Using Prop. Video Generator Unit (VGU) AND CTRB counter
Hi Folks,
I am attempting to write a section of code that will output a data stream from the VGU while simultaneously generating a clock signal (to be used with the data stream) using CTRB. I have configured CTRA/B similarly, using a different PLL tap to make the clock signal 2x that of the data signal.
The code works - sort of. The problem I have is that the relative phases of the signals are unpredictable, sometimes the clock signal is 'high' during the data hold time, others it is 'high' during the data transition time. (See timing diagram at top of attached code) I have included instructions that restart the counters prior to executing the WaitVid instruction, but this does not seem to help. Anyone have any guesses as to what the issue might be?
Thanks, -h
(OK, for some reason the timing diagram is not showing correctly, although I have been able to cut/paste with Word and Notepad......)
Thanks, -h
''Want to output test data (VGU) and clock signal (CTRB) so that clock signal always does a low-high transition near
''the middle of the test data bit
'' CLOCK 
'' DATA 
''Looking with O'scope on clock and data lines I sometimes get the above, but also get this: (inverted clock,
''clock and data transition low-high at same time :(
'' CLOCK 
org 0
LCDgen mov dira, outPins 'make outputs
movi vcfg, #%0_01_1_0_0_000 'VCFG set to 8-bit, 4-color).
movd vcfg, #%000000_000 'pins 7..0 for video output
movs vcfg, #%0_0000_0001 'mask to be used for video output ---->p0 for test
mov VSCLset, _VSCLset
mov vscl, VSCLset 'mov timing of video output to vscl register
mov FREQa, _FREQa
movi ctra, #%000001_010 'config counterA in video mode (pll) - divisor of 32----> DATA
mov FREQb, _FREQb 'load freqb, but do not load into frqb yet (ie dont start ctrb yet)
movs ctrb, #1 'set output pin from ctrb - p1
movi ctrb, #%00010_010 'config CTRb PLL-single ended - div of 32 ----> CLOCK
mov pixels, _pixels '
mov colors, _colors
mov zero, #0
mov delay, _delay
mov time, cnt
add time, delay
waitcnt time, delay
dataOut mov tA, #100
mov frqa, FREQa 'set frequency of CTRa and start running
mov frqb, FREQb 'set frequency of CTRb and start running
:loop waitvid colors, pixels
djnz tA, #:loop
waitpeq zero, #%0000_0010 'wait for p1 to be low
mov frqb, #0 'stop CTRb
mov frqa, #0 'stop CTRa
mov phsb, #0 'clear CTRb starting value
mov phsa, #0 'clear CTRa starting value
jmp #dataOut
_pixels long %0100_0100_0100_0100_0100_0100_0100_0100 '0,1,0,1,0,1 etc
_colors long %1111_1111_1111_1111_1111_1111_0000_0000 ' 0=0's, 1=1's
outpins long %0000_1000_0000_0000_0000_0000_1111_1111 'pins that will be used for data and clk's
_VSCLset long %0000_0001_____0000_0001_0000 '1clk/pixel - 16clks/frame '
_FREQa long $1000_0000 'PLL freq = 16*(80MHz x $1000_0000)/2^32 = 80MHz
_FREQb long $1000_0000
_PHSbStart long $1000_0000
_delay long 10_000_000
_XCLmask long %0000_0010 'XCL = p1
pixels res 1
colors res 1
VSCLset res 1
FREQa res 1
FREQb res 1
PHSbStart res 1
time res 1
delay res 1
XCLmask res 1
zero RES 1
tA res 1
BTW, you don't need to use the so-called "video mode" of CTRA to drive the video circuitry. Any PLL mode will work, in case you also want to assign the output to a pin. This can be handy for generating a dot clock when VSCL is set up for one clock per pixel.
Thanks for the info, I was running out of possible ways to sync the waveforms.
I'm feeling a little obtuse....... Nothing to see here, keep moving......
-h
