How do you insert inline code in the forum posts? — Parallax Forums
Don MDon M Posts: 1,654
edited 2011-02-13 16:21 in Propeller 1
Besides attaching a zipped file how do you guys attach it so that it can be read in the post?
Sorry if this was discussed else where. I did a search but came up empty.
Thanks.
Don
  • AJMAJM Posts: 171
    edited 2011-02-13 16:00
    Don M wrote: »
    Thanks.
    Don
    Hi Don,
    code...
    [/'code]
    Without the apostrophes, the above three lines will do the following..
    code...
    edited 2011-02-13 16:14
    Just paste your code between[noparse]
    [/noparse] blocks.
    Alternatively you can highlight your code and click on the # icon in the editor.
    OBC
    edited 2011-02-13 16:15
    and there is a similar syntax for italics and [/'i] and quotes and [/'quote]
    (Without the apostrophes as well).
  • Don MDon M Posts: 1,654
    edited 2011-02-13 16:17
    So you just copy and paste from Propellor Tool in between 'code and /'code?
  • AJMAJM Posts: 171
    Correct. That's all you need to do.
