Spinneret Web Server Geting started help
Hello
i just got my Spinneret Web Server in the mal today and went to hook it up but i cant seem to get the guy talking to my prop tool the lights for TX and RX are not on.is there anything i need to do to make this work.
Do you have a prop plug? Is the Spinneret connected to your local network?
the setup is simple the vss is jumped to a bread boardboard
the vdd is jumped to a bread board board
the prop plug and web server is connected to power and ground on the connected breadboard
http://www.agaverobotics.com/spinneret/controlpanel.htm
The prop plug is connected to the prop plug 4 pin connection, J2. I have 5V going into J6, positive on pin 2 and ground on pin 3
You can power the Spinneret with 3 to 3.3V. You have to connect J1 - Pin 1 to 3 - 3.3V and pin 2 to ground.
Saying
Does not help me help you. Explain what you're doing.
sorry to post such a stupid question...................................
http://forums.parallax.com/showthread.php?127298-HTTP-Demo-(updated-11-22-2010-12-35am)
is there any reason i can not ping the ip address that i coded into the device
It's what I've been working with, and it responds to a ping. Just remember not to include the HTTP port number in the IP address you're pinging.
Not necessarily. Most web servers use port 80, which is what your browser will default to if you don't specify it. But incoming SYNs to port 80 are often blocked by routers, firewalls, or even one's ISP. So, for this kind of work from a home network, another port is almost always used. The choice of 3456 is entirely arbitrary.
I want to use port 8801 so i go to my web browser and type
192.***.40.***:8801
but this returns page can not be displayed do i need to foward this from my router
CON _clkfreq = 80_000_000 _clkmode = xtal1 + pll16x socket = 0 [color=red] listenPort = 3456'───┬── Your port of choice goes here ; typically between 0 and 65535[/color] ' │ Note: If you use port 80, then you don't need to specify { ├──┐ the ':xxxx' at the end of the HTTP address, however http://24.253.241.231:xxxx some IP's block port 80. In your router you will └────────────┤ need to configure it so that the port is forwarded. │ This number can be found at some place like... http://whatismyipaddress.com Note: The Above method gets you on the entire web, if you just want local network access to the Spinneret, then you don't need to use port forwarding, and you can use the static IP address instead. You still need to specify the port (':xxxx') if it's something other than port 80. http://192.168.0.50:xxxx or (if using port 80)... http://192.168.0.50 }can anyone tell me what the J6 PIN 1 is for......
Te datasheet states that its a IOs erial port can this be used for a LCD ?
As an alternative, you could also supply 5V power through the daughterboard socket (J1). Parallax carries a daughterboard with a wall-transformer input (PWR-I/O-DB) that can be used to power the Spinneret. It requires connecting three of its configuration header pins together to bring power to the daughterboard socket. It also provides six three-pin servo-style headers, four of which are connected to dedicated Prop Pins (but without the voltage translation).
