Considering the release a Joystick hack Object — Parallax Forums
Keith YoungKeith Young Posts: 569
edited 2011-02-09 10:49 in Propeller 1
You guys have been very helpful with a project I have been doing so I would like to return the favor. My project is currently using a USB Logitech Joystick as linked:
http://www.amazon.com/Logitech-Extreme-Joystick-Silver-Black/dp/B00009OY9U/ref=sr_1_1?ie=UTF8&qid=1296361030&sr=8-1
When you take it apart, you can remove the internal USB board and either simply plug in your own breadboard wires or even find the correct connection to make a PCB if you wish. There is enough space in there for a Prop on a custom made PCB if you wish to do so.
The joystick operates strangely in that the buttons aren't connected to high or low, but instead are pulsed on phases so that fewer wires can be used for the manufacturer. In order to get best use of this I made an assembly program, which is my first assembly program and also the first thing done almost "prefessional" enough to release.
Could you guys look over this and see if you like the idea? And also comment on what I need to change to make this releaseable.
Obviously it will need some sort of schematic.
CON
  _clkmode  = xtal1 + pll16x
  _xinfreq  = 5_000_000
  ADC_dpin  = 1
  ADC_cpin  = 2
  ADC_spin  = 0
  rudderc   = 0
  aileronc  = 1
  elevatorc = 2
  throttlec = 3
OBJ
  AD    : "MCP3208_fast_ADC"
  DB    : "FullDuplexSerial"
VAR
  long Shared
  word rudder, aileron, elevator, throttle
  long stack[256]
PUB Start
  AD.Start(ADC_dpin, ADC_cpin, ADC_spin, 0) 'Start ADC
  DB.Start( 31, 30, 0, 57600)               'Start Parallax Serial Terminal communication
  cognew(@entry, @Shared)                   'Begin running Assembly code
  cognew(Check_Act, @stack[0])              'Check status of joystick and act
Pub Check_Act
  dira[27]~~
  outa[27]~
  dira[26]~~
  outa[26]~
  repeat
    rudder   := AD.In(rudderc)        'Get ADC value of Rudder
    aileron  := AD.In(aileronc)       'Get ADC value of Aileron
    elevator := AD.In(elevatorc)      'Get ADC value of Elevator
    throttle := AD.In(throttlec)      'Get ADC value of Throttle
    DB.Dec(Shared)                    'Display status of Buttons
    DB.Str(String(13))
    DB.Dec(rudder)                    'Display Rudder value
    DB.Str(String(13))
    DB.Dec(aileron)                   'Display Aileron value
    DB.Str(String(13))
    DB.Dec(elevator)                  'Display Elevator value
    DB.Str(String(13))
    DB.Dec(throttle)                  'Display Throttle value
    DB.Str(String(13))
    if shared & butt1 == butt1        'Check if trigger is pulled. Trigger is Button 1
      outa[27]~~                      'Turn on light if trigger is pulled
    else
      outa[27]
    if shared & butt13 == butt13 and shared & butt14 == butt14
      outa[26]~~                      'If HAT switch is pushed forward and right
    else                              'turn on a light
      outa[26]~
DAT
           ORG      0
entry      mov Mem, PAR
           or       dira,pinn21
           or       outa,pinn21
           or       dira,pinn25
           or       outa,pinn25
           or       dira,pinn24
           or       outa,pinn24
{{         or       dira,pinn10      Un comment this area in order to use
           or       outa,pinn10      the 6 buttons on the base of the
           or       dira,pinn15      joystick and the throttle
           or       outa,pinn15
           or       dira,pinn17      ALL AREAS OF CODE COMMENTED OUT BELOW CONTROL
           and      outa,pinn17      JOYSTICK BASE. UNCOMMENT FOR THIS FUNCTION   }}
           or       dira,pinn27
           and      outa,pinn27
           xor      outa,pinn21
           xor      outa,pinn25
           xor      outa,pinn24
           'xor      outa,pinn10
           'xor      outa,pinn15
           mov      time,cnt             'Current clock loaded into time
           add      time,delay           'delay added to time
:Loop
           xor      outa, pinn21         'Pin 21 PHASE 1
           waitcnt  time,delay
           mov      temp, ina
           test     temp,   pinn23    wz '13 Hat Up
