humanoido is interested in doing it this way I can post specifics once I get back to work and grab a few files.
    With TV, you can basically get 12, 6, 4, or 2 lines. You've got a bit more leeway on horizontal expansion and I've done 20 to 28 characters with more or less being possible. The VGA driver has the same hx and vx parameters but is much more limited because of timing and line count restraints; you can basically have 13 or 7 rows, take your pick. You can get finer grained horizontal characters but it requires modding the pixel clock which is nontrivial.
  • PerryPerry Posts: 253
    edited 2011-03-03 19:58
    Graphics.spin wil produce really BIG characters, you just need to know how to adjust the parameters.
    I use 8bit Color graphics because the memory is linear but the standard Graphics.spin should produce similar results.
    This gives 16 chars by 6 lines
    128 dots x 96 rows
    CON
      x_tiles = 8
      y_tiles = 6
    VAR
      long  tv_status     '0/1/2 = off/invisible/visible           read-only
      long  tv_enable     '0/? = off/on                            write-only
      long  tv_pins       '%pppmmmm = pin group, pin group mode    write-only
      long  tv_mode       '%ccip = chroma,interlace,ntsc/pal       write-only
      long  tv_screen     'pointer to screen                       write-only
      long  tv_color      'pointer to porch color                  write-only
      long  tv_ht         'horizontal tiles                        write-only
      long  tv_vt         'vertical tiles                          write-only
      long  tv_hx         'horizontal tile expansion               write-only
      long  tv_vx         'vertical tile expansion                 write-only
      long  tv_ho         'horizontal offset                       write-only
      long  tv_vo         'vertical offset                         write-only
      long  tv_broadcast  'broadcast frequency (Hz)                write-only
      long  tv_auralcog   'aural fm cog                            write-only
      byte  edgecolor
      word  line_base[96]
    OBJ
      tv    : "8bc_TV"
      gr    : "8bc_Graphics"
    PUB
      BlankBuffers
      gr.start
      edgecolor := $02
      gr.setup(x_tiles, y_tiles, 64, 48, bitmap_base, @line_base)
      tv_enable := 1
      tv_pins   := %001_0101 ' for demo board, pin 12
      tv_mode   := 0
      tv_screen := display_base
      tv_color  := @edgecolor
      tv_ht     := x_tiles
      tv_vt     := y_tiles
      tv_hx     := 20   '<<<<<<<<<<<< these are the tricky
      tv_vx     := 2    ' <<<<<<<<<<<<        ones to adjust
      tv.start(@tv_status)
      gr.text(0,0,string("Hello"))    ' place text in middle of screen
    edited 2011-03-03 22:50
    localroger wrote: »
    Roger, thanks! This sounds like a good path to take. 4 or 6 lines of 20 characters to a line could be perfect.
    edited 2011-03-03 22:52
    Perry wrote: »
    I use 8bit Color graphics because the memory is linear but the standard Graphics.spin should produce similar results. This gives 16 chars by 6 lines..
    Thanks Perry. I look forward to trying this tonight!
    edited 2011-03-03 22:55
    jrjr. wrote: »
    Humanoido,
    buried in the obex.
    B&W so I'm easy.
    jack
    It sounds very interesting but I need a TV driver instead of VGA. Can you convert it?
    edited 2011-03-03 22:56
    Ariba wrote: »
    You can scale the pixels with the 2 parametrs hx and vx in the DAT section (tv_params). Make theme 2 times higher and half the cols and rows tiles. Andy
    Andy, thanks much! This is the info I need to know. I'll try this asap.
    edited 2011-03-04 05:49
    Retrotext should do what you need. We've been using it for gaming, but IIRC there is 20 characters per line.http://www.savagecircuits.com/forums/showthread.php?444-Retrotext-Text-Driver-for-gaming OBC
    OBC, thank you very much but you had better change the name from Retrotext to NanoText. It's just about the smallest fly speck I've ever seen on this 3.5-inch display. I must add, however, this is a very clear and stable driver, quite remarkable, and even the text although very tiny, is somehow tac-clear, you can read it (no smearing of characters). Well, it's a job well accomplished! Thanks for sharing! But I still need characters 4x larger.
    edited 2011-03-04 06:00
    Ariba wrote: »
    Andy, so 2 and 2? I tried it and kept the first line in the demo, but it just flashes a screen with no characters.. what is missing?
