NUMBERS saving over sequential variables
Keith Young
When running something such as
all of the displayed values will display as I would expect to see the d number. If I comment out the d number, the 3 remaining displayed numbers all show as I expect to see the c number.
I've found a slow, sort of duct tape way, of fixing the issue is to immediately DBG. However I am using TV and I need these numbers to be established before a screen refresh.
I've tried several ways of saying the same thing trying to trick the program in to working but it just doesn't want to without going super slow.
Is this a common problem? Maybe I need to treat these variables in some special way in DAT? For example astr long "55555", 0 or something?
If I find a fix I'll be sure to post it here. I've spent alot of time troubleshooting this error and I expect it to be common.
astr := NUM.ToStr(anum, NUM#DEC5) bstr := NUM.ToStr(bnum, NUM#DEC5) cstr := NUM.ToStr(cnum, NUM#DEC5) dstr := NUM.ToStr(dnum, NUM#DEC5) DBG.Str(astr) DBG.Str(bstr) DBG.Str(cstr) DBG.Str(dstr)
Basically you got what you asked for.
pub print5(n) | div n := -9_999 #> n <# 99_999 ' limit to 5 characters if (n < 0) ' if negative dbg.tx("-") ' print sign ||n ' remove sign div := 1_000 else div := 10_000 repeat while (div > 0) dbg.tx(n / div + "0") ' extract & print digit n //= div ' remove printed digit div /= 10 ' update divisorMy problem is enhanced also due to the fact that my program uses more space than typical Graphics_Demo styled commands will allow. I am using what PotatoHead was kind enough to point out here http://forums.parallax.com/entry.php?86-Ripple-Draw
Which basically draws the screen 8 times, so to have to display the text for each update makes everything that much slower.
I mainly need to update the values right before I run the 8 screen Draws. My ADC is spitting out numbers very quickly, I just need to grab the values right before Draw, and have the displayed values remain the same through all 8 draws.
If Graphics.Spin had a Dec command or if Numbers.Spin or Simple_Numbers.Spin would just let me save a value I'd be all set hehe. Trying to hack them in to working just hasn't been successful yet.
It doesn't because it can only print a string, not indiviual characters. If you create enough buffers for your values then the code I showed you can work -- just pass the individual buffer for the desired ADC channel, then print them later. Assuming you don't have negative values and your ADC reading will fit into four digits, you can change my number to string conversion like this:
pub num4str(n, strbuf) | div n := 0 #> n <# 9_999 ' limit to 4 characters bytefill(strbuf, 0, 5) ' clear buffer case n ' set divisor for n 0..9 : div := 1 10..99 : div := 10 100..999 : div := 100 other : div := 1000 repeat while (div > 0) byte[strbuf++] := n / div + "0" ' extract & print digit n //= div ' remove printed digit div /= 10 ' update divisorUpdated code:
repeat shareds := shared rudders := rudder ailerons := aileron elevators := elevator throttles := throttle GR.Setup(2, 12, 128, 96, bitmap_base) Draw 'frame++ ORIGINAL GR.Setup(2, 12, 128-32, 96, bitmap_base+$600) 'draw strip to the right... Draw 'frame++ ORIGINAL GR.Setup(2, 12, 128-64, 96, bitmap_base+$C00) 'draw strip to the right... Draw 'frame++ ORIGINAL GR.Setup(2, 12, 128-96, 96, bitmap_base+$1200) 'draw strip to the right... Draw frame++ GR.Setup(2, 12, 128-128, 96, bitmap_base+$1800) 'draw strip to the right... Draw 'frame++ ORIGINAL GR.Setup(2, 12, 128-160, 96, bitmap_base+$1E00) 'draw strip to the right... Draw 'frame++ ORIGINAL GR.Setup(2, 12, 128-192, 96, bitmap_base+$2400) 'draw strip to the right... Draw 'frame++ ORIGINAL GR.Setup(2, 12, 128-224, 96, bitmap_base+$2A00) 'draw strip to the right... Draw 'frame++ ORIGINAL frame := frame + 3 PUB Draw GR.Clear num5(shareds, @numstr) GR.Text(-100, 80, @numstr) GR.Finish num5(rudders, @numstr) GR.Text(-100, 70, @numstr) GR.Finish num5(ailerons, @numstr) GR.Text(-100, 60, @numstr) GR.Finish num5(elevators, @numstr) GR.Text(-100, 50, @numstr) GR.FinishI was hoping to just do the number to string right at the top so the program wouldn't feel the need to run all those Spin instructions 8 times per screen refresh. Once I add on the rest of the functionality (lines and arcs etc) I think this method of converting 8 times per screen refresh to avoid the issue of NumToStr type command overwriting themselves won't be ideal.
