I am using qt v4.7 and building with Qt creator under Debian.
Here is what I did:
1) Check out pzst-read-only from http://code.google.com/p/pzst/
2) Unpacked that which creates the pzst-read-only directory.
3) Download and unpack QScintilla in the pzst-read-only director creating a QScintilla-gpl-2.4.6 directory in there.
4) Build Scintilla using Qt Creator from the project file: QScintilla-gpl-2.4.6/Qt4/qscintilla.pro
5) Copy the resulting scintilla libraries into my Qt setup:
# cp -a QScintilla-gpl-2.4.6/qscintilla-build-desktop/libqscintilla2.so* ~/qtsdk-2010.05/qt/lib/
6) Copy the scintilla include files into my Qt setup:
cp -a QScintilla-gpl-2.4.6/Qt4/Qsci /home/michael/qtsdk-2010.05/qt/include/
7) Build pzst in QtCreator using the project file PZST.pro
THIS FAILS with an unknown header file Qsci/SB.h in mainwindow.cpp so:
8) Delete that include statement and build again.
SUCCESS!
And it runs, see attached scree shot.
It's fast. I loaded it up with 10000 lines of Spin and it scrolls around without a stutter.
Now, is there any chance of simplifying this build I don't like to have to add libs and includes to my QT sdk.
Where is that SB.h came from????? There is nothing liket neither in qscintilla nor in my code.
To BUILD the code, you have to add these includes. But you do not need them to RUN the program, given you have QT libraries installed. Also, I build QScintilla as a static library by replacing "dll" with "staticlib" in qscintilla.pro (the line starting with config +=) - this way, when building the app, qscintilla is compiled into the application, and the app does not require qscintilla dll to run
P.S. If you install Parallax font, it will look a bit better
Actually, there can be a delay if you load a big file and then navigate to the end of file, either by pressing Ctrl+End of by selecting a method that is near the bottom of the file - that is syntax highlighter parsing the file. When it is finished, scolling is very fast
Yep, I realize there is a lot of work going on with the parser when moving around files. No complaints about that. It's a lot faster than BST for example.
Yes, but I'd rather have them somewhere other than in my qtsdk directories. There must be a nice way to tell QtCreator to find them somewhere else. Like in the scintilla directories.
Same for the scintilla library I might guess.
All in all this is shaping up to be a great addition to the Propeller tools world.
OK lets try that again: I check out a read only version of pzst like so:
heater@rsm-51:~/tmp$ svn checkout http://pzst.googlecode.com/svn/trunk/ pzst-read-only
A pzst-read-only/eserialport.h
A pzst-read-only/aboutdialog.h
....etc etc etc
A pzst-read-only/spinparser.h
U pzst-read-only
Checked out revision 5.
Change to the new copies directory and do a diff of mainwindow aganst my last download:
Has anyone got this to work with windows, I was able to build the exe, however after I open a spin file and select compile it says "Failed to start compliler"
I get a "CompileError" every time I try to compile my code. I have ensured that $PATH listed the location of the BSTC program. I have checked the bstc program in terminal and it compiles the file properly.
I used qmake, make with Linux Mint 10, Qt 4.7 to build.
Nothing is in the Compiler Window. "Compile Error" shows up in the bottom right hand corner of the IDE.
I thought it was because I have my .spin file in my "Ubuntu One" directory, due to that space in the directory name. But, I moved the file onto my desktop, and it still did not compile, throwing a Compile Error, with no information in the Compiler Window.
Could it be because I installed Qt in Synaptic instead of downloading the SDK?
Yep it works! Now, since I use Ubuntu One to sync code between computers, the program will only compile files that are saved under a directory without spaces.
Is there any way to put this in the "ToDo" list? I only ask because I would REALLY like to make this my regular Propeller IDE. I really like the layout and look of it!
Couple of things added today:
- optional line numebring in editor window
- optional current line marker in editor window
Now working on code completion. Then find/replace functionality (for now, only search works, no replace), VIM-style quick search/replace - and I think I am ready for first release
The SpinEditor constructor fails to produce a new object of the class (it doesn't instantiate).
This is looking quite fabulous!
Here is what I did:
5) Copy the resulting scintilla libraries into my Qt setup: 6) Copy the scintilla include files into my Qt setup: 7) Build pzst in QtCreator using the project file PZST.pro
SUCCESS!
Oh yes there is! It's in the pzst-read-only/mainwindow.cpp like so:
#include <QMdiSubWindow> #include <QWidget> #include <QFileDialog> #include <QApplication> #include <QCloseEvent> #include <QMimeData> #include <QTabBar> #include <QSettings> #include <QProgressBar> #include <QDockWidget> #include <QMessageBox> #include <QDir> #include <QTextCodec> #include <Qsci/SB.h> #include <QScrollArea> #include <QPainter> #include <QLineEdit> #include "mainwindow.h" #include "spineditor.h" #include "spinlexer.h" #include "spinparser.h" #include "eserialport.h" #include "propellerloader.h" #include "spincompiler.h" #include "erroritem.h" #include "aboutdialog.h" #include "preferencesdialog.h" #include "pzstpreferences.h" using namespace PZST; SpinError::SpinError(QString msg, QString f, int l, int c) :message(msg), filename(f), line(l), col(c) { } etc etc....For sure I did not put it there:)
see https://code.google.com/p/pzst/source/browse/trunk/mainwindow.cpp - there is no <Qsci/SB.h>, that line says <Qsci/qscilexercustom.h>, and it always did so.
Hmmm...That include fiel is different and a new line of code has appeared.
Oh well, it builds and runs here anyway:)
I installed the Parallax font. Had to change to 14 point to get the same size as the 12 point Liberation Mono.
I think the Parallax font looks awful ! See attachment.
Which raises the issue of saving files as good old ASCII or as UTF-16.
Many of us hate to have source code saved as UTF-16 as it buggers up all kinds of tools when working under Unix. diff for example.
Still it's early days for your users to be making requests:)
and place bstc.exe into one of directories listed in PATH environment variable
(I can put the link here and it is also on post #26 but these will get lost as the thread grows longer)
Also can you please describe how to get the code. http://code.google.com/p/pzst/source/checkout
How's that .deb coming along?
tdeyle, what is that "CompileError" exactly? What's in "Compile errors" window?
Binary builds (deb or exe) are not expected soon.
I am using a basic blank file:
As well as the one attached.
I have checked it with the bstc in a terminal window to ensure that it executed without errors.
bstc-0.15.4-pre13
Forgot to set the search path in Preferences.