    edited 2011-03-04 06:11
    Perry, I don't know where the old code should end and the new code should begin or which code to run as a demo. Can you just paste it into the code and post a new folder of files? If it works, it will be a miracle. I worked most of the night on this but no luck so far.
    edited 2011-03-04 08:01
    Humanoido wrote: »
    This code works with standard graphics.spin and tv.spin
    "Hello World" is in center of screen
    also attached is BIGterminal (21 columns by 7 lines)
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      _stack = ($3000 + $3000 + 100) >> 2   'accomodate display memory and stack
      x_tiles = 8  ' 16
      y_tiles = 6  ' 12
      paramcount = 14
      bitmap_base = $2000
      display_base = $5000
      lines = 5
      thickness = 2
      basepin = 12
    VAR
      long  mousex, mousey
      long  tv_status     '0/1/2 = off/visible/invisible           read-only
      long  tv_pins       '%ppmmm = pins                           write-only
      long  tv_mode       '%ccinp = chroma,interlace,ntsc/pal,swap write-only
      long  tv_screen     'pointer to screen (words)               write-only
      long  tv_colors     'pointer to colors (longs)               write-only
      long  tv_hc         'horizontal cells                        write-only
      long  tv_vc         'vertical cells                          write-only
      long  tv_hx         'horizontal cell expansion               write-only
      long  tv_vx         'vertical cell expansion                 write-only
      word  screen[x_tiles * y_tiles]
      long  colors[64]
    OBJ
      tv    : "tv"
      gr    : "graphics"
    PUB start | i, j, k, kk, dx, dy
      'start tv
      longmove(@tv_status, @tvparams, paramcount)
      tv_screen := @screen
      tv_colors := @colors
      tv_hc     := x_tiles
      tv_vc     := y_tiles
      tv_pins := (basepin & $38) << 1 | (basepin & 4 == 4) & %0101
      'init colors
      repeat i from 0 to 64
        colors[i] := $00001010 * (i+4) & $F + $2B060C02
      'init tile screen
      repeat dx from 0 to tv_hc - 1
        repeat dy from 0 to tv_vc - 1
          screen[dy * tv_hc + dx] := display_base >> 6 + dy + dx * tv_vc + ((dy & $3F) << 10)
      'start and setup graphics
      gr.start
      gr.setup(x_tiles,y_tiles, 64, 48, bitmap_base)
      repeat
        'clear bitmap
        gr.clear
        'draw text
        gr.textmode(1,1,7,5)
        gr.colorwidth(1,0)
        gr.text(0,0,string("Hello World"))
        'copy bitmap to display
        gr.copy(display_base)
    DAT
    tvparams                long    0               'status
                            long    1               'enable
                            long    %001_0101       'pins
                            long    %0000          'mode
                            long    0               'screen
                            long    0               'colors
                            long    x_tiles         'hc
                            long    y_tiles         'vc
                            long    10              'hx
                            long    1               'vx
                            long    0               'ho
                            long    0               'vo
                            long    0               'broadcast
                            long    0               'auralcog
    edited 2011-03-04 12:35
    Humanoido wrote: »
    Set cols and rows at begin in the CON section of TV_Text like that:
    CON
      cols = 20 '40
      rows = 6 '13
    Then set in the DAT section the hx and vx parameters to:
    long    8  '4               'hx
                            long    2  '1               'vx
    You have now a TV_Text object with 20x6 characters. You can also try it with 7 rows.
    Andy
    edited 2011-03-05 08:20
    Andy, this worked exceptionally! Thank you.
    I adjusted the screen for 16 characters by 10 rows.
    This produces the sharpest and most clear characters
    I have ever seen on this small screen.
    cols = 17  '40
      rows = 11  '13
      long    8               'hx     4
      long    1               'vx     1
    554 x 386 - 120K
    edited 2011-03-05 08:38
    Perry, thank you for this great working solution! It scales well and the characters are very interesting.
    The sharpness of the characters is nothing like the text driver that Andy talked about. I'm wondering if this is true of most TVs or if it happens only on my small TV. There is a blur line below the characters. Some characters seem like they were "stamped double." Do you know anything about this?
    654 x 494 - 98K
    edited 2011-03-05 11:45
    Humanoido wrote: »
    I suspect it has something to do with interlace. My display is a B/W tv, don't have an LCD. Parallax does not seem to supply that little 3.5 inch any more. Need to know the exact horz/vert pixels.
    Try changing
      y_spacing = 12        '13 = normal
    near the top of tvBIGterminal.spin
