S2 GUI and multiple cogs question — Parallax Forums
schabotte1schabotte1 Posts: 3
edited 2011-01-16 06:05 in Robotics
Hi,
Is it possible to run multiple cogs via the S2 GUI? I can't find any references to this in the help files for the GUI.
Steven
  • WhitWhit Posts: 4,194
    edited 2011-01-16 05:51
    Steven, Both the S2 default program(demo) and S2 object run multiple cogs. So, in the GUI this is happening seamlessly. You don't really see it or know it, but it is happening.
    If you are asking whether there is direct cog control in the GUI, the answer is no. The object uses the graphic program and runs it, doing what is necessary (as regards the cogs) to make it function. That is one of the marvels of the GUI.
    Phil Pilgrim (PhiPi on these forums) could give a better explaination. He wrote the S2 object. The S2 default program was written by Ben Wirz. Open them and look around, they are worth your study. Also look at the help for the S2 Object (at the bottom of the help index for the GUI.
    Hope this helps.
  • schabotte1schabotte1 Posts: 3
    Thanks for the heads up on that. It is appreciated!
    Steven
