Translate SPIN to PASM (Using phsa)
Hi there,
I'm trying to translate that:
Into PASM.
So I tried to translate one loop and applied that to all.
So far, here is what I did:
But of course, it's not working.
Everything is pretty simple, but I'm still not able to find the issue
I'm suspecting some issues on the MOV with the address being assigned instead of the values, or the opposite.
So all the suggestions are welcome. I would like to understand what I'm doing wrong.
JM
PUB PulseTheStepPin(StepPin, TotalSteps) | RampingSteps, RunningSteps, Counter, CycleOffset
if TotalSteps > RAMPING_RANGE
RampingSteps := SPEED_RANGE
RunningSteps := TotalSteps - RAMPING_RANGE
else
RampingSteps := TotalSteps / 2
RunningSteps := TotalSteps // 2
CycleOffset := MIN_SPEED
ctra[30..26] := %00100 ' Configure Counter A to NCO
ctra[5..0] := StepPin
frqa := 1
dira[StepPin]~~
Counter := cnt
repeat RampingSteps
phsa := -HIGH_PULSE_WIDTH
waitcnt(Counter += CycleOffset--)
StepCount++
repeat RunningSteps
waitcnt(Counter += CycleOffset)
StepCount++
repeat RampingSteps
waitcnt(Counter += CycleOffset++)
StepCount++
Into PASM.
CON
HIGH_PULSE_WIDTH = CLK_FREQ / 500_000 'This is the setting for the minimal step pulse width.
MIN_SPEED = 7_000 'Adjust this setting to overcome any moments of inertia you may have in your mechanical system.
MAX_SPEED = 11_000 'Settings above 11,000 will result in step count inaccuracies for a 2000 uStep drive and settings
'above 12,000 will cause the G251 to falter.
'Do not alter
SPEED_RANGE = MAX_SPEED - MIN_SPEED
RAMPING_RANGE = SPEED_RANGE * 2
PUB PulseTheStepPinWithCog(StepPin, TotalSteps) | RampingSteps, RunningSteps, Counter, CycleOffset
else
frqa := 1
dira[StepPin]~~
Counter := cnt
LONG[_RampingSteps] := RampingSteps
LONG[_RunningSteps] := RunningSteps
LONG[_CycleOffset] := CycleOffset
LONG[_Counter] := Counter
COGNEW(@cogstart, @cogstart)
DAT
ORG 0
cogstart
MOV _index, _RampingSteps
loop1 MOV phsa, _HIGH_PULSE_WIDTH
WAITCNT _Counter, _CycleOffset
SUB _CycleOffset, #1
SUB _Index, #1
TJNZ _Index, loop1
MOV _index, _RunningSteps
loop2 MOV phsa, _HIGH_PULSE_WIDTH
SUB _Index, #1
TJNZ _Index, loop2
loop3 MOV phsa, _HIGH_PULSE_WIDTH
ADD _CycleOffset, #1
SUB _Index, #1
TJNZ _Index, loop3
end JMP end
_index LONG $00000000
_RampingSteps LONG $00000000
_RunningSteps LONG $00000000
_CycleOffset LONG $00000000
_Counter LONG $00000000
_HIGH_PULSE_WIDTH LONG $FFFFFFF6
JM
Example:
end jmp #end
will create an endless loop.
Some advice that I hope you will not take in the wrong way: Start REALLY simple and small. You will be glad you did.
-h
I changed the 4 jumps I have.
I have also added some checkpoints. OUT1 to OUT3 are connected to LEDs so I know when the application reach a certain point.
So far, look like the WAITCNT is waiting way longer than what it's supposed. So I will try to dig there.
