SCHOTTKY diode..
RITESH KAKKAR
Hi, i have SMD shocky diode ic, but i don't understand it terminal.
Thanks.
Thanks.
RITESH KAKKAR
Here's the Wikipedia link: http://en.wikipedia.org/wiki/Schottky_diode
It's marked obsolete, BTW. Why are you using it?
I have taken it frommy old STB dth, i study in class that it is used for high freq. switching.
I will be helpful if you tell me more about this package.
thanks.
It probably would have been used with the inductive components of a converter system.
Google schottkey diode and have a look at the Wikipedia entry.
The MOSFET part of the package is just an ordinary device with the naturally ocurring reverse diode shown.
Cheers,
The data sheet will have the relevant ratings, try reading it!
How, the schematic shows only one diode with 4 terminals??
And it allows you to make a wider trace on the pcb so more electricty can go through.
And using multi pins instead of one big wide one, allows the factory to use the same machinery that makes single pins.
And probably helps with cooling with its air space.
look at this one, it have 5pins for the same path to handle 180amp
http://www.infineon.com/dgdl/IPB025N10N3+G_Rev2.03.pdf?folderId=db3a304313b8b5a60113cee8763b02d7&fileId=db3a30431ce5fb52011d1ab1d9d51349
Weren't you taught basic electrical theory at school?
Tony has it right, the 5 pins make up one high current connection, the other high current connection is the tab. The gate of course only needs one pin.
C.W.
No, it's OK i was not absorbing as i was thinking that, little STB will take few mA then what the use of // connection.
but i don't understand what the use of putting Schottky diode and MOSFET in STB??
Here is some detail on "fetky" devices, includes reasons why to combine both devices in one package.
http://www.irf.com/product-info/fetky/
C.W.
I want to calculate it's AC current, how??
this.
The diode/mosfet combination is designed for use in DC switching applications. In those applications the transistor usually switches current on/off to an inductor and the diode blocks reverse current. This type of circuit has high peak currents even though the average current may be low. Having multiple leads results in lower resistance for the high peak currents as well as better heat removal for the chip.
