Using Prop. Video Generator Unit (VGU) AND CTRB counter
Hi Folks,
I am attempting to write a section of code that will output a data stream from the VGU while simultaneously generating a clock signal (to be used with the data stream) using CTRB. I have configured CTRA/B similarly, using a different PLL tap to make the clock signal 2x that of the data signal.
The code works - sort of. The problem I have is that the relative phases of the signals are unpredictable, sometimes the clock signal is 'high' during the data hold time, others it is 'high' during the data transition time. (See timing diagram at top of attached code) I have included instructions that restart the counters prior to executing the WaitVid instruction, but this does not seem to help. Anyone have any guesses as to what the issue might be?
Thanks, -h
(OK, for some reason the timing diagram is not showing correctly, although I have been able to cut/paste with Word and Notepad......)
Thanks, -h
''Want to output test data (VGU) and clock signal (CTRB) so that clock signal always does a low-high transition near ''the middle of the test data bit '' '' CLOCK  '' '' DATA  ''Looking with O'scope on clock and data lines I sometimes get the above, but also get this: (inverted clock, ''clock and data transition low-high at same time :( '' '' '' CLOCK  '' '' DATA  org 0 LCDgen mov dira, outPins 'make outputs movi vcfg, #%0_01_1_0_0_000 'VCFG set to 8-bit, 4-color). movd vcfg, #%000000_000 'pins 7..0 for video output movs vcfg, #%0_0000_0001 'mask to be used for video output ---->p0 for test mov VSCLset, _VSCLset mov vscl, VSCLset 'mov timing of video output to vscl register mov FREQa, _FREQa movi ctra, #%000001_010 'config counterA in video mode (pll) - divisor of 32----> DATA mov FREQb, _FREQb 'load freqb, but do not load into frqb yet (ie dont start ctrb yet) movs ctrb, #1 'set output pin from ctrb - p1 movi ctrb, #%00010_010 'config CTRb PLL-single ended - div of 32 ----> CLOCK mov pixels, _pixels ' mov colors, _colors mov zero, #0 mov delay, _delay mov time, cnt add time, delay waitcnt time, delay dataOut mov tA, #100 mov frqa, FREQa 'set frequency of CTRa and start running mov frqb, FREQb 'set frequency of CTRb and start running :loop waitvid colors, pixels djnz tA, #:loop waitpeq zero, #%0000_0010 'wait for p1 to be low mov frqb, #0 'stop CTRb mov frqa, #0 'stop CTRa mov phsb, #0 'clear CTRb starting value mov phsa, #0 'clear CTRa starting value jmp #dataOut _pixels long %0100_0100_0100_0100_0100_0100_0100_0100 '0,1,0,1,0,1 etc _colors long %1111_1111_1111_1111_1111_1111_0000_0000 ' 0=0's, 1=1's outpins long %0000_1000_0000_0000_0000_0000_1111_1111 'pins that will be used for data and clk's _VSCLset long %0000_0001_____0000_0001_0000 '1clk/pixel - 16clks/frame ' _FREQa long $1000_0000 'PLL freq = 16*(80MHz x $1000_0000)/2^32 = 80MHz _FREQb long $1000_0000 _PHSbStart long $1000_0000 _delay long 10_000_000 _XCLmask long %0000_0010 'XCL = p1 pixels res 1 colors res 1 VSCLset res 1 FREQa res 1 FREQb res 1 PHSbStart res 1 time res 1 delay res 1 XCLmask res 1 zero RES 1 tA res 1
BTW, you don't need to use the so-called "video mode" of CTRA to drive the video circuitry. Any PLL mode will work, in case you also want to assign the output to a pin. This can be handy for generating a dot clock when VSCL is set up for one clock per pixel.
Thanks for the info, I was running out of possible ways to sync the waveforms.
I'm feeling a little obtuse....... Nothing to see here, keep moving......
-h
