Drawing Schematics - Old School?
For drawing circuit schematics, is it acceptable to draw resistors with a small rectangle and a line at each end representing the wire connections?
The reason I ask, is because the electronics template shown below does not include the typical zig-zag schematic symbol for a resistor. Has the zig zag become old school?
It, unlike the rectangle, tells the observer immediately what the component is; no guessing its function!
DJ
-Andy Rooney
I mean, where's the freaking coil symbol? Just another rectangle. But what's worse is the set of IEC symbols for logic gates. For example, here's what someone thinks will be instantly recognized as an XOR gate:
Yet another dang vanilla rectangle!
I contend it's much easier to read a schematic whose elements have distinctive shapes, rather than being just boxes with text in them. This is because human perception is very tuned to geometrical figures. Systems that have evolved over time tend to be much more expressive and recognizable than those designed by a committee. Who are those IEC dweebs anyway?
-Phil (sitting in for Andy Rooney)
DJ
Guess it's a good thing I play with squares, boxes, and rectangles then.... lol@Phil
Little boxes made of silicon.
Little boxes on the leadframe.
Little boxes all the same!"
Beau, I'm impressed that you can keep all of that straight. Just out of curiosity, what is your screen resolution?
Resistor
Trimpot
Pot
LDR
Zig-zag was all I ever knew, beginning in 1960. I can see the convenience and utility of the rectangle, but I could never embrace it.
--Bill
and yes the IEC is so vague ...
Peter
Interesting, if you study enough engineering the resistor, capacitor, coil, and amplifiers are analogues for mechanical systems as well and other engineering disciplines use these symbols to represent similar Physics.
Like most things these days, I've had to learn to read a wide varietly of means of expression in order to study what others are saying, but I retain my own vocabulary for communication that is a much smaller subset.
There was a time when it seems that industries and governments could enforce standards, but that times seems to have come and gone.
Standards are wonderful things... so many to choose from!
Whilst we are at it who had the brilliant idea to push simple squares as the symbols for logic gates instead of the nice old rounded AND and the OR with a concave side for the inputs.
Box logic is NOT logical... bad pun not nor and LOLs
My head does this with those gates
Peter
Yes but what happens when you are a current going the other way? Negative resistance! Also when you finally make it up to the top of the ramp the implication would be that you have more potential energy than you had when you were at bottom. Which is clearly not the case for charge carriers in a resistive medium.
I like the zigzags, it suggests a slalom course for current carriers which is sure to slow them down and drain their energy as they swerve one way and another. Given my mental picture of electrons bumping around in a material as they travel that seems just perfect.
