S2 GUI and multiple cogs question
Is it possible to run multiple cogs via the S2 GUI? I can't find any references to this in the help files for the GUI.
Steven
Steven
If you are asking whether there is direct cog control in the GUI, the answer is no. The object uses the graphic program and runs it, doing what is necessary (as regards the cogs) to make it function. That is one of the marvels of the GUI.
Phil Pilgrim (PhiPi on these forums) could give a better explaination. He wrote the S2 object. The S2 default program was written by Ben Wirz. Open them and look around, they are worth your study. Also look at the help for the S2 Object (at the bottom of the help index for the GUI.
Hope this helps.
Steven
