Drawing Schematics - Old School? — Parallax Forums
HumanoidoHumanoido Posts: 5,770
edited 2011-02-01 09:08 in General Discussion
For drawing circuit schematics, is it acceptable to draw resistors with a small rectangle and a line at each end representing the wire connections?
The reason I ask, is because the electronics template shown below does not include the typical zig-zag schematic symbol for a resistor. Has the zig zag become old school?
    edited 2011-01-29 00:55
    I think the zig-zag resistor symbol is exclusive to the U.S. AFAIK, almost everyone else uses the rectangle.
  • LeonLeon Posts: 7,620
    edited 2011-01-29 02:15
    We used the zigzag here in the UK when I was young.
  • MoskogMoskog Posts: 556
    edited 2011-01-29 05:39
    I never used the zig-zag symbol, always been using the rectangle. I also learned to use a circle around the transistor symbol. Fuses are rectangles with a line through (like here), not the sine-wave symbol often seen.
    edited 2011-01-29 15:00
    A rectangle makes a convenient place to indicate the value ... just sayin.
    edited 2011-01-29 15:28
    ...zigzag old school?
    It, unlike the rectangle, tells the observer immediately what the component is; no guessing its function!
    DJ
    edited 2011-01-29 15:40
    Most schematics have the parts identified: R1, C1, etc. with the value. That removes any uncertainty.
    edited 2011-01-29 16:00
    As a matter of personal taste, I hate the rectangles. I also hate it when polarized caps are drawn with two rectangles (one filled), rather than as an arc and a line with a + symbol to indicate polarity. Rectangles are for ICs, dagnabbit! But what I hate most of all are schematics drawn with brown and dark green lines. (Eagle?) Yecch!
    -Andy Rooney
    edited 2011-01-29 16:10
    I'm with Phil on this, or was that Andy...
    edited 2011-01-29 16:56
    Oh gosh, I see they're ruined relays now, too:
    I mean, where's the freaking coil symbol? Just another rectangle. But what's worse is the set of IEC symbols for logic gates. For example, here's what someone thinks will be instantly recognized as an XOR gate:
    Yet another dang vanilla rectangle!
    I contend it's much easier to read a schematic whose elements have distinctive shapes, rather than being just boxes with text in them. This is because human perception is very tuned to geometrical figures. Systems that have evolved over time tend to be much more expressive and recognizable than those designed by a committee. Who are those IEC dweebs anyway?
    -Phil (sitting in for Andy Rooney)
    edited 2011-01-29 19:46
    ...in my best Gollem voice - "we hates them IEC symbols....yes, we hates them!"
    DJ
    edited 2011-01-29 21:56
    Hmmm,
    Guess it's a good thing I play with squares, boxes, and rectangles then.... lol@Phil
    1024 x 781 - 309K
    edited 2011-01-29 22:39
    "Little boxes on the leadframe.
    Little boxes made of silicon.
    Little boxes all the same!"
    -with apologies to Janis Joplin :)
    Beau, I'm impressed that you can keep all of that straight. Just out of curiosity, what is your screen resolution?
    edited 2011-01-29 22:44
    "Beau, I'm impressed that you can keep all of that straight. Just out of curiosity, what is your screen resolution?" - 5120x1024 (<-Dual Monitor Heads ; each head 2560x1024)
    edited 2011-01-29 22:49
    Whoa! Cinerama! That must be on a non-PC workstation, then, right?
    edited 2011-01-29 23:19
    Does anyone have a good key to the meaning of all those rectangles?
    edited 2011-01-30 04:43
    From left to right:
    Resistor
    Trimpot
    Pot
    LDR
    edited 2011-01-30 07:28
    The Pots #2 and 3 from left could also have been with three connectors, the arrow should have been against the rectangle, not through and with its own connector.
  • Bill ChennaultBill Chennault Posts: 1,198
    edited 2011-01-30 07:31
    All--
    Zig-zag was all I ever knew, beginning in 1960. I can see the convenience and utility of the rectangle, but I could never embrace it.
    --Bill
    edited 2011-01-30 08:38
    the only bad thing of zig zags is I can mistake them as a inductor if its printed out bad OR heavy JPEG compression is used and muddys the photo ..
    and yes the IEC is so vague ...
    Peter
  • ajwardajward Posts: 1,130
    edited 2011-01-30 09:34
    If I'm doing a quick sketch for my own purposes, I'll use a lot of rectangles (or trapeziods!) with copious notes. If laying the diagram out for someone else, I prefer the "old skool" symbols... zig-zags, lines/arcs, etc... Just me! :-)
    edited 2011-01-30 09:47
    I just checked the schematic symbols supplied with the Pulsonix PCB software I use, and it has a zigzag one as well as the more usual box one that I use. It also has a zigzag pot and trimpot.
    edited 2011-01-30 13:54
    Express PCB also have this zig zag stuff. I use to make my own customized rectangle ones, eh...
    edited 2011-01-31 03:58
    I certainly use the zig-zag for a resistor as that is what I learned as standard in th1960's. Some people claim the rectangle is European, but I suspect it is a child of computer graphics.
    Interesting, if you study enough engineering the resistor, capacitor, coil, and amplifiers are analogues for mechanical systems as well and other engineering disciplines use these symbols to represent similar Physics.
    Like most things these days, I've had to learn to read a wide varietly of means of expression in order to study what others are saying, but I retain my own vocabulary for communication that is a much smaller subset.
    There was a time when it seems that industries and governments could enforce standards, but that times seems to have come and gone.
    edited 2011-01-31 06:55
    [QUOTEThere was a time when it seems that industries and governments could enforce standards, but that times seems to have come and gone.[/QUOTE]
    Standards are wonderful things... so many to choose from! :lol:
    edited 2011-01-31 10:48
    Give me zigzag resistors every time. Where is the meaning in a rectangular box?
    Whilst we are at it who had the brilliant idea to push simple squares as the symbols for logic gates instead of the nice old rounded AND and the OR with a concave side for the inputs.
    edited 2011-01-31 14:28
    Heater. wrote: »
    Box logic is NOT logical... bad pun not nor and LOLs
    My head does this with those gates
    Peter
    edited 2011-02-01 08:44
    Just a thought but rather than a rectangle shouldn't a resistor have been designed as a ramp(triangle) as moving up a ramp or hill you meet resistance.
    skylight,
    Yes but what happens when you are a current going the other way? Negative resistance! Also when you finally make it up to the top of the ramp the implication would be that you have more potential energy than you had when you were at bottom. Which is clearly not the case for charge carriers in a resistive medium.
    I like the zigzags, it suggests a slalom course for current carriers which is sure to slow them down and drain their energy as they swerve one way and another. Given my mental picture of electrons bumping around in a material as they travel that seems just perfect.
