Would these voltage regulators work for my project?
Andrey Demenev
I am working on a project where electronics include Propeller, SD card, GSM module and GPS module. Everything is powered from a Li-ion battery. GSM and GPS can be powered directly from the battery, and for card and propeller I need a voltage regulator, since battery produces up to 4.2 volts when fully charged. Obviously, the regulator is to be LDO. Unfortunately, I cannot purchase suitable regulators locally, and ordering them would take too much time. What I have by hand are a couple of LP2980, which are rated up to 50 mA. I am thinking about using two such regulators - one for the propeller, another for SD card. SD card will be used for reading only, propeller will run at 80 MHz, I think up to 5 cogs would be used.
Would these 2 LP2980 regulators be enough for this project?
They tend to explode if they are charged too much, and will die if the voltage goes too low...
The battery has built-in protection