    if_z   or       button, butt13
    if_nz  andn     button, butt13
           test     temp,   pinn22    wz '14 Hat Right
    if_z   or       button, butt14
    if_nz  andn     button, butt14
           test     temp,   pinn19    wz '15 Hat Down
    if_z   or       button, butt15
    if_nz  andn     button, butt15
           test     temp,   pinn20    wz '16 Hat Left
    if_z   or       button, butt16
    if_nz  andn     button, butt16
           xor      outa, pinn21
           xor      outa, pinn25         'Pin 25 PHASE 2
           waitcnt  time,delay
           mov      temp, ina
           test     temp,   pinn20    wz '1 Trigger
           test     temp,   pinn19    wz '2 Secondary
    if_z   or       button, butt2
    if_nz  andn     button, butt2
           test     temp,   pinn22    wz '3 Bottom Left
    if_z   or       button, butt3
    if_nz  andn     button, butt3
           test     temp,   pinn23    wz '4 Bottom Right
    if_z   or       button, butt4
    if_nz  andn     button, butt4
           xor      outa, pinn25
           xor      outa, pinn24         'Pin 24 PHASE 3
           waitcnt  time,delay
           mov      temp, ina
           test     temp,   pinn20    wz '5 Top Left
    if_z   or       button, butt5
    if_nz  andn     button, butt5
           test     temp,   pinn19    wz '6 Top Right
    if_z   or       button, butt6
    if_nz  andn     button, butt6
           xor      outa, pinn24
{{           xor      outa, pinn10       'Pin 10 PHASE 4
           waitcnt  time,delay
           mov      temp, ina
           test     temp,   pinn12    wz '7
    if_z   or       button, butt7
    if_nz  andn     button, butt7
           test     temp,   pinn11    wz '8
    if_z   or       button, butt8
    if_nz  andn     button, butt8
           xor      outa, pinn10
           xor      outa, pinn15         'Pin 15 PHASE 5
           waitcnt  time,delay
           mov      temp, ina
           test     temp,   pinn13    wz '9
    if_z   or       button, butt9
    if_nz  andn     button, butt9
           test     temp,   pinn14    wz '10
    if_z   or       button, butt10
    if_nz  andn     button, butt10
           test     temp,   pinn12    wz '11
    if_z   or       button, butt11
    if_nz  andn     button, butt11
           test     temp,   pinn11    wz '12
    if_z   or       button, butt12
    if_nz  andn     button, butt12
           xor      outa, pinn15      }}
           wrlong   button, Mem
           jmp      #:Loop               ' Check trigger again using :loop
  button                byte    %000000000000000
  shareds               long    %000000000000000
  rudders               long    %000000000000000
  ailerons              long    %000000000000000
  elevators             long    %000000000000000
  throttles             long    %000000000000000
  delay     long    5000
  pinn21    long    |< 21
  'pinn10    long    |< 10
  pinn25    long    |< 25
  pinn24    long    |< 24
  'pinn15    long    |< 15
  'pinn17    long    |< 17
  pinn27    long    |< 27
  pinn20    long    |< 20
  pinn19    long    |< 19
  pinn22    long    |< 22
  pinn23    long    |< 23
  'pinn12    long    |< 12
  'pinn11    long    |< 11
  'pinn13    long    |< 13
  'pinn14    long    |< 14
  butt1     long    |<  0
  butt2     long    |<  1
  butt3     long    |<  2
  butt4     long    |<  3
  butt5     long    |<  4
  butt6     long    |<  5
 ' butt7     long    |<  6
 ' butt8     long    |<  7
 ' butt9     long    |<  8
 ' butt10    long    |<  9
 ' butt11    long    |< 10
 ' butt12    long    |< 11
  butt13    long    |< 12
  butt14    long    |< 13
  butt15    long    |< 14
  butt16    long    |< 15
  temp      long    0
  time      Res     1
  Mem       Res     1
  • AndreLAndreL Posts: 1,004
    edited 2011-01-29 21:50
    If it works, just package it into a clean object, so someone can use it from another program. Looks like its commented, so that's good. Then write up a little doc, make a demo or 2, and put it all into a nice ZIP, so people can use it. You can ALWAYS do version 1.1, 2.0, etc. so don't worry about it being perfect.