JM
PUB PulseTheStepPinWithCog(StepPin, TotalSteps) | RampingSteps, RunningSteps, Counter, CycleOffset if TotalSteps > RAMPING_RANGE RampingSteps := SPEED_RANGE RunningSteps := TotalSteps - RAMPING_RANGE else RampingSteps := TotalSteps / 2 RunningSteps := TotalSteps // 2 CycleOffset := MIN_SPEED ctra[30..26] := %00100 ' Configure Counter A to NCO ctra[5..0] := StepPin frqa := 1 dira[StepPin]~~ Counter := cnt _RampingSteps := RampingSteps _RunningSteps := RunningSteps _CycleOffset := CycleOffset _HIGH_PULSE_WIDTH := -HIGH_PULSE_WIDTH COGNEW(@cogstart, @table) DAT ORG 0 cogstart {{ repeat RampingSteps phsa := -HIGH_PULSE_WIDTH waitcnt(Counter += CycleOffset--) StepCount++ }} MOV dira, #%0000_0000_0000_1111 MOV _index, _RampingSteps MOV outa, #%0000_0000_0000_1000 MOV _Counter, CNT loop1 MOV phsa, _HIGH_PULSE_WIDTH ADD _Counter, _CycleOffset WAITCNT _Counter, #0 SUB _CycleOffset, #1 SUB _Index, #1 TJNZ _Index, #loop1 MOV outa, #%0000_0000_0000_0100 MOV _index, _RunningSteps loop2 MOV phsa, _HIGH_PULSE_WIDTH WAITCNT _Counter, _CycleOffset SUB _Index, #1 TJNZ _Index, #loop2 MOV outa, #%0000_0000_0000_0010 MOV _index, _RampingSteps loop3 MOV phsa, _HIGH_PULSE_WIDTH WAITCNT _Counter, _CycleOffset ADD _CycleOffset, #1 SUB _Index, #1 TJNZ _Index, #loop3 end JMP end _index LONG $00000000 _RampingSteps LONG $00000000 _RunningSteps LONG $00000000 _CycleOffset LONG $00000000 _Counter LONG $00000000 _HIGH_PULSE_WIDTH LONG $FFFFFFF6
You are starting a process in another COG - you need to get the data you need from the first COG (running SPIN) to the second COG (running PASM).
I would try some exercises using just one process self-contained in one COG to get familiar with PASM before trying moving to a process like this. The Propeller Education Kit Labs have some really great examples to learn from.
-h
Do you have any link for the kit labs? I already did some few PASM methods, like to play OGG files, but look like I forgot too many things in the meantime
JM
I moved everything in the DAT section with the right values instead of calculating them at the runtime. I removed all the spin code, but I don't know how to remove the remaining one. Now there is no need to transfert data between the 2 methods.
But it's still not working
JM
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 CLK_FREQ = ((_CLKMODE - XTAL1) >> 6) * _XINFREQ PUB Main cognew (@cogstart, 0) DAT ORG 0 cogstart OR dira, #%0000_0000_0000_1111 OR outa, #%0000_0000_0000_1000 MOV frqa, 1 MOV ctra, CtrCfg MOV _index, _RampingSteps MOV _Counter, CNT ADD _Counter, _CycleOffset SUB _CycleOffset, #1 loop1 MOV phsa, _HIGH_PULSE_WIDTH WAITCNT _Counter, 0 ADD _Counter, #500 SUB _CycleOffset, #1 SUB _Index, #1 TJNZ _Index, #loop1 OR outa, #%0000_0000_0000_0100 MOV _index, _RunningSteps loop2 MOV phsa, _HIGH_PULSE_WIDTH WAITCNT _Counter, _CycleOffset SUB _Index, #1 TJNZ _Index, #loop2 OR outa, #%0000_0000_0000_0010 MOV _index, _RampingSteps loop3 MOV phsa, _HIGH_PULSE_WIDTH WAITCNT _Counter, _CycleOffset ADD _CycleOffset, #1 SUB _Index, #1 TJNZ _Index, #loop3 end JMP end _index LONG $00000000 _Counter LONG $00000000 _RampingSteps LONG $00001B58 _RunningSteps LONG $00014FF0 _CycleOffset LONG 3000 _HIGH_PULSE_WIDTH LONG $FFFFFF60 CtrCfg LONG %0001_0000_0000_0000_0000_0000_0000_0001
The PEKL links are in the sticky at the top of the Prop forum, though I just looked at them again, and most examples are in SPIN
But, if memory serves, there is a discussion of waitcnt and how you can get unexpected results if you do not 'load' it correctly.....
Also, it appears that you have a lot of constants defined, but no variables..... see RES in the Prop manual.
Sorry, got to run, dinner is on the table......
This code is making the leds blinking perfectly:
MOV _index, _RampingSteps MOV _Counter, CNT ADD _Counter, _CycleOffset loop0 WAITCNT _Counter, _CycleOffset SUB _Index, #1 XOR outa, #%0000_0000_0000_1100 TJNZ _Index, #loop0
I had to adjust the speed. I will see if it can have an impact on the other loops.
Have you had any luck with the conversion?
Bruce
