Got some coding issues that I'm trying to resolve for him. We're using RCTIME to gather data for the servos. I suspect that my RCTIME to servo routines aren't quite sync'd yet.
You can use the PBASIC library found in the OBEX. There are actually three objects to get more of BASIC Stamp functions: BS2 Functions by Martin Hebel are here and another RCTIME by Beau is here. PAUSE is here. BS2 simplified commands by Microcontrolled are here. That's everything that I know about. Is there anything to add?
You can also get BASIC functions using Bean's PropBASIC and it's a compiled converted result. In another Bean project posted on the Forum, you can put 8 BASIC Stamps into a single Propeller chip, one running in each cog.
Robert
Yes, this is the improved hand.. bigger, faster, stronger..
Gramps would like to be able to pour a can of soda, then crush the can.
OBC
Won't he need a robotic forehead?
OBC
OBC
