What I Did On My Day Off (video) — Parallax Forums
Martin_HMartin_H Posts: 4,051
edited 2011-03-17 22:04 in Robotics
A few weeks ago I read through Phil Pi's wheel encoder document several times, and took the sample programs apart a line at a time. The document and code are dense but great, and I suggest making them required reading for anyone building a robot. I had plans for this knowledge, but time has been short.
Today I had a day off with nothing that needed doing. So I could finally put in time on a project I had in mind (The Erco inspired one). The project involves my BS2e powered CBA robot, wheel encoders, a compass sensor, a say it module, and an LCD for debuging.
So I sat down and entered the code zone, not even kids or a barking dog could distract me. I made good progress during the day and only just stopped because my NiMH batteries were spent. They are back in the charger, but that means I can't make a video of what I completed as I planned.
But I'll attach the in progress code for curious souls who want to take a peak:
CBA Sayit.BSE - the main module which uses the say it module.
MotorsAndSensors.BSE - the motors and sensors module called in response to tasks.
It's multi-bank and fairly big, but could be stripped down and run on a BOEbot with some porting work. Given that the source for this project came from BOEbot samples it isn't hard. This project put me in an "I heart PBasic" mood as it is a no drama programming environment.
    edited 2011-02-21 20:32
    Martin_H wrote: »
    Well said!
    edited 2011-02-22 13:56
    Well I got my batteries charged and was ready to make a video. But I started getting a COM failure error messages from the Say It module. One of the componets on its daughter board was really hot too. I pulled the module from the app mod socket and it cooled down. However if I plug it back in, it gets hot again. So it looks like the Say It module is dead/defective.
    It was connected properly as it plugs into the app mod socket and I was able to communicate using the default pins, so it's pretty goof proof.
    Long story short, I need to find a new way to do my compass/odometry demo.
    edited 2011-02-23 09:44
    I was just about to make a video of my flying antigravity cold fusion-powered S2. But my camera battery was dead, dangit!
    Martin, you sure know how to build drama and keep us coming back!
    edited 2011-02-23 12:11
    Erco, I know, I know. But I was all ready to go and the Say It module freaks out. But I called Parallax and they told me to send it back as it was within the warranty period. Hopefully a new one will arrive in short order.
    When I get the new one I can do the uber-demo. In the mean time I'm working on a smaller one.
    edited 2011-02-23 20:09
    I had to make this teaser video quickly: http://www.youtube.com/watch?v=mMQFV3KBx9g
    The key thing going on is that the robot has a command set in the EEPROM. Current commands include: move, turn, turn on one wheel, match compass heading, and halt. Future commands will include goto XY, grip, and release. In my first program I was processing commands directly from the Say It module, although I planned to write them to EEPROM for replay. Since the Say It module died, I can just use the EEPROM.
    As it moves you may notice the robot stop, alter course, then continue. That's Phil's code which compensates for lack of encoder granularity. Originally had my own servo and encode routines. But I read Phil's encoder document and began copying his code. By the time I was done it was Phil's encoder code which just smidgen of my code.
    At the end I zoom in on the LCD which shows the heading, the XY position, and the current command (HALT in this case). The idea is now that the robot knows its XY location it can compute a vector to any other XY location and go there.
    edited 2011-02-27 12:16
    The following are the updated source files.
    MotionScriptMain.bse - A generic motion script program. It replays commands and arguments from EEPROM.
    MotorsAndSensors.BSE - The motor and sensor routines. All the odometry work is done here.
    Gripper.bse - Bank 2 filled up so I moved the gripper code here
    Here's a video of a script being replayed:
    http://www.youtube.com/watch?v=OPb_5ag9ZVc
    Here's the byte stream motion script for the robot in that video:
    Commands DATA TaskTurnCompass, NORTH
    DATA TaskPause, 255
    DATA TaskMoveXY, 60, 60
    DATA TaskMoveXY, 60, 70
    DATA TaskMoveXY, -60, 70
    DATA TaskMoveXY, -60, 60
    DATA TaskMoveXY, 0, 0
    DATA TaskHalt
    All in all it was much more work than the simple path lets on. Trig using eight bit integer math where negative numbers in division are forbidden is no picnic. Even if your wheels don't slip or drop encoder counts, math truncation errors mount up. For example moving to 60,60 results in 59,59 and this compounds with each movement over time.
    edited 2011-02-27 14:59
    Nice results and worth waiting for, Martin_H! I'm with you on the integer math truncation errors adding up. What I learned on my Retrobot project was making each encoder tick a smaller unit for more pulses per foot to keep the error % smaller. IOW, the error between 259 & 260 units is smaller than 59 & 60.
    Be proud of your results, you achieved VG accuracy given that you had potential errors creeping in from the compass, encoder sensors, trigonometry and integer math. Way cool, Bravo! BTW, which compass sensor are you using?
    edited 2011-02-27 16:14
    Erco, thanks! This was indeed a fun project, and I learned a huge amount. Now that I've deep dived into Phil's code, I think I could port it to Spin if/when I switch to the Propeller. I agree that increased encoder granularity solves many problems. So the next robot I build is going to have quadrature encoders.
    My compass is Parallax's Hitachi HM55B Compass Module mounted on the back of the Ping bracket. It's a good sensor and the three wire synchronous serial interface is easy to use. Mounting it on the Ping saves room on the protoboard, and it's simple to adjust the compass reading for the declination of the Ping sensor.
    If I was buying one today I might consider an I2C model if I could find other I2C sensors. The BS2e's larger EEPROM and scratch pad RAM make a big difference in the kinds of programs I can write. But I keep bumping up against the 16 pin barrier.
  • WhitWhit Posts: 4,194
    edited 2011-02-27 17:04
    Nice project and video Martin_H!
    edited 2011-03-01 18:06
    Thanks Whit.
    Time for the next step. I use the compass sensor to zero out heading errors, but errors distance from origin will likely compound over time. So I need some way to zero that out as well. I can think of two ways:
    One way is to use the corner of the room as a baseline. Have the bot move South until it hits a wall, then move East until it is in the corner. Set XPOS and YPOS to some accepted value. I think this would work, but it strikes me as a bit brute force. Plus driving into a corner wastes time and invites getting stuck.
    What I'm going to do instead is mark the origin point, and use a sensor to allow the robot to know it is over the origin. The RFID sensor and tag seems like just the ticket. But my local Radio Shack didn't have the RFID sensors on sale. But Amanda Ward was kind enough to act as my proxy to buy one. So if I get a chance I'm going to try that this weekend.
  • RussHRussH Posts: 35
    edited 2011-03-17 12:33
    Hello, Which LCD are you using? is it a parallax product? I like the backlight colour. Thanks
    edited 2011-03-17 18:07
    RushH, it's just a white on blue backlight 2x16 parallel LCD I bought from Wulfden or Modern Device for $10. It's on homemade 117 serial driver board so it only uses one pin. Paul Anderson sells a kit which include the LCD and 117 serial chip for around $10 on E-bay.
    Excellent, thanks. I was about to get the parallax 4x20, but the rest of my panel is blue.
    I now have the adapter and display on their way from gravitech.
