RcTime Voltage Measurement
I am using a BS2 to measure DC voltage. My reference was an article EME System (http://www.emesystems.com/BS2rct.htm) to design the circuit. I had to amplify incoming voltage from 0-21 mV to 0 - 3.7V using an LM359 Op Amp, and this works perfectly. The circuit diagram and code are attached.
When I read the RC value, I am getting wild numbers that eventually stabilize to 1 and then nothing happens. I tried changing the delay time in the loop but that didn't do anything.
Can anyone spot what I am doing wrongly? The amplification works and the RcTime circuit and code are very simple. Not sure what is going on! Thanks in advance for any help..
Al
Al
' {$STAMP BS2} ' {$PBASIC 2.5} ' RCtime stuff Sig PIN 14 rcSig VAR Word LOW Sig again: RCTIME Sig, 0, rcSig ' measure RC discharge time LOW Sig DEBUG CLS, HOME, DEC ? rcSig ' display result PAUSE 500 GOTO againThis is the RCTIME code that you should be trying and can you see the differences in Basic Stamp Editor help file and your code above.' RCTIME1.BS2 ' This program shows the standard use of the RCTIME instruction measuring ' an RC charge/discharge time. Use the circuit in the RCTIME description ' (in the manual) with R = 10K pot and C = 0.1 uF. Connect the circuit to ' pin 7 and run the program. Adjust the pot and watch the value shown on ' the Debug screen change. ' {$STAMP BS2} ' {$PBASIC 2.5} RC PIN 7 result VAR Word Main: DO HIGH RC ' charge the cap PAUSE 1 ' for 1 ms RCTIME RC, 1, result ' measure RC discharge time DEBUG HOME, DEC result ' display value PAUSE 50 LOOP ENDJust remember that the RCTIME command isn't the only way for Stamp to measure voltage and they are.1) Analog Digital Converters(ADC) which uses SHIFTIN command (From Stamp Works PDF)
2) Using a 555 Timer IC which uses PULSIN command (From Stamp Works PDF)
Al
Still, The ADC0831 is the best way to go, and you have success with that. Stick with it!
