USB Programming
I have some questions regarding the propeller chip. I want to implement a USB interface to allow the chip to be reprogrammed at will. What is involved in doing this? I see that I could make a Prop Clip and integrate it into my board, which I am interested in doing, or buy the clip. I also plan to buy the 40 pin Propeller DIP chip, 5 MHz crystal, and 64KB EEPROM chip. Does the 64KB EEPROM have to be initially programmed? I do not have an EVAL board, and I am trying to avoid having to buy one. I would like all the programming to done through USB. Any guides on how to do this?
Thank you,
Joseph
Thank you,
Joseph
at least it comes in SOIC version that is easier to reflow solder by hobbiest.
Look at the Propeller Education Kit (PEK) tutorials for examples of minimal Prop circuitry on a breadboard. One of the "sticky threads" on this forum has links to all the PEK stuff.
