PASM pin test timeout question
Duane Degn
I'm working on a universal remote program using Nick's MagicIR. I'm still relatively new to PASM but I think I understand most of Nick's code. The exception is this part:
The way I see it, this should work except when the system clock is within timoutMax cycles from the roll over. In these cases I'd think the timeout would occur immediately since the first time timeoutCurrent and cnt are compared cnt would be larger than timeoutCurrent.
Another possible problem is if timeoutCurrent is closer to the roll over point than the time the loop takes (e.g. timeoutCurrent = ($FFFFFFFF - $4) with a loop that takes 12 clock cycles it is unlikely that cnt would often (if ever) be larger that timeout Current). In this (very unlikely) case the loop may never end since timeoutCurrent could be larger than cnt every time it is checked.
Am I not understanding this? I'd like to prevent a rare lockup of my code.
Is there a beter way to monitor a pin with a timeout?
Duane
PS While the code above is Nick's, it might not look the same. I changed most (if not all) variable names to match my convention.
mov timeoutCurrent, cnt ' prepare for calculating timeout
add timeoutCurrent, timeoutMax ' start with cnt and add max timeout
pauseloop cmp timeoutCurrent, cnt wc ' if current timout has exceeded the system clock, set the C flag
if_c jmp #exit ' current timeout exceeded, jump to exit
test Pin, ina wc ' no worries on timeout anymore, just check for a state change on ina
if_c jmp #pauseloop ' if there's no statechange, jump back to pauseloop
{later}
timeoutMax long 10_120_000 ' how many ticks until I give up on new signals
Duane
Off to make my brain hurt (in a good way).
Thanks again for all your help. As I've mentioned before, I'm a big fan of your articles.
As I remember, you wrote about timing on the Prop, though I think it was in Spin. I'll have to reread that article too.
Just to be clear, the code I posted will have problems at certain times in the system clocks cycle?
Duane
I ve be used that code to ---> And that give me info why some times this code in ViewPort shows strange things.
mov timeoutCurrent, cnt ' prepare for calculating timeout pauseloop mov timeoutDelta, cnt 'Get current time. sub timeoutDelta, timeoutCurrent 'Compute elapsed time. cmp timeoutDelta, timeoutMax wc 'If elapsed time has met or exceeded timeoutMax, clear carry. if_nc jmp #exit ' current timeout exceeded, jump to exit test Pin, ina wc ' no worries on timeout anymore, just check for a state change on ina if_c jmp #pauseloop ' if there's no statechange, jump back to pauseloop {later} timeoutMax long 10_120_000 ' how many ticks until I give up on new signals-Phil
BIG Thanks
Where's the fun in that?
I think I'd have figured it out in a couple of hours. (Actually I think I was getting close.) Here's an example in FullDuplexSerial (I want Jon to know I did my homework).
receive jmpret rxcode,txcode 'run a chunk of transmit code, then return test rxtxmode,#%001 wz 'wait for start bit on rx pin test rxmask,ina wc if_z_eq_c jmp #receive mov rxbits,#9 'ready to receive byte mov rxcnt,bitticks shr rxcnt,#1 add rxcnt,cnt :bit add rxcnt,bitticks 'ready next bit period :wait jmpret rxcode,txcode 'run a chuck of transmit code, then return mov t1,rxcnt 'check if bit receive period done sub t1,cnt cmps t1,#0 wc if_nc jmp #:wait test rxmask,ina wc 'receive bit on rx pin rcr rxdata,#1 djnz rxbits,#:bitI think what you wrote is hidden in there. You sure make it look easy.Now I'll have to make my brain hurt some other way.
A big thanks from me too.
This lots of fun.
Duane
Sorry... I would normally have posted a snippet for you to try but I was on my way out the door and I was hoping to point you in a helpful direction. Phil is the man -- listen to him by all means!
Not a problem at all. I'm often amazed at how helpful people (yourself included) are on this forum. I've seen you give very detailed answers many times. I often learn a lot from these posts.
I was pleased that my most resent perusal of FullDuplexSerial wasn't near as intimidating as I thought it'd be.
Yes, Phil is the man. He's another one I've learned a lot from.
My thanks to both of you.
Duane
