using a oscillator
I am working with a 5V @ 14.31818Mhz oscillator...and I want to use it as a clock on a 3.3V device (propeller and other). Can I run the clock through a 74LVC244 buffer to change the voltage to 3.3V (and then to the propeller and other device as the clock)? Will it work and will the timing still be at 14.31818Mhz?
