Robot
Is there any body can help to run boe bot with RF433 Transceiver and 5-Position?
* 2 RF433 Transceiver - 1 in robot and 2nd in Homeboard
* 5-Position in Homeboard
I need to move the robot up-down or right to left.
adnanzowayed@gmail.com
So, the answer to your question is "yes, there are probably folks here who can help you".
Tell us what you've done so far; what have you tried that you need help with? What part of your project are you stuck with right now?
Cheers,
' {$STAMP BS2}
' {$PBASIC 2.5}
' Sender Side
' PIN14 TO TX/RX
' PIN15 TO DATA
synch CON "A"
junk CON 126
dat VAR Byte
baud CON 16468
TR PIN 14 ' TX/RX pin of Transceiver
main:
HIGH TR ' Set Transceiver to TX
DEBUGIN dat
SEROUT 15,baud,[junk,synch,dat]
GOTO main
(2) Basic Stamp 2 board with RF433 Transciver
' {$STAMP BS2}
' {$PBASIC 2.5}
' Receiver side
' PIN14 TO TX/RX
' PIN15 TO DATA
synch CON "A"
dat VAR Byte
baud CON 16468
x VAR Byte
LOW TR ' Set Transceiver to RX
DO
PULSOUT 0, 1200
SERIN 15,baud,[WAIT(synch),dat]
SELECT dat
CASE "w" ' Forward
LOW 6
FOR x=1 TO 21
PULSOUT 12,650
PULSOUT 13,850
PAUSE 20
NEXT
CASE "s" ' Reverse
HIGH 6
FOR x =1 TO 21
PULSOUT 13,650
PULSOUT 12,850
PAUSE 20
NEXT
CASE "d" ' Right
FOR x=1 TO 21
PULSOUT 12,850
PULSOUT 13,850
PAUSE 20
NEXT
CASE "a" ' Left
FOR x=1 TO 21
PULSOUT 13,650
PULSOUT 12,650
PAUSE 20
NEXT
ENDSELECT
LOOP
END
(3) when I had try to wite a code using 5-position device like.
' File...... 5PositionSwitch_Simple.bs2
' Purpose... Show Directional Output of the 5-Position Switch
' Author.... Parallax Inc.
' E-mail.... support@parallax.com
' Started... 9-30-2009
' {$STAMP BS2}
' {$PBASIC 2.5}
[ Program Description ]
' Displays the position of the 5-Position Switch on the DEBUG screen.
[ Program Code ]
DEBUG CLS, ' Display directional graph
" ", CR,
" | ", CR,
" - - ", CR,
" | ", CR
DO
IF (IN0 = 0) THEN DEBUG CRSRXY, 2, 2, "<" ELSE DEBUG CRSRXY, 2, 2, " "
IF (IN1 = 0) THEN DEBUG CRSRXY, 5, 4, "v" ELSE DEBUG CRSRXY, 5, 4, " "
IF (IN2 = 0) THEN DEBUG CRSRXY, 8, 2, ">" ELSE DEBUG CRSRXY, 8, 2, " "
IF (IN3 = 0) THEN DEBUG CRSRXY, 5, 2, "o" ELSE DEBUG CRSRXY, 5, 2, " "
IF (IN4 = 0) THEN DEBUG CRSRXY, 5, 0, "^" ELSE DEBUG CRSRXY, 5, 0, " "
PAUSE 20
LOOP
(4) the Key Features for the 5-position as follws :
Key Features :
* 8-Pin DIP Module is ready fro breadboard of through hole Projects
* 10 kΩ pull-up resistor included on each postional pin
* simple communication with any parallax microcontroller
Do I need to replace the wire with resistors 10kΩ ?
Thank you.