There's got to be a way to get a permanent value from a number to string. Bytemove wasn't doing the trick either strangely.
CON _clkmode = XTAL1|PLL16X _xinfreq = 5_000_000 CON ncnt = 4 ' number of conversions ccnt = 12 ' size of temporary buffer OBJ FDS: "FullDuplexSerial" NUM: "Numbers" VAR byte storage[ncnt*ccnt] ' temporary buffers PUB null | n, str[4] NUM.Init FDS.start(31, 30, %0000, 115200) waitcnt(clkfreq*3 + cnt) [COLOR="blue"]' convert ncnt values[/COLOR] repeat n from 0 to constant(ncnt -1) bytemove(@storage[n*ccnt], NUM.ToStr(?cnt, NUM#SDEC11), ccnt) [COLOR="blue"]' display ncnt values[/COLOR] repeat n from 0 to constant(ncnt -1) FDS.str(@storage[n*ccnt]) FDS.tx(13)It converts 4 (ncnt) random numbers (?cnt) which occupy at most 12 characters (ccnt, 11 chars + string terminator). The string generated by ToStr is copied immediately into the temporary storage for this particular number (@storage[n*ccnt]) and displayed later.There are other ways to manage a partially buffered screen. That ripple draw method is a great general purpose case, that will work for most anything, but... It can be improved significantly, depending on what the screen is doing. It's likely a different drawing order, and or some intelligent management of the strips can yield you some screen speed.
If you've got the buffer space, 4 strips may work better, or the technique could be extended some to smaller regions. So, a full draw, on occasion, with rapid secondary draws to update text values.
Plus warning screens and menu screens. A GUI for GPS waypoint system.
Video Overlay will also be necassary, but that will likely be done on Backpack on another screen.
Basically my buddy worked it out to take aerial photography making enough money to pay for the equiptment and a couple beers. So I'm making a plane that can fly to waypoints, be flown by hand or autopilot, have a pan tilt zoom camera, and the camera is expensive so pilot interupt etc is necessary as well as GPS location in case of crash. Lots of menu and probably 2 TV's being driven. One with say 2 way telemetry and the other controling forward looking pilot camera and pan tilt zoom camera for picture taking.
So there will be a plane with 1-2 Props and ground station with 1-2 Props.
If it were me, I would make a draw routine for the geometry, and I would use 6 or 8 strips. Locate your text elements in the strips, and refrain from mixing them with the geometry. That way, the drawing of text can be decoupled from the geometry. Draw the geometry each screen update, and the text, every few updates. The illusion of a rapid display will be there, and will filter out noise from the text data anyway.
(unless that's really important)
I think I would also seriously consider pre-computing the text elements, storing them as images that can just be drawn to the screen quickly. If the text is "ORed" with the geometry, it can overlay it where needed.
So that's about what is possible with the strips. Draw the center 4 strips or 6 strips constantly, adding in the occasional draw of the side strips for a optimal display draw, using the partial buffer method.
To get better than that, it's going to need to be individual tiles. Define them in the HUB, draw to them, then "pop" them on the screen, by changing the tile addresses when they are complete. No tearing that way, and fairly high complexity objects can be drawn without the user seeing it.
The set tile address method, and the window demonstration in my commented graphics_demo.spin show how this is done.
You might also be able to clone a few areas of the screen too.
When you get more of the graphics running, and know more about the data, more might be possible to say.
I didn't want to distract. Sometimes it's fun to think of different ways to do graphics, and that might not be the point. Sure sounds like a great project though. Maybe you will feel about 57.3 times better about finishing it! That's how it works for me.
I don't have any direct plan for how to do everything, how to make the menus work. I just have a list of attributes which will both grow and shrink. This project is still very much in the brainstorming phase. Most of what I'm doing right now is making a sort of "cardboard model". Making sure I can control the speed and location of a Servo wirelessly with the joystick. Simulating a loss of aircraft power, then re-establishing communication remotely.
if communication loss
autopilot climb to 200ft
regain communications
etc
This will probably take me 4 hours a day till Summer.
