building a KeyPad — Parallax Forums
building a KeyPad
ftj405ftj405 Posts: 8
edited 2011-02-07 13:45 in General Discussion
i have an old wireless phone that has the keypad on a seperate board. it has nine connector pins to connect to.
Can anyone tell me what i need to get this to interface to a basic stamp 2 and a propeller..
From the pictures attached, it looks like it has a resistor for each key..
    edited 2011-02-06 19:25
    Get out your ohm meter and do some testing. You should be able to figure it out pretty fast.
  • LeonLeon Posts: 7,620
    edited 2011-02-07 04:49
    I think it uses conductive pads on the keys. It has 18 keys, which ties in with the nine connections - 5 * 4 = 20. One will be ground.
    There's an object (I think it comes with the Prop Tool) for interfacing a 4 x 4 keypad with the Prop. It (your keypad) might work with a modified version of the object.
    When I used the object I had to add 0.1uF capacitors to each column pin to get to work correctly (I think my wires were too long).
    I wrote an object that stores the keypresses until they are asked for by the main object. I can set the time I want the keypress to stay valid so old keypresses can be ignored.
    If you want I'll dust it off and post it. I'm pretty sure I posted it once but the version I posted had some bugs. I never did get the cleaned up version posted to OBEX. Let me know if you're interested in it.
    The 4x4 keypad object should give you a good idea on how to hook up your keypad.
