What is best way to deal with button timing issue?
I have a GPS data logger program that has a long loop with a waitcnt of 4 seconds between writes to a kml file. I use a button to start and stop recording of the kml file.
I have been using a separate cog to check the state of the button pin so that it doesn't have to be pressed at the exact time it goes back through the repeat loop.
I am sure there is a better way people are doing this, but couldn't find anything like this in the labs.
I want to add an accelerometer and need to free up a cog. I was thinking counters might could be used, but the counter examples are over my head.
PUB InitButton
cognew(button(@buttonpressed), @stack)
Pub button(bp)
dira[8]~
long[bp] := 0
repeat
if ina[8] == 1 'stores a button press until an action is done in main program to remove timing issues.
long[bp] := 1
repeat t := cnt bp := 0 repeat if INA[8] bp := 1 quit until (cnt - t) > (CLKFREQ * 4) if bp quit '' WRITE TO FILECON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR long timer1 long eTime1 OBJ debug : "FullDuplexSerial" PUB Main 'the FIRST PUB-Method inside a spinfile is ALWAYS the startpoint where the program starts to run debug.start(31, 30, 0, 115200) timer1 := cnt 'make inital snapshot of systemcounter repeat 'do whatever you like inside this loop ' 'the method elapsed_time_msec calculates the time that has gone since 'variable timer1 has set to the (former) value of systemcounter eTime1 := elapsed_time_msec(timer1) if eTime1 => 1340 debug.str(string("snapshot of systemcounter: timer1=")) debug.dec(timer1) debug.str(string(" elapsed time=")) debug.dec(eTime1) debug.tx(13) debug.tx(13) 'make new snapshot of systemcouner to set new startvalue timer1 := cnt PUB elapsed_time_msec(p_TimeVar) | RightNow, ClockTicks RightNow := cnt if RightNow < p_TimeVar ClockTicks := ||($FFFFFFFF - RightNow + p_TimeVar) else ClockTicks := ||(RightNow - p_TimeVar) result := ClockTicks / (clkfreq / 1_000) 'calculate milliseconds ' SPIN treats longs as SIGNED longs meaning bit 32 represents the sign "+-" ' the systemcounter thinks of the 32bits as UNsigned meaning bit 32 is ' just another bit of the number and NOT a sign "+-" ' if one or both values are negative it could happen ' that the result is negative too ' the command "||" calculates the absolute value of the SIGNED longs 'if the systemcounter has wrapped around since snapshot of 'systemcounter (value of parameter p_TimeVar), 'this method calculates the timedifference in the right way 'wrap-around example with easy numbers: counter maxvalue 1000 'p_TimeVar containing value 980 'time goes on counter wraps around from 1000 to 0 'time goes on 'RightNow containing 300. This means 20 ticks until maximum 1000 and 300 ticks 'since wrapping from 1000 to 0 in summary 320 ticks of time has gone 'this is calculated by MaxCounter - p_TimeVar + RightNow 'in numbers 1000 - 980 + 300 = 320 'the real systemcounter has 32bits max value 2^32 -1 = 4294967295 'hexadecimal $FFFFFFFF 'end of PUB elapsed_time_msec(p_TimeVar) | RightNow, ClockTicksThe repeat-loop will run pretty fast and check very often if the elapsed time is more than
a value you can adjust. If elapsed time is more than log the data else don't store data
This way you can slow down the execution of a lot of things while your main loop is still running fast
best regards
Stefan
