It's a MOSFET with a diode in the same package. The anode and cathode connections are clearly identified, what is the problem?
It's marked obsolete, BTW. Why are you using it?
I have taken it frommy old STB dth, i study in class that it is used for high freq. switching.
I will be helpful if you tell me more about this package.
thanks.
The package description shows that the unit is used in converters and other DC switching applications. The Schottkey diode works like a regular diode except it has much lower forward voltage drop and recovers from conducting state to non-conducting state much more rapidly than a normal diode. Very useful in rapidly switching inductive loads.
It probably would have been used with the inductive components of a converter system.
Google schottkey diode and have a look at the Wikipedia entry.
The MOSFET part of the package is just an ordinary device with the naturally ocurring reverse diode shown.
Having two pins, is the same as having a thicker wire.
And it allows you to make a wider trace on the pcb so more electricty can go through.
And using multi pins instead of one big wide one, allows the factory to use the same machinery that makes single pins.
And probably helps with cooling with its air space.
Tony has it right, the 5 pins make up one high current connection, the other high current connection is the tab. The gate of course only needs one pin.
C.W.
No, it's OK i was not absorbing as i was thinking that, little STB will take few mA then what the use of // connection.
but i don't understand what the use of putting Schottky diode and MOSFET in STB??
Look up Buck Regulator and Boost Regulator in the Wikipedia. It's very common in these regulators to require an MOSFET and a diode and, because these regulators are commonly used with low voltages, low voltage drop through the diode is important, so a Schottky diode is used.
The diode/mosfet combination is designed for use in DC switching applications. In those applications the transistor usually switches current on/off to an inductor and the diode blocks reverse current. This type of circuit has high peak currents even though the average current may be low. Having multiple leads results in lower resistance for the high peak currents as well as better heat removal for the chip.
Here's the Wikipedia link: http://en.wikipedia.org/wiki/Schottky_diode
thanks.
Cheers,
The data sheet will have the relevant ratings, try reading it!
How, the schematic shows only one diode with 4 terminals??
look at this one, it have 5pins for the same path to handle 180amp
http://www.infineon.com/dgdl/IPB025N10N3+G_Rev2.03.pdf?folderId=db3a304313b8b5a60113cee8763b02d7&fileId=db3a30431ce5fb52011d1ab1d9d51349
Weren't you taught basic electrical theory at school?
C.W.
Here is some detail on "fetky" devices, includes reasons why to combine both devices in one package.
http://www.irf.com/product-info/fetky/
C.W.
I want to calculate it's AC current, how??
this.
