Translate SPIN to PASM (Using phsa)
Hi there,
I'm trying to translate that:
Into PASM.
So I tried to translate one loop and applied that to all.
So far, here is what I did:
But of course, it's not working.
Everything is pretty simple, but I'm still not able to find the issue
I'm suspecting some issues on the MOV with the address being assigned instead of the values, or the opposite.
So all the suggestions are welcome. I would like to understand what I'm doing wrong.
JM
PUB PulseTheStepPin(StepPin, TotalSteps) | RampingSteps, RunningSteps, Counter, CycleOffset if TotalSteps > RAMPING_RANGE RampingSteps := SPEED_RANGE RunningSteps := TotalSteps - RAMPING_RANGE else RampingSteps := TotalSteps / 2 RunningSteps := TotalSteps // 2 CycleOffset := MIN_SPEED ctra[30..26] := %00100 ' Configure Counter A to NCO ctra[5..0] := StepPin frqa := 1 dira[StepPin]~~ Counter := cnt repeat RampingSteps phsa := -HIGH_PULSE_WIDTH waitcnt(Counter += CycleOffset--) StepCount++ repeat RunningSteps phsa := -HIGH_PULSE_WIDTH waitcnt(Counter += CycleOffset) StepCount++ repeat RampingSteps phsa := -HIGH_PULSE_WIDTH waitcnt(Counter += CycleOffset++) StepCount++
Into PASM.
CON .... HIGH_PULSE_WIDTH = CLK_FREQ / 500_000 'This is the setting for the minimal step pulse width. MIN_SPEED = 7_000 'Adjust this setting to overcome any moments of inertia you may have in your mechanical system. MAX_SPEED = 11_000 'Settings above 11,000 will result in step count inaccuracies for a 2000 uStep drive and settings 'above 12,000 will cause the G251 to falter. 'Do not alter SPEED_RANGE = MAX_SPEED - MIN_SPEED RAMPING_RANGE = SPEED_RANGE * 2 PUB PulseTheStepPinWithCog(StepPin, TotalSteps) | RampingSteps, RunningSteps, Counter, CycleOffset if TotalSteps > RAMPING_RANGE RampingSteps := SPEED_RANGE RunningSteps := TotalSteps - RAMPING_RANGE else RampingSteps := TotalSteps / 2 RunningSteps := TotalSteps // 2 CycleOffset := MIN_SPEED ctra[30..26] := %00100 ' Configure Counter A to NCO ctra[5..0] := StepPin frqa := 1 dira[StepPin]~~ Counter := cnt LONG[_RampingSteps] := RampingSteps LONG[_RunningSteps] := RunningSteps LONG[_CycleOffset] := CycleOffset LONG[_Counter] := Counter COGNEW(@cogstart, @cogstart) DAT ORG 0 cogstart MOV _index, _RampingSteps loop1 MOV phsa, _HIGH_PULSE_WIDTH WAITCNT _Counter, _CycleOffset SUB _CycleOffset, #1 SUB _Index, #1 TJNZ _Index, loop1 MOV _index, _RunningSteps loop2 MOV phsa, _HIGH_PULSE_WIDTH WAITCNT _Counter, _CycleOffset SUB _Index, #1 TJNZ _Index, loop2 MOV _index, _RampingSteps loop3 MOV phsa, _HIGH_PULSE_WIDTH WAITCNT _Counter, _CycleOffset ADD _CycleOffset, #1 SUB _Index, #1 TJNZ _Index, loop3 end JMP end _index LONG $00000000 _RampingSteps LONG $00000000 _RunningSteps LONG $00000000 _CycleOffset LONG $00000000 _Counter LONG $00000000 _HIGH_PULSE_WIDTH LONG $FFFFFFF6
JM
Example:
end jmp #end
will create an endless loop.
Some advice that I hope you will not take in the wrong way: Start REALLY simple and small. You will be glad you did.
-h
I changed the 4 jumps I have.
I have also added some checkpoints. OUT1 to OUT3 are connected to LEDs so I know when the application reach a certain point.
So far, look like the WAITCNT is waiting way longer than what it's supposed. So I will try to dig there.
JM
You are starting a process in another COG - you need to get the data you need from the first COG (running SPIN) to the second COG (running PASM).
I would try some exercises using just one process self-contained in one COG to get familiar with PASM before trying moving to a process like this. The Propeller Education Kit Labs have some really great examples to learn from.
-h
Do you have any link for the kit labs? I already did some few PASM methods, like to play OGG files, but look like I forgot too many things in the meantime
JM
I moved everything in the DAT section with the right values instead of calculating them at the runtime. I removed all the spin code, but I don't know how to remove the remaining one. Now there is no need to transfert data between the 2 methods.
But it's still not working
JM
The PEKL links are in the sticky at the top of the Prop forum, though I just looked at them again, and most examples are in SPIN
But, if memory serves, there is a discussion of waitcnt and how you can get unexpected results if you do not 'load' it correctly.....
Also, it appears that you have a lot of constants defined, but no variables..... see RES in the Prop manual.
Sorry, got to run, dinner is on the table......
This code is making the leds blinking perfectly:
I had to adjust the speed. I will see if it can have an impact on the other loops.
Have you had any luck with the conversion?
Bruce
