Are there any testing board for the BS2p40?
Hi there,
A newby in electronics here. I bought a couple of parallax kits and I am already doing my own simple projects. I want to use a BS2p40 since I need more pins and I do not want to complicate the setup with serializers and multiplexed communications.
Are there any boards out there that I can stick the BS2p40 into it and immediately start programming it? If not, any site showing an easy 1, 2, 3 steps on how to make this board that I need using USB instead of Serial port?
Thanks!
Miguel
Thanks!
Miguel
- If I have 5 volts from other boards already regulated, do I need the 7805 regulator? Regardless, how is it supposed to be connected in your board (it is not in the schematics you mentioned)?
- You mean Serial/USB adapter/cable right? Any USB/Serial cable, removing the Serial head (leaving the USB head on the other side) and connecting the proper cables to the board will do? Are there any specific things that may need to be careful here?
Miguel
http://www.parallax.com/Store/Microcontrollers/BASICStampDevelopmentBoards/tabid/137/CategoryID/12/List/0/SortField/0/Level/a/ProductID/123/Default.aspx
If you are connecting to other boards with solid +5V signal, sure you can use that. I'd still use a filter cap right at the Stamp. Connect your grounds (Vss) together ( I believe pin 4 for you), and connect the +5V to your Stamp's Vdd pin ( believe pin 37 for you). Info at http://www.parallax.com/dl/docs/prod/schem/BS2p40SchematicRevD.pdf
I will be trying a full power suply later (and maybe asking more about it), but not yet, I have still a lot to program to get what I want on the board first, to then move it to a finished product.
Miguel
