What is best way to deal with button timing issue? — Parallax Forums
RagtopRagtop Posts: 406
edited 2011-03-02 10:58 in Propeller 1
I have a GPS data logger program that has a long loop with a waitcnt of 4 seconds between writes to a kml file. I use a button to start and stop recording of the kml file.
I have been using a separate cog to check the state of the button pin so that it doesn't have to be pressed at the exact time it goes back through the repeat loop.
PUB InitButton
   cognew(button(@buttonpressed), @stack)
Pub button(bp)
   dira[8]~
   long[bp] := 0
   repeat
     if ina[8] == 1       'stores a button press until an action is done in main program to remove timing issues.
        long[bp] := 1
I am sure there is a better way people are doing this, but couldn't find anything like this in the labs.
I want to add an accelerometer and need to free up a cog. I was thinking counters might could be used, but the counter examples are over my head.
  • Andrey DemenevAndrey Demenev Posts: 386
    edited 2011-03-02 06:49
    Just replace waitcnt with a loop:
        repeat
            t := cnt
            bp := 0
            repeat
                if INA[8]
                    bp := 1
                    quit
            until (cnt - t) > (CLKFREQ * 4)
            if bp
                quit
            '' WRITE TO FILE
    or use a method that measures the elapsed time relative to a systemcounter snapshot
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
    VAR
      long timer1
      long eTime1
    OBJ
      debug : "FullDuplexSerial"
    PUB Main
      'the FIRST PUB-Method inside a spinfile is ALWAYS the startpoint where the program starts to run
      debug.start(31, 30, 0, 115200)
      timer1 := cnt 'make inital snapshot of systemcounter
      repeat
        'do whatever you like inside this loop
        'the method elapsed_time_msec calculates the time that has gone since
        'variable timer1 has set to the (former) value of systemcounter
        eTime1 := elapsed_time_msec(timer1)
        if eTime1 => 1340
          debug.str(string("snapshot of systemcounter: timer1="))
          debug.dec(timer1)
          debug.str(string("  elapsed time="))
          debug.dec(eTime1)
          debug.tx(13)
          debug.tx(13)
          'make new snapshot of systemcouner to set new startvalue
          timer1 := cnt
    PUB elapsed_time_msec(p_TimeVar) | RightNow, ClockTicks
      RightNow := cnt
      if RightNow < p_TimeVar
        ClockTicks := ||($FFFFFFFF - RightNow + p_TimeVar)
      else
        ClockTicks := ||(RightNow - p_TimeVar)
      result := ClockTicks / (clkfreq / 1_000) 'calculate milliseconds
      ' SPIN treats longs as SIGNED longs meaning bit 32 represents the sign "+-"
      ' the systemcounter thinks of the 32bits as UNsigned meaning bit 32 is
      ' just another bit of the number and NOT a sign "+-"
      ' if one or both values are negative it could happen
      ' that the result is negative too
      ' the command "||" calculates the absolute value of the SIGNED longs
      'if the systemcounter has wrapped around since snapshot of
      'systemcounter (value of parameter p_TimeVar),
      'this method calculates the timedifference in the right way
      'wrap-around example with easy numbers: counter maxvalue 1000
      'p_TimeVar containing value 980
      'time goes on counter wraps around from 1000 to 0
      'time goes on
      'RightNow containing 300. This means 20 ticks until maximum 1000 and 300 ticks
      'since wrapping from 1000 to 0 in summary 320 ticks of time has gone
      'this is calculated by MaxCounter - p_TimeVar + RightNow
      'in numbers              1000     -   980     +   300     = 320
      'the real systemcounter has 32bits max value 2^32 -1 = 4294967295
      'hexadecimal $FFFFFFFF
    'end of PUB elapsed_time_msec(p_TimeVar) | RightNow, ClockTicks
    The repeat-loop will run pretty fast and check very often if the elapsed time is more than
    a value you can adjust. If elapsed time is more than log the data else don't store data
    This way you can slow down the execution of a lot of things while your main loop is still running fast
    best regards
    Stefan