    Andre'
  • Keith YoungKeith Young Posts: 569
    edited 2011-01-30 00:19
    My progress so far. Please let me know what you see wrong etc. I'll probably eventually make an official thread including the hardware for this item since it lends itself very nicely to being put in a custom box with sliders and you could even fit a Prop inside the unit as it is keeping the professional look. Plus with it being $30 I think just about everyone could use one.
    Keith Young
    Jan 30 2011
                    This assumes colors of wires are the same throughout the manufacturing
                    history of this product. You may wish to check this so as to be sure
                    you aren't connecting this bass ackwards.
              Joystick  -----------------------------------------------------------------
                    Red     &#9532;  Pin 19 and Pull Up  3.3V   (I use 10Kohm)
                    Green   &#9532;  Pin 20 and Pull Up  3.3V
                    White   &#9532;  Pin 21
                    Yellow  &#9532;  Pin 22 and Pull Up  3.3V
                    Pink    &#9532;  Pin 23 and Pull Up  3.3V
                    Orange  &#9532;  Pin 24
                    Grey    &#9532;  Pin 25
                    Brown   &#9532;  3.3V
      Rudder Pot    Black   &#9532;  1st Channel ADC
                    Blue    &#9532;  GND
                    Red     &#9532;  3.3V
      Aileron Pot   Green   &#9532;  2nd Channel ADC
      Elevator Pot  White   &#9532;  3rd Channel ADC
                    Black   &#9532;  GND
              Joystick Base  ------------------------------------------------------------
                    Orange  &#9532;  Pin 15
                    Black   &#9532;  Pin 14 and Pull Up  3.3V
                    Brown   &#9532;  Pin 13 and Pull Up  3.3V
                    Grey    &#9532;  Pin 12 and Pull Up  3.3V
                    Pink    &#9532;  Pin 11 and Pull Up  3.3V
                    Yellow  &#9532;  Pin 10
                    White   &#9532;  GND
       Throttle Pot Green   &#9532;  4rth Channel ADC
                    Red     &#9532;  3.3V
    CON
      ADC_dpin  = 1
      ADC_cpin  = 2
      ADC_spin  = 0
      rudderc   = 0
      aileronc  = 1
      elevatorc = 2
      throttlec = 3
    OBJ
    VAR
      long Shared
      long stack[256]
    PUB Start
    Pub Check_Act
      dira[27]~~
      outa[27]~
      dira[26]~~
      outa[26]~
      repeat
        DB.Str(String(13))
        DB.Str(String(13))
        DB.Str(String(13))
        DB.Str(String(13))
        DB.Str(String(13))
        else
          outa[27]~
          outa[26]~
    DAT
               ORG      0
    entry      mov Mem, PAR
               or       dira,pinn21
               or       outa,pinn21
               or       dira,pinn25
               or       outa,pinn25
               or       dira,pinn24
               or       outa,pinn24
               or       outa,pinn15
               or       dira,pinn27
               and      outa,pinn27
               xor      outa,pinn21
               xor      outa,pinn25
               xor      outa,pinn24
               'xor      outa,pinn10
               'xor      outa,pinn15
    :Loop
               waitcnt  time,delay
               mov      temp, ina
               xor      outa, pinn21
               waitcnt  time,delay
               mov      temp, ina
               xor      outa, pinn25
               waitcnt  time,delay
               mov      temp, ina
               xor      outa, pinn24
               waitcnt  time,delay
               mov      temp, ina
               xor      outa, pinn10
               waitcnt  time,delay
               mov      temp, ina
               xor      outa, pinn15      }}
               wrlong   button, Mem
      delay     long    5000
      pinn21    long    |< 21
      'pinn10    long    |< 10
      pinn25    long    |< 25
      pinn24    long    |< 24
      'pinn15    long    |< 15
      'pinn17    long    |< 17
      pinn27    long    |< 27
      pinn20    long    |< 20
      pinn19    long    |< 19
      pinn22    long    |< 22
      pinn23    long    |< 23
      'pinn12    long    |< 12
      'pinn11    long    |< 11
      'pinn13    long    |< 13
      'pinn14    long    |< 14
      butt1     long    |<  0
      butt2     long    |<  1
      butt3     long    |<  2
      butt4     long    |<  3
      butt5     long    |<  4
      butt6     long    |<  5
     ' butt7     long    |<  6
     ' butt8     long    |<  7
     ' butt9     long    |<  8
     ' butt10    long    |<  9
     ' butt11    long    |< 10
     ' butt12    long    |< 11
      butt13    long    |< 12
      butt14    long    |< 13
      butt15    long    |< 14
      butt16    long    |< 15
      temp      long    0
      time      Res     1
      Mem       Res     1
    edited 2011-01-31 14:33
    This object has been released.
    http://obex.parallax.com/objects/706/
    I can assure you that this object can drive a servo location and it's speed, it can read any combination of its buttons, and read every axis when those functions are added. They just are not included in this demo at the moment. I don't want you to feel you may be paying $30.00 for a joystick that won't work.
    I will likely make a YouTube Video shortly.
    Please comment as this is my first OBEX upload, I'd like to be sure I'm not missing anything.
    Anyone who already owns this type of joystick please test this. See if the instructions are clear and if you can get it working easily your first attempt.
    Someone with more electronics experience may know for example if a different pull up resistor value is more optimal.
    edited 2011-01-31 15:18
  • RonPRonP Posts: 384
    edited 2011-02-01 01:19
    roughwood,
    Nice Project. My other Hobby the more expensive one is flying RC 3D Heli's. I was wondering are you planing on flying a RC plane or something with your rig. I think that would be neat to fly a RC plane with that set up. Just curious. Going to check out the new Object.
    -Ron
    edited 2011-02-01 01:35
    This is for an FPV aircraft for both fun and aerial photography which will help pay for the project. Search FPV in YouTube and you'll see what that part of the project will entail. The main thing will be operating the real camera and protecting it since it will be pretty expensive. Communication failsafes, autopilot return, things of that nature will take up the majority of my work.
    This joystick is fully hackable so you could use throttle for collective, and twist of the joystick for the tail collective. Plenty of buttons for all the channels on any plane. 16 buttons if I recall, plus I set it up so you can take any combination of those buttons.
    edited 2011-02-01 02:05
    Sounds like you have your work cut out for you. At this point I don't have the skills to write a program for CCPM to use it for a Helicopter. Plus I don't see an advantage for 3D flying. But I think it would be a blast in a little electric plane. Nice work on the Object l think you explained it well compared to some of the Objects in the Exchange. I don't know PASM and i am just learning SPIN so take it for what its worth. 2 cents :smile:
    edited 2011-02-01 13:32
    It won't help for 3D flying no lol.
    But for general flight and motion control, even for Hydra games etc, this thing could be pretty cool. Plus with PWM etc it can be made to work on an Arduino or pretty much whatever someone happens to be using.
    Can anyone say if they've gotten this to work or if they're having trouble? I am about to hit all my exams and won't have much time to fix any problems pretty soon here.
